2018 Giant Anthem Suspension Maintenance- Mtbr.com
Results 1 to 6 of 6
    Gun
    Gun is offline
    Jun 2016
    Hello:
    I just purchased a used 2018 Anthem Advanced Pro 29 1. I have never owned a full suspension bike before. Can anyone tell me what kind of maintenance and service I need to do on the suspension pivot points? Thanks for any advice you can provide!
    Thanks,
    Gun
    Reputation: grubetown's Avatar
    Sep 2013
    Make sure they are torqued correctly. Donít spray high pressure water directly into them. Replace them when they wear out. Bigger issue I see is the rear shock hasnít been maintained properly.
    Gun
    Gun is offline
    Jun 2016
    Grubetown,
    Thanks for the information. The person I bought the bike from had the fork and shock serviced so I am good for a while. I am going to plan on having the fork and shock serviced annually just because they are so expensive to replace.
    I have a 2012 Anthem X 29er and also purchased used, back in 2016. Soon after purchasing the bike things were getting noisy in the BB area. I pulled the Maestro linkage apart and pried the seals off the cartridge bearings and all but one were bone dry. I repacked with quality grease and went on my way.
    Two seasons later I repaced all the bearings. To my surprise the brand new giant bearings, 6 bearings for the lower link were all dry, out of the factory packaging. I replaced the top 4 bearings with "EnduroMax" which cost less and have plenty of their high quality synthetic lube.
    Also had a similar experience with my 09 Trance many years ago so it appears Giant may be getting bearings from a lower quality source. They are all sealed but what is the point if there is little or no lube in them.
    I would suggest checking the condition of the bearings. I pry the seals of with an exacto- knife. If dry pack with a quality synthetic waterproof grease. If they are rusted/dry, replace them with "EnduroMax" bearings.
    Good luck with the bike!!
    Yes the giant bearings are v low quality - don't even come with waterproof grease from the factory. Mine lasted a year, and the LBS damaged the paint replacing them... Even with the right tool!
    Master of Beat
    Reputation: attomixt's Avatar
    Dec 2004
    I can't find what bearings are needed for an Anthem (2018 advanced in particular.) Are you guys just going to diant dealer and ordering? Also I see there used to be a nice maestro tool you can buy but its no longer made? Anyone have any info?
  1. Giant Anthem 3 (2018) Vs Giant Trance 3 (2018)
    By NebWaldron in forum Beginner's Corner
    Last Post: 03-20-2018, 12:59 AM
  2. Replies: 15
    Last Post: 06-18-2014, 09:54 AM
  3. 2009 Giant Anthem Vs 2008 Giant Anthem
    By Bigno in forum Giant
    Last Post: 10-13-2008, 02:44 AM
  4. Giant Anthem 1 '06 vs. Giant Anthem 1 '08
    By goodfella in forum Giant
    Last Post: 09-28-2008, 04:06 AM
  5. Replies: 3
    Last Post: 05-24-2008, 06:16 AM
Members who have read this thread: 53
