2017 Trance 3 - 1x10 conversion- Mtbr.com
Results 1 to 8 of 8
    Nov 2017
    Hi all,
    Can anyone advise if the Deore rear mech on the 2017 Trance 3 will be ok running a 11-42 cassette?
    Also as the bike is boost, do I need a boost specific front N/W for a 1x conversion? Sorry for the questions but I haven't had a bike with boost before.
    Apr 2013
    the spec doesn't list the rear mech model but it looks like the sgs model since the bike comes with an 11-36 cassette. i'd think it would be fine with the 11-42 as its total capacity is listed as 43t. the only thing i'm not sure about is the top pulley clearing the 42t cog and whether the b-tension would be long enough to help. yes you will need a boost specific ring as the offset is different between boost and non boost.
    Jan 2013
    just get a medium cage, let the air out of the shock and compress the rear suspension.
    run the chain through the system on the largest rear cog and around the chainring.
    Take up all the slack from the rear mech and cut the chain at that point.
    this should suffice
    Shimano Deore M610 10 Speed Rear Mech | Chain Reaction Cycles
    Jan 2013
    I run a short cage zee on a 11x36 so the medium should be ok for 42. Any larger than 42 I would choose a long cage rear mech. and that link offers both medium and long.
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by mjs1231 View Post
    this should suffice
    Why get a med cage when op most likely has a long already given a 3x. Only reason for a new der is if the stock one isn't a clutch type.
    Wait whuuut, who did he tell you that!?!?....
    Nov 2017
    So as long as itís clutch type I should be ok? Just wasnít sure if it would clear the 11-42 cassette.
    NedwannaB
    Quote Originally Posted by Craig24 View Post
    If it's a Deore rr der it should work fine. You could also just get an 11/40t cassette to be sure and adjust what size front ring size to get the same net granny gear.
    Feb 2006
    if you're gonna change the rear derailleur / cassette / chainring.... you may as well go 1x11 checkout chainreactions groupset kits.... 1x11 works way better than 1x10
    you can get a SLX Shifter/Derailleur/Crankset/cassette/Chain for $224
  1. Trance 2017 vs Trance 2016
    By Corporate in forum Giant
    Last Post: 05-23-2017, 01:38 PM
  2. Should I get a Giant Trance 3 2016 or a Giant Trance 3 2017?
    By harell286 in forum Beginner's Corner
    Last Post: 01-04-2017, 09:25 PM
  3. Replies: 9
    Last Post: 12-08-2016, 12:16 PM
  4. Replies: 3
    Last Post: 06-05-2016, 10:29 PM
  5. Replies: 17
    Last Post: 05-16-2016, 09:58 PM
