What are the advantages of a tubeless tire setup?- Mtbr.com
Results 1 to 85 of 85
    The wheels and tires of my new Stumpjumper are tubeless ready and a
    valve kit was included with the bike. In the three months that I have had the bike I
    have had four flats, two of which I had to pull thorns out of the tires.
    what are the pros and cons of a tubeless set-up?
    High Desert MTBer
    Reputation: rockerc's Avatar
    I presume you are running tubes in them, altho you do not say. If you were running tubeless with sealant your problems would be solved. Best thing that ever happened to MTBing.
    It's all Here. Now.
    Reputation: Schott's Avatar
    Nov 2012
    Well, yes, if you were to go tubeless, chances are that if your sealant were fresh, it would have sealed up the thorn punctures. It also gets rid of pinch flats, which are a problem when running lower pressures. Since you are able to run the lower pressure, you getter better traction and a softer ride. It may take some experimentation based on your weight, but when you find the right PSI, it is fantastic. Besides all of that, it's lighter weight. I always carry a tube just in case, and used it for the first time a couple of weeks ago because of a sidewall gash.
    Cons? Well, I guess setting up the first time can be difficult, but after you've done it a few times it's easy. If you do have to put in a tube on the trail, it could be a little messy.
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Try reading into it more. There are pages and pages of info on tubeless for MTB use. General consensus is just do it. You wont regret it.
    Raised in a Chicken-Coop by Chickens
    I went tubeless 4yrs ago and have yet to experience a flat.with tubes i was going flat once a week.
    You will need to cheak tire pressure before each ride....not a bad thing.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    Quote Originally Posted by Sheepo5669 View Post
    ^^ This!
    I like turtles
    Reputation: TiGeo's Avatar
    First off - you have a great setup. The rims and the tires are ready to be set up tubeless making the whole process much easier to do. I would go ahead and do it.
    The pros are no flats, ability to run lower air pressure and avoid pinch flats, and the ability to tell people you run tubeless which increases you cool factor
    Honestly, its really a great way to go - I haven't had a flat tire in over a year since doing it. I would say the cons are it is typically more messy with the sealant.
    For your bike, just remove the tube. If you have red standard rim tape, you need to remove it and replace with the yellow Stan's tape in the appropriate width (clean the rim with alcohol first..the yellow tape won't stick to it if its not clean..this will lead to air loss). Install the valve stem. Set the tire except for once section of the bead. Dump 2 scoops of Stan's sealant in there and set the rest of the bead. You should be able to inflate with a floor pump - if this doesn't work, use CO2 or an air compressor (I just use CO2..so darn easy..just costs a few bucks). Do the Stan's shimmy (youtube or Notubes site). Ride happy.
    There is a @#[email protected]#$ load of info on this here..just search it.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Sounds like the only disadvantage is that repairing a flat will be messy.
    Checking tire pressure before each ride - already do that. I run 38psi in both tires and I weigh 185lbs.
    What do you all weigh and what level of psi are you running?
    Moderator Moderator
    Not sure which Specialized rims you have, but I had bad luck running their DT 450 and 550 rims tubeless. They're difficult to set up, burp easily, and wont support the lower pressures where the magic happens. Just got rid of the last 450 rim last week and happy to have it gone. Give me a Stans or WTB i series rim any day.
    K3N
    K3N is offline
    Certified slacker
    Reputation: K3N's Avatar
    Aug 2010
    I've only had 1 flat tire since being tubeless over 2 yrs. and that was caused by my laziness of not airing up my tire before a ride and the tire burped. Keep your psi up and it's never an issue.
    I'm at about 180 geared up and run 28 psi. (29er)
    I like turtles
    Quote Originally Posted by stepitup_onenotch View Post
    It can be - but typically this is only when you cut the tire and would need to boot it and add a tube. I still carry a tube for this reason and have done it on the trail...you get Stan's on you..no doubt.
    At 185, you should be able to run in the mid to upper 20s with no issues.
    I am 165 and run 22 psi f/r.
    I like turtles
    Quote Originally Posted by Metamorphic View Post
    He says they are "new" and came with valve stems...should be the Rovals and they set up perfectly.
