Results 1 to 22 of 22
    spacers under head tube
    i'm thinking about taking the spacers off between the top of my head tube and my stem and moving them between the fork and the bottom of the top tube on my 4300 to make the frame feel bigger. anyone try this before? thoughts?
    If I understand you correctly, you can't do that.
    On top of the fork is the headset race that sits firmly on a widened spot on the steer tube. The headset race sits against the bearings on the bottom side of the headset. You can't put spacers under the race, and you can't put spacers on top of the race.
    Will not work do not try. Period
    Don't listen to those other guys, make sure you post pictures when you're done.
    Reputation: HighLife420's Avatar
    is he not talking about moving the headset spacers from top of the stem to the bottom?
    I know you have to have at least 5mm spacer on top of a carbon steerer.
    Ive took some spacer from the bottom to bring my stem down a bit.
    Unless im understanding him incorrectly.
    Reputation: Slee_Stack's Avatar
    Quote Originally Posted by HighLife420 View Post
    Is 'under head tube' in the title not descriptive enough?
    Yeah, you can do what you said, but that's not what he said.
    Quote Originally Posted by Slee_Stack View Post
    It is, but when you read it, it kind of sounded like he meant the spacers...was just checking as to what he exactly meant =)
    He wants to put the spacer between the frame and the fork...which, you obviously cant do.
    Sorry for the mixup.
    check your six
    Reputation: sodak's Avatar
    OP- From what I gathered from your post, you cannot put a spacer under the headtube / on top of the race. However, if you are trying to make the cockpit feel bigger, then I would suggest adding a spacer or two BELOW your stem. That is if your steer tube on your fork is long enough to permit this. This will raise your stem up a bit giving you a taller feel to the bike. Other than that, you could possibly get a longer stem, which will extend your reach slightly making the cockpit longer. Ohh, and you can slide your saddle back on the seat post giving you a few millimeters too.
    "We can always find excuses if we want to find them, but if we really want to do something, we have to just go."
    Fat-tired Roadie
    Nov 2007
    You CANNOT put spacers under the head tube. The bottom cup of the headset has to fit snugly in the head tube, and the steer tube of a fork is a little broader at the bottom to fit the base plate of the headset. There's no safe way to change these relationships.
    I was about to shoot my mouth off about a specific product that addresses the problem safely, but I realize I don't know what kind of headset is on a Trek. Cane Creek makes a version of their S-3 with a taller bottom cup, that would do that for a bike that takes a conventional 1-1/8" threadless headset, and Real World Cycling distributes a bottom cup for bikes with internal headsets and 1-1/8" steer tube forks.
    HighLife420 talks about doing something that's safe and pretty common. If you just want the bars higher, and you don't also want to mess with the head angle, that'll do it. You need to have more spacers above the stem for that to work, of course. You can also flip up the stem, get a higher-angle one, get riser bars, etc.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Quote Originally Posted by Ray Pinpillage View Post
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    You MAY be able to get a taller crown race. Chris King for one makes a 10mm crown race, up from the stock 5mm race.
    But the CK race won't work with most other headsets such as Cane Creek, FSA maybe uses the same bearing chamfer angle? I just don't know.
    "...like sex with the trail." - Boe
    you can look for a headset with a bigger stack height but putting the spacers under your stem would be a cheap and easy fix.
    this has a super tall stack height of 35mm but is only 1.5"
    Reputation: Flat Ark's Avatar
    There is a bmx "flatland" company out of Japan named Ares Bikes that makes a spacer/extended headset for bikes with 1-1/8" head tubes. Their U.S. website "was" www.aresbykesamerica.com but now it looks like that U.S. store/distributor is gone. I don't think that's really what you are needing though.
    Can you post a photo of your bike? Maybe after seeing a photo it will be easier to offer a possible solution. Kind of sounds like you either need a longer travel fork or a new fork with a longer steerer tube. You just want your handlebars "higher", correct?
    Reputation: Lurchlee's Avatar
    +1 to this, I can't wait to see this monstrosity
    May 2015
    It can be done. Specialized uses a 10mm machined aluminum spacer between the fork crown and the bottom cup of the headset on their Stumpjumper FSR Expert Carbon EVO 27.5 (See review on pg 43 of Aug 2014 issue of Mountain Bike Action mag). It gives you an effective head tube angle about 1 degree slacker. Not sure if such a piece is available after-market or if a Specialized dealer could order the part in for you, but it is not impossible.
    Reputation: Gasp4Air's Avatar
    DELETE - totally missed the date. Zombie thread ate my brain, I guess.
    Use it, use it, use it while you still have it.
    Turns right to go left
    Reputation: 410sprint's Avatar
    Oct 2012
    Eight year old zombie tread.....
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by element_rider View Post
    You necro'd a 7+yr old thread for that?
    Reputation: dbhammercycle's Avatar
    Klatu barada nananana/necktie/necro'd...
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Reputation: Coal-Cracker's Avatar
    May 2010
    Quote Originally Posted by dbhammercycle View Post
    Sent from my SM-N960U using Tapatalk
    Magically Delicious
    Reputation: Cleared2land's Avatar
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. Lefty Steer tube too short for head tube, what are my options?
    By XC Dawg in forum Shocks and Suspension
    Last Post: 10-22-2009, 02:51 PM
  2. Replies: 11
    Last Post: 06-22-2009, 01:56 PM
  3. Headsets with spacers below head tube?
    By mattbryant2 in forum General Discussion
    Last Post: 06-10-2008, 04:48 PM
  4. Spacers For Prophet Head Tube
    By mzungo in forum Cannondale
    Last Post: 03-25-2007, 10:49 AM
  5. steer tube spacer under bearing race/head tube?
    By HuffyMan in forum Shocks and Suspension
    Last Post: 10-31-2006, 10:24 PM
Members who have read this thread: 92
