• 03-25-2014
    Picard
    what is the best solvent to clean expensive oakley glasses lens?
  • 03-25-2014
    John Kuhl
    I use soap and water. Rinse good after, and dry with a
    clean terry cloth towel.
  • 03-26-2014
    In-Yo-Grill
    Dawn dishwashing liquid. It's a mild degreaser and will take off the oils from your skin.
    Also really good for cleaning bike parts. If you let them soak in a bucket with a water/soap mix they scrub super clean.
  • 03-26-2014
    AZ
    I use Acetone on the cheap ones.
  • 03-26-2014
    Picard
    what about Zeiss or Purisol lens cleaner?
  • 03-26-2014
    DIRTJUNKIE
  • 03-26-2014
    eatdrinkride
    Re: what is the best solvent to clean expensive oakley glasses lens?
    Expensive Oakley glasses are mainly expensive because of the brand name not the quality of the product so much. I have an "expensive" pair of Maui Jims I simply lick with my tongue and wipe with a cloth that came with them. Works perfectly. If they actually have dirt on them rather than just dried sweat I'll use dish soap.
  • 03-26-2014
    Cleared2land
    Oakley has cheap lens?
  • 03-31-2014
    swingset
    Microfiber > terry cloth. But otherwise, this.
  • 03-31-2014
    LittleBitey
    Spit and a cotton tshirt
  • 04-01-2014
    In-Yo-Grill
    HaHa...I do the same thing when I'm out fishing with my Costa's.
    Oakley doesn't make glass lenses so they are easier to scratch. This makes them lighter which is why I like them for riding.
    I wouldn't use my T-shirt to wipe them off unless it was a dry-fit shirt and even then I'd prefer to just carry a lens cloth with me on rides.
  • 04-01-2014
    Spencerespencer
    Do to a local eyeglass store and they have a special spray it's about $5 bucks then get a microfiber rag. I use that on my bottle rockets! Works great!
  • 04-01-2014
    Procter
    Vanity keeps then clean, you need nothing else.
  • 04-01-2014
    dbhammercycle
    Don't use fingernail polish remover, it will scar the plastic. In fact, stay away from solvents.
    I agree with using dish soap, it de-greasing capabilities also work well for grease stains on clothing as a pre-treater too. Using spit and your t-shirt will most likely scratch the lenses. Use a clean terry cloth/micro-fiber towel to dry and wipe.
  • 04-01-2014
    DiRt DeViL
    Use the bag that came with them after you remove the crud with water.
  • 04-01-2014
    LB412
    dish soap
  • 04-01-2014
    sjfsr-shep
    Spit and the cloth that came with them.
  • 04-01-2014
    AZ
    The OP trolled asking about "solvent", Acetone is a high quality solvent.
  • 04-01-2014
    dbhammercycle
    This is true.
  • 04-01-2014
    eatdrinkride
    Spit on the dish soap!
  • 04-02-2014
    153stars
    Bausch & lomb sight savers. Like a wet wipe in foil pouch. I "borrow" some from work when jet skiing as your glasses get real funky on the river.
    Solvent on plastic glasses... reminds me of funny story . Guy at work" who's always real smart ass" gets a cool okley style pair of saftey glasses from parts guy. Asks my buddy in maint shop to mark em so no one steals them. So he goes to bench grinder....grinds all the way across the center of lens. "There no one will steal them now" Look on his face PRICELESS.
  • 04-03-2014
    rockerc
    I have my assistant send them back to Oakley when they get dirty. There is always a fresh pair in her pack for me.
  • 04-03-2014
    Trajan556
    Warm water and the cloth that came with them.
    They will eventually scratch. You use something and this will happen. The lenses are replaceable.
  • 04-04-2014
    In-Yo-Grill
    Baush&Lomb sells some cleaning wipes that work well too. You can buy a box at Wal-mart cheap.
  • 04-04-2014
    mcrn12
    vinegar and distilled water
  • 04-04-2014
    dbhammercycle
    In what ratio?
  • 04-04-2014
    mcrn12
    I mix this to clean car windows and use it to clean any glass.....I do about 1/3 vinegar to 2/3 water.....however you can use straight vinegar if the windows are really bad. If I have hard water spots on my windshield I use straight vinegar....works great!
  • 04-04-2014
    DIRTJUNKIE
    I've had probably 10 pairs of Oakleys over the years and it doesn't matter how you take care of them they're going to get scratched. The best way I found is to give up and buy Ray Ban or equivalent. ;) It's harder to scratch a glass lense BUT glass lense shades aren't meant for high impact sports like what Oakleys are designed for. Best advice above is just a good eye glass cleaner liquid with a eye glass shami or use the bag they came in.
  • 04-04-2014
    dbhammercycle
    Vinegar will work well on hard water stains, as they are typically the result of calcium in the water, due to the fact the vinegar contains acetic acid. While the concentration of the acid in vinegar is not particularly high, this varies by vinegar type and is a off product of bacteria that converts alcohol to acetic acid, it may not scar the lenses but could lead to a quicker breakdown of the laminate on the lenses which protects against scratches. All lenses can be scratched upon exposure to the elements. The best thing to do is clean them periodically with soap and use a clean microfiber cloth to wipe them off afterwards. Micro 90 works well, most detergent soaps will do the job, just be careful to use a clean cloth to wipe clean. If you find yourself on the trail with muddy glasses, rinse them off first with water before wiping them clean. The gritty mud will do a great job of scratching them up if not rinsed off first. When I was a student janitor briefly in college, we used Dawn to clean the windows instead of Windex or other cleaners. It simply gave the best results with no streaking. So: dish soap, water, and a clean microfiber cloth.
  • 04-04-2014
    bmwjnky
    I have been wearing Oakley's since the mid 90's and have had the best luck with warm water and dish soap. This was the recommended cleaning method from Oakley in the paperwork with the glasses and the only way I clean mine when the pouch they come with doesn't work. Also wash pouch every few months.