    Roval 29, alloy disc, 26mm wide, 32h
    Specialized Purgatory Control, 2Bliss Ready, 60TPI, aramid bead, dual-compound, 29x2.3
    Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3"
    Best tires I have ever ridden on. I always thought my nobby nic's were outstanding (and they are good tires) but these specialized tires are a whole new level of grip.
    Curious that the LBS where I bought the bike recommended not to go tubeless. To be honest I have had so much fun getting to know my new bike that I never gave it much thought until now.
    Wink
    Quote Originally Posted by TiGeo View Post
    can't keep up with these postings, no sooner do I post one then I notice two more have been added!
    end of august this year I picked up my new 2013 Carbon Comp FSR 29 Stumpjumper which replaced my 1998 chromoly Norco Rampage. Three months on and I still cannot get enough riding done.
    There are six other bikes in between these two but they all belong(ed) to my wife and two kids.
    I like turtles
    Do it and don't even think about it. SO EASY with those tires...same ones that came on my Stumpy EVO 29 HT. Again, you should get some Stan's yellow tape (wide) b/c it is unlikely that they are taped with the Roval tubeless blue tape. Have no idea why a shop would caution against it...these rims/tire are made to do this.
    Reputation: Deep Thought's Avatar
    Sep 2012
    Quote Originally Posted by rockerc View Post
    I have to respectfully disagree. The advent of suspension is the best thing that ever happened to MTBing.
    High Desert MTBer
    Quote Originally Posted by Deep Thought View Post
    And I respectfully re-disagree! I used to ride often in the UK well before even a hint of usable suspension was available, and in the fall the farmers would cut back the hawthorn hedges that lined many of the tracks alongside farmland. These tracks were often the only route available to get to more remote trails, and I suffered repeated flats every time I rode these. One ride I actually repaired 7 punctures. Not 7 holes at one time, but 7 punctures on 7 separate occasions on one ride. This was a fu*king pain the arse. Suspension would not have helped! I would have taken tubeless over suspension any day back then...
    When I moved to AZ. I would get pinch flats and thorn punctures all the time, until I started running tubeless. Now issues with tires are extremely rare, and I can finally enjoy the benefits of the rest of the technological advances available to me, suspension being one of them!
    It's all Here. Now.
    Reputation: PerthMTB's Avatar
    At the risk of upsetting all the tubeless fans (dare I say zealots!) I just want to play the devils advocate here and say - it depends.
    If you run high enough pressures so that pinch flats aren't a problem (and from what you say above, you are), and if you don't ride where there's a lot of thorns to give you 'traditional' punctures, then tubeless may not be worth the hassle for you.
    If you read around this and other forums on the topic like those above suggest, you'll also find a litany of issues people have with tubeless conversions - incompatibility of rims & tyres, burping tyres, not being able to get beads to seat without use of a compressor, porous tyre walls, leaky rims, sealant degrading tyre rubber, sealant drying out, getting covered in icky white goo when you need to mend a puncture by the side of the trail, etc. etc. - you get the picture!
    Don't get me wrong, there are many benefits to tubeless (and confession: I run tubeless on 2 out of three of my bikes) but there are also disadvantages that I think you should be aware of before you make the leap, and at the end of the day, tubelss isn't right for everyone.
    High Desert MTBer
    Quote Originally Posted by PerthMTB View Post
    Fan yes, Zealot no! And there is something in what you say. I would add that you do need to make sure you run a good tire/rim combination to minimise issues with tubeless, and I do. I use Mavic wheels that are tubeless specific, with tires that are tubeless ready. This is no big deal to my mind, same way as I choose to run certain components that work better than others on my bikes. The style of riding I prefer requires lower pressures, I have a lot of sharp rocks and cactus here too, so tubeless is a boon for me. For me the pluses far outweigh the minor inconveniences of tubeless, and I do mean very minor. I have a 70 dollar compressor that works great on all my tires, when out on the trail I always carry a spare tube just in case, and if I burp as I have just once in 2 years, I can reseat the bead and reinflate using a CO2 thingy and a pump. As for getting covered in icky white stuff, I will leave it for someone else to comment, it has not happened to me yet!
    It's all Here. Now.
