2018 reign dropper post ?- Mtbr.com
    May 2018
    Anyone know what length DP is in size small 2018 reign advanced ? And can a longer one be accomodated ?
    Reputation: LargeMan's Avatar
    May 2017
    Believe it is a 125mm, you can put a 170mm on if you are tall enough.
    Reputation: jeremy3220's Avatar
    Jul 2017
    Quote Originally Posted by LargeMan View Post
    Are you sure? One of the demo reps told me the XL only took a 150mm(or less) dropper due to the bend in the seat tube.
    Reputation: Steel Calf's Avatar
    Feb 2010
    Quote Originally Posted by jeremy3220 View Post
    well he probably meant that only a 150mm post can be fully inserted (which means switching to the 170mm post will require more than just 20mm more inseam)
    people usually forget that a 170mm post is 40mm longer than a 150mm post because the additional 20mm travel needs to go somewhere
  1. Replies: 1
    Last Post: 02-11-2018, 07:49 PM
  2. Replies: 6
    Last Post: 10-24-2017, 08:31 PM
  3. Replies: 12
    Last Post: 09-16-2017, 07:18 AM
  4. Replies: 3
    Last Post: 09-23-2016, 09:58 AM
  5. Replies: 3
    Last Post: 10-20-2014, 09:06 PM
