Trick for keeping Gunk outta Housing?- Mtbr.com
Results 1 to 13 of 13
    Anyone have a good trick for keeping gunk outta your housing when riding in muddy/wet conditions? Aside from having full housing which isn't an option on my bike, I need to find a way to cover or seal the opening where the cable feeds through the ferrules. I've had to change my housing twice in the last month from riding in muck. getting frustrated!!
    Well you can get the Shimano cableset with their ferrules and rubber boots. The ferrules have an o-ring and hard rubber seal around the cable and on top of that a 1" long rubber boot attacheas in front of it to slow down gunk from even getting to the ferrule in the first place. You can ride cables with no maintenance for months. A lot of people complain that they add too much cable drag but that is truly BS. It is so little it doesn't matter especially when you consider it will keep running smooth for so much longer.
    Who are the brain police?
    Reputation: Locoman's Avatar
    Here's a getto trick..
    Quote Originally Posted by Eggman
    Personally, I try to avoid mud since the trails near me ruin easily. But I came across this link a while ago. Seems like this should do the trick if you're going for a ride where you know they'll be a lot of mud.
    http://www.utahmountainbiking.com/fix/mud.htm
    The Who - Glittering Girl
    Ween - The Grobe
    Yellowman - Strong Me Strong
    all your base are belong to us
    Quote Originally Posted by Locoman
    Cheap and effective but definately not an elegant solution
    Coors, the american beer.
    Reputation: Melt's Avatar
    duct tape fixes everything
    AZ has the best mountain bike gathering ever
    I wonder why somebody hasn't invented a product that mimics this duct tape method? I can picture some kind of rubber accordian/boot that attaches to the housing then clamps to the cable instead of just letting the cable slide into the accordian/boot. Know what I mean?
    Ween - The Grobe
    sweet
    i may actually try this, not pretty but i'm willing to sacrifice sexiness for not having to change cable/housing every couple weeks!
    my other option is full length housing with these "problem solvers". i use them for my hydro brakes and they work well.
    http://www.pricepoint.com/detail.htm...d=050%20PRMHB3
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Avid Flak Jackets
    Been using the same set of Avid Flak Jackets on my bike through 2.5 muddy Vermont seasons and they're still smooth as silk.
    Not bad for a $20 investment.
    question about the flacks
    i was just checking these out online and i'm curious to how exactly the red shield tubing works, or how it fits over the ferrules. could someone explain installation? especially in relation to the brake stops on a frame.
    Reputation: nwmtb's Avatar
    the housing end caps use a stepped down nose that has a tad smaller outside diameter than the red liner's inside ... you cut the red liner to length and everything slips together tightly. At the ends a boot is used to keep muck out.
    later, Chad
    http://redbarnbicycles.com/
    Reputation: mtpisgah's Avatar
    Goto a motorcycle shop
    Buy a gadget that they sell at motorcycle shops for cleaning out housing. It costs $10-15 I think. You loosen the cables and slip it on the housing. Then you attach an aerosol cleaner like triflow and shoot it through the housing. It blows all the gunk out. I usually do this a couple of times a year and then replace the housing one a year. Some will say that this method just attracts more gunk but I don't think it does and it is better than replacing the housing all the time.
    Lotta companies b makin cable and housin sets for ridin in the chump ass mud.
    Jagwire, Shimano, and Avid makes some boots you can use foo, and some even have sheaths that cover the whole punk ass cable sucka.
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    Ditto
    Avid Flak Jackets and then for the ultimate in protection I put some rubber cemment on the ferrule/housing interface and put shrink wrap tubing around the ferrule (sp?) cable interface. 2 michigan seasons and nothing but grins.
  1. Avid mechs - housing question / problem...
    By DSR in forum Brake Time
    Last Post: 03-03-2004, 12:29 AM