    Agree wholeheartedly that a lot of it is in the choice of rim and tyre. I run proper UST rims (Shimano) with Maxxis LUST tyres, and therefore manage to avoid most of the issues with 'ghetto' tubeless. For example, I can fit & remove my tyres by hand, never had a burp, and can even seat the bead with my mini-pump. I don't use goo either, and haven't had a leak or puncture (but then there's no thorn bushes or cakti where I ride). So, I'm actually a great fan of tubeless done right, but just wanted to give the OP a balanced view....
    Dec 2010
    Converted my 2013 Stumpjumper FSR Elite to tubeless last week. I had a hard time getting the yellow tape to seal the back wheel (yes, I cleaned the rims). Kept leaking everywhere (Roval rims that are tubeless ready with Purgatory and Ground Control tubeless tires). i also had trouble seating the valves.
    FInally, I said screw it and bought a pair of Stan's rim strips. They are rubber and have the valve built in. Technically you don't need them for a tubeless-ready wheel but they work perfectly and the tires inflated with just a floor pump.
    My hardtail Stumpjumper has Mavic Crossmax wheels. There are no spoke holes so you don't need a rim strip. These worked perfectly right out of the box.
    But in regard the FSR, I could feel an immediate difference on the trail. I think I dropped a quarter of a pound from each wheel and you can feel the decrease in rolling inertia. Bike seemed snappier.
    Nov 2012
    Just to throw it out there, if you are running high enough pressures that pinch flats aren't a problem....you are running too high of a pressure, and you don't know what you are missing!!
    the catalan connection
    Reputation: What&son's Avatar
    I did it mainly for lower pressure, less punctures and what also turned out to be a good weight saving too. Here's the thread, you might find some good info there:
    http://forums.mtbr.com/wheels-tires/...in-778158.html
    Cheers
    "Blessed is the man who, having nothing to say, abstains from giving us wordly evidence of the fact." George Elliot
    Sep 2012
    I suppose it's different for everyone, eh? To each his own. :cheers
    ...and at the end of the day, tubelss isn't right for everyone.
    And there is something in what you say...
    These are both great responses - honest and prudent.
    I, too, run tubeless on occasion (currently I only have one bike that's tubeless) but soon got tired of messing with sealant, installation, etc. So, I run tubes with sealant in them (for thorns). I've had less than 5 pinch flats in the last 7 years, and most of them have been on my road bike.
    I also run relatively low air pressures with tubes (sometimes as low as 25psi) and I weigh 220 - and I NEVER get pinch flats. My riding buddy, who we call "Captain Pinch Flat" gets them nearly every ride. I've even seen him get 2-3 in a day.
    He plows over stuff, and I don't. My riding style, derived from BMX, is very "light on the wheels" even at my weight. I ride a hardtail, and the rest of my bikes are rigid. I am not particularly slow, either.
    So, I think tubeless is a great option for those who feel they need it. I've been able to get by going tubeless or not.
    If you're flatting regularly, I would recommend it. There is a maintenance factor, but it isn't much.
    I like turtles
    Quote Originally Posted by Ailuropoda View Post
    Bummer - one other thing you can do if the yellow tape is giving you fits is buy a roll of the skinny (1" I believe) Gorilla Tape - works GREAT and will be lighter than the strip. You really have to clean those rims...I wasted nearly a roll of yellow tape before I really cleaned them with degreaser and rubbing alcohol and finally got it work. My buddy uses the Gorilla Tape to avoid the hassle. It just stink to have to use the rubber strip when your tires/rims are set up for not having to use it.
    meow meow
    Reputation: b-kul's Avatar
    you get to feel super accomplished that you have no tubes in your tires.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Quote Originally Posted by Schott View Post
    That also depends on the needs of the rider and trail. Me, I love tubeless and sometimes go as low as 15 psi (1 bar) for the cush and traction on my 29er. Others might not like the increased rolling resistance of pressures that low. Not everyone rides in a way that makes wheels hit things (with the tire in between of course).
    I do think tubeless offers benefits even at a little bit higher pressures, but IMO the lack of pinch flats with tubes isn't a surefire sign that the pressure is too high.
    High Desert MTBer
    Where I ride here it is pretty much impossible to ride without jamming into rocks and cactus, I love the super tech chunk, so fairly low pressures and flat resistance are mandatory for me. Horses for courses tho...
