Results 1 to 7 of 7
    suspension air pump recs?
    I'm probably going to buy a ShockWiz to help me analyze and tweak my mtb suspension:
    https://www.quarq.com/shockwiz/
    So I'll need to buy a suspension air pump in order to adjust my suspension accordingly. I currently have a RockShox Pike on the front and a Fox Float on the back. Do all makes/models of forks and shocks generally use the same type of air valve? Are there any suspension air pump favorites among forum members here? For example, when I was looking for an air pump for my tires, the Joe Blow Sport seemed to be a forum favorite and I've been happily using that for 2 years now
    Oct 2018
    Same question from last week -these answers should get you started.
    https://forums.mtbr.com/shocks-suspe...p-1093842.html
    And yes, any suspension pump will do the trick. As long as the pressure ranges meets your requirements.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah. Suspension air pumps are designed so that no air is lost from the suspension when you disconnect the pump as the air chuck on the pump ensures the shock or fork valve closes before air escapes. The air you hear escaping is coming from the pump and hose, not the shock/fork. Of course you'll see this with the ShockWiz as it will read the same pressure after you disconnect the pump.
    You need a shock pump irrespective of using a ShockWiz. The SWiz is OK, but you need to understand and experiment with shock and fork settings either way. A bunch of us here (all experienced riders) tried the SW and thought meh. It didn't change anything in the way we set up and used our suspensions.
    Do the math.
    100% PRIME ALBERTA BEEF
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by Lone Rager View Post
    ...A bunch of us here (all experienced riders) tried the SW and thought meh. It didn't change anything in the way we set up and used our suspensions.
    For my bikes, it was a bad rabbit hole. The suggestions were way too soft and marshmallowy. For my daughter’s bike, using the SW was great to at least get her in the ball park, when she wasn’t able to give me accurate feedback to set it up manually.
    OP - there are countless threads on here related to your questions. I think the consensus, for digital pumps at least, is to buy the cheapest one you can find that looks like the Fox or RockShox one (which are the same except for decals), since all these pumps are manufactured by the same company.
    Nov 2017
    I'm curious about the folks who didn't like the Shockwiz. How did its recommendations differ from what you eventually preferred - too little LSC, too little damping, etc?
    since 4/10/2009
    Reputation: Harold's Avatar
    Shockwiz is probably best for folks who are new to suspension adjustments, tbh, or have several bikes with different settings and want to keep it all straight.
    For someone with a single bike, it's probably best used as a rental tool.
    I've never cared much about the shock pump I'm using.
    I think this is the one I'm using now.
    https://www.jensonusa.com/Buzzys-Pol...SABEgK_pfD_BwE
    I had one of these for awhile. It came with a fork that I bought aftermarket, but it rusted in my pack pretty quickly.
    https://www.amazon.com/RockShox-High...02651880&psc=1
    There are now 4 bikes with 4 different forks, and 3 different rear shocks in my garage, though. One of those forks doesn't play nice with the shockwiz (MRP Ribbon, in particular the ramp cartridge), and one of them has a PITA fork setup (Wren). I need to keep better records of the suspension settings on all of the bikes. I've thought about a digital shock pump for shop use, and just save the hand pump for emergency trailside/trailhead adjustments. I worked at a shop that had a Lezyne digital shock floor pump and it was great to use.
    https://www.lezyne.com/product-dpump...p#.XCEOOlxKiUk
    poser
    Reputation: langster831's Avatar
    Feb 2005
    I've been using a specialized brand pump, it works great, doubles as a portable tire pump. The only thing is it max's at 220psi but my rock shox rear shock calls for something like 250/275 psi. Not much of a big deal though, since I've just been running my rear shock at 180psi.
  1. Pump Pump Pump Pump POP!!!!!!
    By prowlus in forum Scott Sports
    Last Post: 06-25-2011, 05:34 PM
  2. Changed Recs on DHX air Boost Valve?
    By Reek in forum Shocks and Suspension
    Last Post: 10-13-2008, 01:04 PM
  3. Replies: 3
    Last Post: 08-18-2007, 07:31 PM
  4. Rohloff w/ Full Suspension XC Frame Recs
    By BOHICA in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-06-2007, 02:11 AM
  5. Tire air pump vs.shock air pump -- difference?
    By Creelove in forum Shocks and Suspension
    Last Post: 09-10-2004, 06:28 AM
Members who have read this thread: 40
