SRAM XX BB30 or GXP for BB90 BB ???- Mtbr.com
Results 1 to 6 of 6
    Sooz
    Reputation: sooza's Avatar
    Feb 2012
    I have a Trek TopFuel 2011 9.9 with a BB90 BB (bearings installed in frame). I recently purchased a SRAM XX BB30 crank off eBay and have since discovered the BB30 will not fit in my frame From what I can research, it is the SRAM XX GXP crank that I need. I would appreciate it someone would confirm this.
    Yes, you need the GXP crankset. You will need the Trek BB for GXP.
    http://forums.mtbr.com/trek/trek-bb9...ms-776481.html
    Make sure you research this - looks like the Top Fuel takes a special BB, something about a narrow Q-factor. The Enduro page has a warning:
    FRAMES THIS KIT WILL NOT FIT:
    --Trek mountain frames with BB90 bottom bracket shells.
    (Top Fuel Carbon and Hardtail Carbon)
    The joy of ski is Yours
    Reputation: Haint's Avatar
    IMO this batch of BB experimentation is nothing outside of a disaster for Mountain Bikes. There's even a BB with 1/2 of a mm as a standard - 89.5mm. Unless that's just been called BB90, but really - 68/73mmm and 83mm is what goes the distance, new and used.
    I like Sand - I don't like Witches
    Mar 2013
    Put a mountain biker in a room with 2 bowling balls and we'll break one and lose the other - GelatiCruiser
    Sooz
    Feb 2012
    Quote Originally Posted by Slash5 View Post
    Thanks Slash. I ordered a SRAM XX GXP crank and the correct Trek BB for GXP. All done now and back on the trail. Thank-you.
    Sooz
    Feb 2012
    I am not sure what you mean.
  1. SRAM BB30 Spacers?
    By ALS650L in forum SRAM
    Last Post: 08-30-2013, 08:27 PM
  2. SRAM BB30 Spacers?
    By ALS650L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2013, 05:45 PM
  3. BB30 frame with Shimano BB90 XTR crank. HELP!!!
    By eduluke in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2012, 07:02 AM
  4. SRAM X9 BB30 Loose
    By J3SSEB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-24-2012, 06:38 PM
  5. SRAM XX ring GXP vs BB30
    By Rich24 in forum SRAM
    Last Post: 01-09-2012, 01:43 PM
