Swapping frame for larger size with longer head tube - is that a deal breaker?- Mtbr.com
Results 1 to 9 of 9
    I wanted to try swapping out my 2011 pitch pro medium frame for a Large of the same year- keeping all the same parts.
    However I just noticed that the "head tube height" jumps from 108mm to 128mm on the large size.
    This means I'd need a new fork right?
    Reputation: J.B. Weld's Avatar
    It depends on how many spacers you have on your current one.
    3 spacers, (2 below the stem and 1 above), I tried measuring them with a tape measure in 16ths of an inch, they are maybe 5mm each. So 15mm total. Still 5mm shy.
    You might be able to lose a few more millimeters by replacing your stem with another one that isn't as tall (the part that clamps on the steer tube). Also a headset with a shorter stack height may be an option.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Lower stack stem will be the easy route for sure. You might want a shorter stem with the longer frame anyways.
    If it's just a couple of mm short of optimum, it's not that bad especially with metal steerer tubes. If you have a carbon steerer, it should actually poke through the stem and it is advisable to have a spacer on top of the stem.
    Reputation: TwoNin9r's Avatar
    Jan 2011
    Is your stem pointed up? Flip it
    Something just occurred to me, so I am going for a larger frame mostly for the reason of feeling like my legs are too long in the medium size. I have a disproportionately long inseam and figured with a size larger, along with a shorter stem, the Large size would likely fit me perfectly.
    On the specialized geometry chart, the Large has a stack height 20mm more than the Medium.
    Since the fork size is always the same for the 26" wheels and the bottom bracket height stays the same through all sizes, this added stack height is obviously all found in the additional head tube height.
    So by removing spacers and possibly using a shorter (in height) stem to accommodate my fork... I basically return to the medium size "Stack" height.
    Reputation: RS VR6's Avatar
    If you have a tall cap. You can always try a shorter one.
    Swapping frame for larger size with longer head tube - is that a deal breaker?-img_20151018_131335.jpg
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Nothing wrong with laying a 5mm stem washer above the stem itself: it's totally stable and may help the fork's resale value(slightly).
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Replies: 18
    Last Post: 10-13-2012, 06:27 PM
  3. Acceptable frame modification? (Reaming seat tube to fit larger post)
    By iamkeith in forum Vintage, Retro, Classic
    Last Post: 11-16-2011, 10:35 PM
  4. Head Tube size on Cobia
    By yeahdog31 in forum Trek
    Last Post: 06-01-2011, 10:56 AM
  5. Tubing size for head tube
    By henrypig in forum Frame Building
    Last Post: 04-11-2011, 05:15 PM
