Trek marlin 5 2021 vs Merida big seven 20md..which one is the winner?- Mtbr.com
Results 1 to 2 of 2
    Jun 2020
    I'm really curious on how this is going to turn out. This is the best 2 budget mtb under $600 or 36k INR. Pls share your opinions on this
    Trek Marlin 5 2021 Merida Big Seven 20MD 2020
    Frame Alpha Silver Aluminum Aluminium,27.5" wheelsize,
    135x9mm axle standard
    Fork SR Suntour XCE 28, coil spring, preload, 42mm offset for 27.5'' wheel, 100mm QR, 100mm travel SR Suntour XCM HLO,
    Coil,
    100mm travel with lockout
    Brake Tektro HD-M276 hydraulic disc, short reach lever Promax MTD-3.0 disc, with Shimano RT10
    Rim Bontrager Connection, double-wall, 32-hole, 20mm width, schrader valve Merida CC,
    17mm innerwidth
    Tire Bontrager XR2 Comp, wire bead, 30 tpi, 27.5x2.20'' Merida K1080
    Shifter Shimano Altus M315 Shimano ST-EF500
    FD Shimano Tourney TY300, 34.9mm clamp, down swing, down pull Shimano FD-TY700
    RD Shimano Tourney TY300, long cage, 34T max cog Shimano RD-M360
    Crank Shimano Tourney TY301, 42/34/24, 170mm length Shimano TY301,
    170mm,
    42-34-24T
    BB VP BC73, 73mm, threaded cartridge FSA TH-7420ST-W, Cartridge Bearing
    Cassette Shimano HG200, 12-32, 7 speed Sunrace CSM668,
    11-32T, 8 speed
    Chain KMC Z7, 7 speed KMC M700
    Weight 14.44 kg 15.3 kg
    Dec 2013
    Where does the Suntour XCE fit in the hierchy of Suntour suspension forks?
    Nothing is coming up on the web searches.
    Low end is XCT then its XCM then XCR is the "Higher" end still not that great XCR, but better then XCT.
    I'd go with Merida Big Seven 20MD 2020 because it has XCM, thats only if XCE is at the same level as XCT. Plus you get an extra speed in the back.
  1. Opinion of Merida BigNine 20MD?
    By thekiloohm in forum 29er Bikes
    Last Post: 05-15-2017, 11:55 PM
  2. GT SPORT vs. MERIDA 20D vs. MERIDA 40MD
    By griwulf in forum Beginner's Corner
    Last Post: 03-20-2016, 03:52 PM
  3. GT SPORT vs. MERIDA 20D vs. MERIDA 40MD
    Last Post: 02-22-2016, 09:32 AM
  4. Replies: 3
    Last Post: 01-07-2015, 10:16 AM
  5. Merida Big Seven
    By Kristinka in forum 27.5
    Last Post: 02-10-2013, 02:34 PM
