Is this too much of a stretch- Mtbr.com
Results 1 to 7 of 7
    Feb 2006
    I have this tiny aluminum I think scandium frame given to me that I'm going to build for my lady friend.
    Just for shitz and giggles I put a 28h bonty 135mm rear hub I had laying around. It didn't seem to put undo stress on the stays.
    What's the consensus on using this hub? -Jerry
    Reputation: gabe's Avatar
    Measure it up and post the difference between the frame and the hub..............then you will find out.
    "Roll your own......." Smokebikes.com
    HIYAH
    Reputation: heeler's Avatar
    Quote Originally Posted by Jeromelo
    This question would make alot more sense if we knew the rear spacing of the frame...
    TTHHHHHHHHHPPPPPPPPPTTTTTTTTTTTTTTT
    pvd
    pvd is online now
    Reputation: pvd's Avatar
    ...that I'm going to build for my lady friend.
    That is assembly, not building.
    Feb 2006
    What???? Can't you guys read my mind?
    Sorry 'bout dat...road frame...130mm spacing.
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    there is probably a spacer on the hub that you can remove to space it back to a road length, although now that I think about that you would probably need the 130mm road axle too.
    You should be OK with the spreading. if it was the old 126mm road standard that is a lot to spread the stays but 2.5mm per side is not and issue.
    I would check to make sure that one side isn't doing all the spreading though. Could make the bike handle funny, like it is out of alignment.
    MTBR Posting Guidelines
    calories>electrons
    Feb 2006
    Sure I'll throw on a mtb rear wheel without the skin and see how it centers up.