    It's all Here. Now.
    Nov 2012
    another Newb. question. new to the tubeless as well. I've read somewhere that the Stans only lasts a couple of months!!Do you need to break the tire down and clean the old stans out?? When you say add 2 scoops??
    Sep 2012
    Quote Originally Posted by DEA316 View Post
    This is true. Stan's will dry up after a few months and will lose its effectiveness in sealing punctures. I've been fine checking mine twice a year. I usually find that there is a little liquid left, and a bunch of boogers.
    Oct 2012
    It depends. Two months is the shortest time in the worst conditions. I've been fine every six months.
    It's not a huge effort to deflate the tire, pop the bead on the other side and check how the sealant looks like. When a "false morel" has developed, it's time to pour out the old sealant and put some fresh stuff in. Then put the bead back on, wipe the rim with a soapy sponge, inflate until the bead pops and you're back in the game.
    Poorly chosen rims and tires will be difficult to work on and the bead might not seat easily, but with proper stuff it's no biggie.
    High Desert MTBer
    2 months is about it for AZ I find. I actually just cleaned out and refreshed my Cannondale tires this morning. The Stans goes clearer and brownish after a time, at least what's left of it, but as Saul says, if you are set up well, it is no biggie to clear out the old and in with the new!
    It's all Here. Now.
    Reputation: JoePAz's Avatar
    May 2012
    I have been riding in Az since 1998. Back then the thing was thick tubes and slime inside the tubes. Work pretty good, but with the slime it was hard to deflate the tube. The slime would plug the valve.
    When I went to ligther bike I also chose to ditch the heavy tubes and slime. I have been using a tire liner and regular tube with no sealant. I still get flats every now and then, but mostly at home. I have changed only 3 tires on the trail. One due a pinch flat where I forgot to check the pressure before the ride. One due to my breaking off the presta valve. One was due to a thorn. If I get a flat at home I can change it quickly before the next ride. No mess just a simple tube swap. I keep a stash of tubes at home to always have one plus my trail kit spare before my ride. The liners do a good job of minimizing thorns in the main tread surface, but the sidewalls can still get hit from time to time.
    I would rather have 10 flats at home than 1 on the trail forcing me to walk home. One ride I ran into a rider who popped the bead on his tubeless. He tried to us my pump to reseat the bead, but failed. I run a 26er and was going the other way so I was forced to leave him to walk the 4 miles back. Just seems like alot more hassle trail side than the simple tube in tire method.
    I am 155lbs and run 35 psi on 2.25 nobby nics. Personally I like the tires, but thing their sidewalls are bit thin for running tubeless. I cut a sidewall on my last set, but with some duct tape on the the inside I got another 300 miles on the tire before I replace it due to general wear.
    Anyway some really love tubeless. I am fine with tubes.
    Joe
    '18 Specialized Epic 29", 19' Vassago Optimus Ti SS 29", '19 Ibis Ripmo, XC, AM, blah blah blah.. I just ride.
    High Desert MTBer
    Quote Originally Posted by JoePAz View Post
    Like I said, horses for courses... but, how do you get flats at home?!?!? I have to say that not only do I rarely get flats on the trail, but I can safely say I have NEVER had one at home!
    My biggest problem since going tubeless has been with tire sidewalls cutting, and that depends what kind of tire I am using. I have tried many different tires, and the worst have been Bontrager XR4s and 2s, I sliced 4 in as many weeks. Some are better than others, and I am cosntantly on the search for the best compromise! Right now I am trying Bontrager FR3s, and they are working out great so far. Sturdy sidewalls, good rolling resistance, and grippy as f**k on the rocks. They hook up really well in the softer stuff too, so I am very pleased with them up til now. Tioga Psycho Genius are quite good for a cheap option, they wear well and the sides are strong, but don't hook up so well in turns, and roll badly on hard stuff. There I go, turning this into a tire thread! Sorry...
    It's all Here. Now.
    May 2012
    Slow leak on the trail than only shows up as "flat" after sitting for a week between rides. I do most of my Mtb rides on the weekends so I can do quick squeeze test the day before the ride to see of I need to change tube or add some air.
    ... There I go, turning this into a tire thread! Sorry...
