Sticker residue- Mtbr.com
Results 1 to 20 of 20
Thread: Sticker residue
    Reputation: soontobe29er's Avatar
    Oct 2010
    Sticker residue
    What's the best thing for removing sticker residue ?
    What kind of bike do you have?
    A Sledgehammer.
    Dang! You got shocks, pegs...lucky! You ever take it off any sweet jumps?
    Mountain Dew enthusiest
    Reputation: alex55's Avatar
    GT-85 or WD-40. spray it at the residue and rub with a rag. That's what we do at my shop
    wishes Iowa had mountains
    '11 Transition Bottlerocket frankenbuild
    '09 Origin-8 Interrogator frankenbuild
    '80 Rumme
    Lighter fluid works way better than WD-40
    Reputation: Steve121's Avatar
    Methyl alcohol.Cheap to buy and safe on any surface.We use this all the time to remove stripes on expensive cars like ferrari and Lamborghini after car shows.
    Life is short-Live it full throttle !!
    Reputation: nachomc's Avatar
    Goo gone
    :wq
    Reputation: terraslug's Avatar
    In addition to any of the above mentioned, I've had god luck using a hot-air blow dryer on the glue residue, first, to soften it.
    Hissatsu Jitensha-nin
    Reputation: longfinkillie's Avatar
    Jan 2011
    Goo Gone as said before, but I also use Ronson's lighter fluid for those impossible jobs.
    Reputation: Justin Credible's Avatar
    baby oil
    60% of the time ......it works all the time
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    80-grit
    Honestly... ahh I give up
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by Justin Credible View Post
    baby oil
    Anybody ever wonder how you extract oil from babies?
    ronbo613
    Guest
    Isopropyl alcohol or Goof Off
    Reputation: 3034's Avatar
    lacquer thinner
    Gasoline
    Quote Originally Posted by soontobe29er View Post
    I've found rubbing alcohol not strong enough to break it down & industrial lacquer thinner too strong melts the sticky residue into a monkey snot substance.
    Gasoline on a rag (in a well ventilated area) turns the sticky residue into the stuff like they use on magazines or glossy mailers, rolls right off.
    Legend
    GooGone works well if it's the right consistency "goo". If it's too sticky (like, the crap left behind by crap duct tape), using a rag with rubbing alcohol then rubbing in 90 changes. "Smear" the goo one way, smear it again 90 ... comes off superfast. I had to clean a ton of whiteboards for the schoolboard one fall, the smearing method was the only thing that worked.
    meow meow
    Reputation: b-kul's Avatar
    goof off is where its at.
    Reputation: marpilli's Avatar
    Another vote for 'goof off'. Hasn't let me down in years.
    Reputation: Thatshowiroll's Avatar
    Jan 2009
    Simple Green for all.
    Reputation: chris1911's Avatar
    I use goo gone or WD-40. Goof Off is too aggressive, depending on what you are using it on.
    i also unicycle
    i've had goof off take off pant or haze clear coats. if you think you need something that strong, be careful. when you need it though, holy cow does it work wonders.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    BM and PQ Trail Rep
    Reputation: bankerboy's Avatar
    Angle grinder. Removes everything every time.
    The world does not revolve around you but your actions impact us all!
