What's the best way to touch up a matte black frame?- Mtbr.com
Results 1 to 15 of 15
    I want to touch up some scratches, but I want to do it the best way I can to prevent it from being an obvious touch-up. ya know?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Matte black paint, you kinda fog it on trying to blend it on with a fade into the original paint.
    Bicyclochondriac.
    Quote Originally Posted by mmik
    I use dirt and mud to hide scratches.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Try a Sharpie
    No moss...
    Reputation: husonfirst's Avatar
    Try using paint made for plastic models such as Testors.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    It's time for a new frame
    Honestly... ahh I give up
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    A sharpie has always worked fine on my matte black. Can barely see it, unless very close up.
    That might not work, they're chips, not scratches.
    Rookie
    Reputation: MonsterD's Avatar
    Mar 2011
    Quote Originally Posted by highdelll
    Confirmed for not riding hard enough/aggressively. Then again, I haven't seen any other post saying that he does. Lets just say if you don't have nicks and scratches on your frame you are riding on grass or bike paths.
    Ruder than you.
    Ska is not dead!
    he was making fun of me, monster D
    >_<
    Rebmem Rbtm
    Reputation: claydough001's Avatar
    Take a syringe and and a pair of wire cutters. Cut the pointed tip off of the syringe. Sand the fresh cut tip down so that it is nice and smooth with a nice hole so that the paint can flow. Large guage work best. Take the needle off and suck the paint up into the syringe. Put the needle back on and use the syringe like a pen. I touched up cars and trucks for 10 years and thats the best way to do it.
    If you sand the matte it turns shiny. FYI.
    great advice about the syringe, thanks!
    Also, I love matte finish, so I'd like to keep it as such.
    Is there a sort of reverse-polish I can do to it if the freshly painted sections are shiny?
    Rebmem Rbtm
    not really. You can get a bit of acetone and wipe it off and re-apply. Usually the automotive paint i used back in the day dried in sort of a matt finish which was a problem because it clashed with the gloss finish so when it dried i would hit it with a syringe of clear. If i were you i would go to wal-mart and buy a can of flat black spray paint. It will say on the little white sticker on the can "Flat Black" Shake it up very good and spray it into the top cap of the spray can until you get enough so that you can draw it into the syringe. A little bit will go a long way because you want to make sure you dont apply too much. It will run. If you have to hit the rock chips 2 or 3 times thats fine but use thin layers and re-apply as needed.
    The Angry Singlespeeder
    Reputation: Genshammer's Avatar
    Frosted Glass
    When we repair carbon frames that have a matte finish, we use a little trick to perfect the blend area. There's this spraypaint finish you can buy at Home Depot called 'frosted glass'. Stuff is seriously magical. Once we're done color matching and spraying our matte coat, if it still isn't perfectly blended, we use the frosted glass, and bingo. Give it a try.
    Here's an Argon 18 we repaired with a matte finish on the nude carbon. We used some of the frosted glass to blend it. Came out perfect.
    Kurt Genshammer
    @AngrySinglespdr
Members who have read this thread: 7