    That is one advantage of tubes. You don't need to have tire that seals perfectly. I have 24lbs hardtail and like to keep my tires in sub 600 gram range. I am not a weight weenie, but prefer lower rolling resistance and lower overall weight if given the choice. I ride mostly XC type stuff, but will ride anywhere too. So I don't want to run a heavy thick carcass tire. With tubes I can run a ligher tire and if gets chewed up keep riding. Have ridden some tires to the point were lugs are torn off and fabric cords are showing. I will keep riding it if does not slip too much on the trail and holds air.
    Anyway I am ok with tubes, but I realize that many just love the tubeless set-up.
    Joe
    no point having tubeless if your going to run higher psi than 30.
    Nov 2012
    Quote Originally Posted by bruce219 View Post
    I have to disagree, it also depends on where you ride. You could be running 40psi and still take a thorn. Tube go pop, tubeless go pss...gurgle, gurgle, psstssss...sealed.
    Reputation: 006_007's Avatar
    I think tubeless is great for those forced to live in climates that have thorns.
    Where I am I have tried tubeless, but went back to tubes as I swap tires around semi-frequently (yes, I am a gear whore, but not so much of a whore that I can have multiple tubeless wheelsets built up). Found swapping tubeless setups every few weeks a pain in the arse.
    With tubes, i run 28psi, weigh 185lbs, and I think i had one flat this year. But that could have been last year that I had the flat. What I am getting at is depending where you ride / what your needs are tubeless isnt the "greatest thing ever" for bikes.
    As people who ride in a cold climate if they would rather tubless, or disc brakes and see what answer you will get
    Nov 2012
    has anyone tried this sealant? truckerco-usa | eBay
    Kitty! Kitty! Kitty!
    Reputation: GelatiCruiser's Avatar
    Oct 2012
    Just reading this thread makes me realize that I *might* have my tires overinflated.
    The idea of running tubeless is mainly for more grip,if running high psi tubeless you don't take advantage of that.
    I like turtles
    The point of tubeless is flat prevention. Lower psi is a secondary advantage.
    Nov 2012
    Ah, the point for you is flat prevention. The point for ME was lighter weight and better traction through lower PSI. Different strokes for different folks, but lots of advantages to tubeless for sure.
    Oct 2012
    Not to derail this thread, but what do most people who run tubed tires inflate them to?
    Reputation: ghettocop's Avatar
    The clearest advantage for me was the much improved "feel" of the trail without tubes.
    @Gelaticruiser........ When I ran tubes I inflated to 38-40psi. Without tubes 25-27psi. I weigh 230-240 depending on the day.
    My 2-Bliss groundcontrols are labeled "35-60 psi"
    I guess "true" tubless tires can go lower...
    Thats just the tire manufacturers covering their @rse. My 'true tubeless' tires are labelled 30-60 psi too, but I run them as low as 20.
    Oct 2012
    Labeled ratings for my 2.35 29er Nobby Nics is 23-50 psi and the max recommendation for tubeless is 35 psi. I've gone as low as 15 psi without any trouble, just heaps of traction and plush feeling. This is not suitable for high speed cornering, though.
    High Desert MTBer
    Quote Originally Posted by 006_007 View Post
    Last time I checked, thorns grow in most climates... I can understand that tubeless could be a pain if you swapped tires all the time, like twice a day! but once in a while would not be much of a pain for me. There seems to be some mystique that tubeless is some arcane science and that it is a pain to set it up. I go to my garage and change tires in a few minutes. NO problem. With the right gear it is a cinch.
    I am not sure what you mean with your last comment about tubless (sic) and disc brakes?!? What has that got to do with the price of bread?
    It's all Here. Now.
    Dec 2010
    Am I the only one who uses tubes with removable valve cores? The point is that if you put a couple of ounces of sealant in the tubes you pretty much do away with flats negating one of the main advantages of tubeless tires.
    I converted strictly for a) Decreased rotational inertia and weight, and b) The coolness factor.
    High Desert MTBer
    But wait?!? I don't understand how using tubes AND sealant decreases rotational weight? Surely if you took out the tubes and went tubeless with sealant that is less weight, and WAY cooler, if that is indeed cool... or am I a meringue? (Reference: Scotsman in cake shop)
    It's all Here. Now.
