2016 anthem crank options- Mtbr.com
Results 1 to 8 of 8
    Mar 2019
    What crankset size do I need for this? Would like to get a sram NX 1x but not sure which one will fit.2016 anthem crank options-screenshot_20190807-164649.jpg2016 anthem crank options-20190807_174911.jpg
    Reputation: minimusprime's Avatar
    Any GXP crank should do. The truvativ stylo cranks are a good deal if buying new (250 for carbon and 125ish for aluminum). I also like the older s1400 and x9 with the removable spider. You can find those for pretty cheap these days.
    FYI, there is no difference between boost and non-boost cranksets. The only difference is in the chainring offset. A boost crank is going to come with a boost offset chainring, so if your frame is not boost, that will need to be replaced. However the spindle and crank arms are identical.
    Mar 2019
    ok, so i picked up a used sram GX crankset. The left side does not have a tight fit. There is a small diameter difference between the shaft and the bearing. The crank side seems to be fine. Is this common and i will just need the correct bearing or does something seem off? the bearing feels smooth when i turn it by hand so i wouldnt think the bearing is bad.
    Giant use press fit bb92? For a GXP installation did you put back the wavy washer? I remember this being the difference on my Anthem X 29er (press fit) vs my ROS/SIR 9 (threaded)
    Mar 2019
    ive got one ordered. not sure how will make the shaft fit the bearing tighter. looking online, i noticed some of the BB have MTB on it. do all MTB bottom brackets have MTB stamped on it?2016 anthem crank options-bb.jpg
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    You didn't buy a "Dub" crankset did you?
    2015 Kona JTS
    2014 Scott Scale 710
    2019 Giant Anthem Advanced 1 29
    Mar 2019
    I got the frame from a guy and BB was already installed(see first pic of post). All I know is what's stamped on it.
    Quote Originally Posted by i_rek_alot View Post
    Post a couple pictures with the crank installed.
    2015 Kona JTS
  1. Replies: 22
    Last Post: 06-05-2016, 08:50 PM
  2. Replies: 23
    Last Post: 12-01-2015, 10:18 AM
  3. Anthem SX advanced 2015 / Anthem SX 1 2016
    By Kulharin in forum Giant
    Last Post: 10-14-2015, 08:14 PM
  4. Replies: 1
    Last Post: 06-02-2014, 03:02 AM
  5. Replies: 9
    Last Post: 01-28-2012, 05:32 PM
Members who have read this thread: 17
