Summer Weight Base Layer- Mtbr.com
Results 1 to 10 of 10
    When I ride in cooler weather I wear either a long sleeve or short sleeve base layer which keeps me warmer. In hotter weather will wearing a light weight sleeveless base layer keep me cooler? Generally, more layers means warmer, but I've lately read that the summer weight base layer can be cooler. Have any of you tried these summer base layers?
    Colorado
    Reputation: ltspd1's Avatar
    Nov 2007
    I've tried it, but the concept of wearing more clothes in hot weather in an attempt to stay cool has never worked for me. That said, I know some guys who swear by it.
    Reputation: d365's Avatar
    Depends on your climate. Works much better, the lower the humidity is. Around here, where 90% humidity is the norm in the mornings and afternoons... it's just an extra layer of wet blankets IME.
    Reputation: JoePAz's Avatar
    May 2012
    In Arizona some riders like sun sleeves. These are white sleeves that are supposed to breath well, but keep the sun off your arms. They sort of look like arm warmers. I have never tried them. For me it just chamois and short sleeve jersey and that is all. However I try to avoid the peak heat of Az summers so rarely ride after 8:30 am in the summer or before dusk. Still we are already in the low 80's right now.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '19 Ibis Ripmo, XC, AM, blah blah blah.. I just ride.
    Tee shirt, 1 wicking shirt in hot weather.
    Diggity Dog
    Reputation: ShinDiggity's Avatar
    Silk
    Reputation: upstateSC-rider's Avatar
    I wear base layers year 'round, just some Target-brand wicking SS in the summer even when it's 95 degrees plus.
    My jerseys aren't skin tight so the base layer helps with sweating by wicking away moisture, and when crashing, lets you slide more. At least on the road.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    Technical T-shirt only. Two layers seems like asking to get too hot.
    95 to 115 with heat index here in summer…humidity is a killer...I wear a dry-fit type shirt only.
  1. Great wool base layer package
    By eugenemtbing in forum Where are the Best Deals?
    Last Post: 11-24-2013, 05:25 PM
  2. Merino Base Layer Bundle from On-One
    By lubes17319 in forum Where are the Best Deals?
    Last Post: 11-24-2013, 08:36 AM
  3. Best sleeveless base layer for the Front Range?
    By GRAVELBIKE in forum Colorado - Front Range
    Last Post: 05-24-2012, 11:11 AM
  4. Good base layer shirt
    By bank5 in forum Apparel and Protection
    Last Post: 01-11-2012, 11:47 PM
  5. Base layer wind vest
    By FatTireGoose in forum Apparel and Protection
    Last Post: 11-21-2011, 10:29 PM