    Oct 2012
    He said he converted [to tubeless] to reduce weight compared to the previous setup with tubes and sealant.
    Tubes with sealant gives you the puncture resistance. It doesn't give you reduced rolling resistance, weight and risk of pinch flats at low pressures.
    I never got many flats (could go through a season without any) when running tubes so it wasn't a factor for me. I just like the feel of tubeless when the pressure is low but the tire still rolls without a mushy feel.
    I have a 35km ride this weekend. I am going to convert to a tubeless set up and run 28psi as a starting point. I normally run 38psi with tubes.
    IF we get our ride in I'll feedback my impressions (might have some snow on the way).
    Thanks everyone for a somewhat lively discussion and lots of good advice!
    Nov 2012
    Make sure you are good and set up before venturing out on a long ride, sometimes it takes a couple of days for them to set up, sometimes they set up first time no problem. Don't forget that you will need to carry either a co2 blast to reseat if needed, and/or a tube in case of flat. Best of luck.
    toscano
    Guest
    Advantages?
    There are no advantages! With tubeless tires you use same tires on different situation, it is crazy.
    High Desert MTBer
    Quote Originally Posted by toscano View Post
    Advantages?
    Huh?
    It's all Here. Now.
    Nov 2012
    Advantages?
    Ass on shoulders.
    Rod
    Rod is online now
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by Dion View Post
    Great post - would rep you if i could
    Dec 2012
    pros: you can run lower pressure
    cons: not as easy to service in the field
    as far as thorn flats go, is there a big performance difference between tubeless with sealant and running tubes with sealant?
    High Desert MTBer
    Quote Originally Posted by johnluke View Post
    I don't think your pros are exhaustive enough! As for differences in thorn flat performance, I can only say that in 3 years of tubeless in the desert where EVERYTHING has a spike, I have never had a thorn flat.
    It's all Here. Now.
    I second rockerc's comments.
    I ride where there are blackberry thorns all over. With tubes I would get a flat every 10 or less miles on average. With tubeless, I have a problem once a year or less on average, which translates to about 100 20 mile rides or 2000 miles. That's 200:1 tube flats to tubeless flat ratio by mileage.
    the tubeless flat is often a bigger pain in the ass, but not nearly as much as the 199 tube flats I didn't get.
    Reputation: chas_martel's Avatar
    To be fair, the biggest benefit of a strict UST tubeless setup is the lack of hassles.
    Nobody cares...........
    I like turtles
    The people that have issues with tubeless are typically the ones running ghetto, or jury-rigged set ups. Get TLR tires and rims and you will ride 100% flat/issue free.
    High Desert MTBer
    My point exactly!
    It's all Here. Now.
    High Desert MTBer
    So, I posted this earlier:
    And I just saw someone gave me a negative rep comment saying "I hate thread creep"... What does that even mean?
    It's all Here. Now.
  67. #67
    Bicyclochondriac.
    Agreed. I have liked running tubless, but it has been pretty subtle improvement. I put a whole lot of things before tubeless.
  68. #68
    Bicyclochondriac.
    Nothing is 100%
    I got a sidewall puncture flat that would not seal last week.
  69. #69
    Dec 2012
    They are tube less.
  70. #70
    Dec 2012
    Quote Originally Posted by kapusta View Post
    Nothing is 100%
    You would have likely gotten the flat even if you had a tube.
    Much like a tube, most punctures (including sidewalls) can be repaired trailside if you have the right tools. Otherwise, just keep a spare tube.
    On average, one should have fewer issues running tubes.
  71. #71
    Bicyclochondriac.
    Quote Originally Posted by Knombrar W/AK View Post
    Of course I would have flatted with a tube. Do you think there was any doubt of this?
    My (very clearly stated) point was that tubeless is not 100% flat free. This was (also clearly) in response to someone saying that tubeless was, in fact, 100% flat free.
  72. #72
    Dec 2012
    Glad we cleared that up!
  73. #73
    I like turtles
    Nothing is 100%
    You are right, shouldn't have said 100%...more like 90% or so. You can certainly flat with tubeless..but my point was that the burping etc. issues you hear about are typically from setups that are less-than-ideal. I haven't gotten a flat in almost 2 years tubeless. I used to get at least 1 or 2 year running tubes.
