2016 Glory / Vivid shock question- Mtbr.com
Results 1 to 7 of 7
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    There is a noticeable "top out" on the rear shock upon full, rapid rebound. You can feel it through the bike.
    Are others having the same thing?
    If this is normal, no big deal.
    I have the same problem, and a guy i met in Hafjell Bikepark had the same topout.
    Maybe it could be wrong nitrogen pressure?
    Keep on Rockin...
    Nov 2003
    Found out it is "normal" for this bike/shock.
    Reputation: Scott@GO-RIDE.com's Avatar
    I have not noticed this on the 2015 Glory's we have sold. The Vivid R2C has two rebound adjusters and they need to be set up in synce to work properly. Check the set up recommendations on Rockshox website.
    Can't keep track anymore - Giant, Santa Cruz, Pivot, Yeti, Norco, Salsa, Intense - if it rolls on dirt I like it :thumbsup:
    Keep on Rockin...
    Nov 2003
    Ran into a few other 2016s and there slight too out thunk is there. Probably normal.
    Mar 2006
    are you guys topping out on the vivid coil r2c or the vivid air r2c? any thoughts on whether air or coil is better for the glory 0 frame?
    Keep on Rockin...
    Nov 2003
    Coil, and aside from a minor annoyance, it is a non-issue.
  1. Vivid / Vivid Air Knob Question
    By Techspec360 in forum Shocks and Suspension
    Last Post: 10-25-2017, 12:52 AM
  2. Replies: 6
    Last Post: 05-03-2016, 10:43 PM
  3. New Glory 0 with Vivid Air
    By stejam in forum Giant
    Last Post: 09-26-2015, 08:30 PM
  4. Replies: 1
    Last Post: 05-01-2015, 06:36 PM
  5. Vivid R2 450# coils on Glory 01
    By Hobblyjig in forum Downhill - Freeride
    Last Post: 07-10-2011, 08:41 PM