  74. #74
    Bicyclochondriac.
    You are right, shouldn't have said 100%...more like 90% or so. You can certainly flat with tubeless..but my point was that the burping etc. issues you here about are typically from setups that are less-than-ideal. I haven't gotten a flat in almost 2 years tubeless. I used to get at least 1 or 2 year running tubes.
    Fair enough. Just did not want people to stop carrying that extra tube.
    I agree that not all tubeless setup are created equal. You need to do your research to see what will work best for you.
  75. #75
    I like turtles
    I still carry a tube and a tire patch just in case.
  76. #76
    I'm just messing with you
    Reputation: wv_bob's Avatar
    If it's like requirements creep I guess they mean when the thread grows beyond the scope of the initial post.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
  77. #77
    Bicyclochondriac.
    Some people are just d-bags. I doubt they had enough rep power to actually make a difference, neg rep tools seldom do.
  78. #78
    Moderator Moderator
    Quote Originally Posted by wv_bob View Post
    I hate people who think everything should run like the would like it too and lack the ability to filter or change the channel when their frustration level rises.
    I'm tempted to post a picture of a kitten or something just to derail the thread further.
  79. #79
    Oct 2012
    I just converted my Moonlander to tubeless and wrote up some weights I measured while I was at it.
    Front wheel w. disc and QR skewer, 1640 g
    Tube option 1:
    Surly rim strip: 107 g
    Schwalbe SV13F: 180 g
    Total: 1940 g
    The inner tube required a fairly high pressure to fill out the BFL on the Clown Shoe. While it was fine on the street, lower pressures caused the sidewall to dent at the valve and the tire would creep in the direction of rotation. Not good.
    Tube option 2:
    Surly toob: 440 g
    Total: 2187 g
    Ghetto tubeless setup:
    Clear packing tape and foam strip on rim: 19 g
    Schwalbe AV10D: 223 g
    Total: 1882 g
    I couldn't trim the split tube, because it was just wide enough to work as a rim strip, so the weight was left as is. The tire mounted with a floor pump without issues. The sealant isn't solid weight so it has less of an effect on acceleration. The weight of the new setup is closer to the center of the wheel, which has a positive effect on acceleration.
    So what does it feel like? Awesome! I've used smaller cogs than before and the rolling and acceleration seem much better. I don't care if it's all placebo because I don't race; if it feels good, it's all that matters. Compared to using Toobs I saved 600 grams minus the weight of sealant. To me that's a pretty good result.
  80. #80
    Bicyclochondriac.
    Quote Originally Posted by Saul Lumikko View Post
    Total: 1882 g
    How much sealant did that that take?
  81. #81
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    Plus some tire boot material for sidewall cuts
    Totally disagree, but this is one of those issues, like flats or clipless, which has no single correct answer and boils down to personal experience and preference
    Old enough to know better. And old enough not to care. Best age to be.
  82. #82
    Oct 2012
    Kapusta: no sealant was necessary, the setup sealed right away. Later I added some sealant, but it isn't solid weight so the effect on acceleration is reduced. Some people use sealant with tubes as well, so the weight of the sealant can be added or left out.
    Since I weighed the tubeless setup without sealant and I've never used sealant in tubes, the weight saved is "600 grams minus sealant".
  83. #83
    good advice!
    But I want to add that if you put a strip of foam beneath your rim strip, you probably can reinflate the setup with a hand pump. I figured this out (by reading other people's smart threads) for my fatbike and next time I redo my 29ers, I'll probably apply the same technique.
    At the cost of just a couple of grams for the foam, its very different seating a tire for its first time when with just a touch of water, the rim strip has enough pressure against the bead to allow you to casually inflate the tire. Deep channel in your rim getting you down? no worried now with this technique!
  84. #84
    Bicyclochondriac.
    So how much did you use?
  85. #85
    Oct 2012
    I'm not that exact with sealant. I use "so much" in any of my tires from road tubeless to 29er and now the fat bike. Maybe 2-3 small 2 oz bottles per tire went into the fat bike tires.
    To be honest I should have weighed the entire wheel + tire with the tube beforehand so I could weigh it now and tell you exactly how much weight I managed to lose going tubeless.
