Results 1 to 37 of 37
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Side loading Cage With Slotted Mounting Holes
    As the title says I'm looking for a side loader that fits close to the frame and has slots so it can clear my shock and maximize bottle clearance. What's out there?
    PS, I hate losing bottles.
    I got some bad ideas in my head.
    Reputation: JoePAz's Avatar
    May 2012
    I have been happy with Specialized zee cages. So happy I put them on all 3 of Mtn bikes. And they have slotted holes. 42 grams and you can put a little SWAT tool under them.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    I don't know what you mean by "slots to clear the shock" but Specialized Zee cages are great side-loaders.
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    https://www.arundelbike.com/
    best of the best
    Making shit harder than it needs to be isn't awesome, it's just...harder.
    Anytime. Anywhere.
    With slotted mounting holes the position of the cage can be fine tuned.
    Nat
    Nat is online now
    Quote Originally Posted by Travis Bickle View Post
    It's right there in your title. D'oh.
    sbd
    sbd is offline
    Have a Zee as well. Never launched a bottle. Right or left available. Light. Reasonable price
    Sent from my Moto Z (2) using Tapatalk
    Self Appointed Judge&Jury
    Oct 2000
    Shouldnít this thread be moved to the components forum?
    Reputation: RustyIron's Avatar
    Like Alex said, Arundel is the best.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    I'm using the Spec. Z as well and it allows me to use a larger bottle in my tight frame. Also holds my bottle much tighter that conventional cages.
    Why Johnny Ringo, you look like someone just walked over your grave.
    Nat
    Nat is online now
    I have an Arundel side loader that I was using before switching to the Zee. The reason I switched is because the Arundel loads at an oblique direction whereas the Zee loads directly sideways. My frame has a very tight fit and that oblique loading angle made the bottle trickier to insert or remove, so that's something you'll want to take into consideration. I can't really say that one is of higher quality than the other because they're both just simple pieces of plastic without moving parts. They both work.
    Jan 2009
    what a waste of space! i can't believe we don't have a Bottle Cages forum.
    May 2012
    Zee cages also holds open beer cans too.
    Joe
    100% PRIME ALBERTA BEEF
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Quote Originally Posted by JoePAz View Post
    Critical.
    /Thread
    If the Spesh fits and you arenít worried about bad karma from using anything from the sinister Big S, I would go with it. Cheap, light and it works.
    Mar 2015
    ***whoops***
    Quote Originally Posted by mtnbkrmike View Post
    Critical.
    /Thread
    Thus, my dilemma. Although mine was a gift from a friend.
    lezyne flow right hand side load- works well for me
    2015 Santa Cruz 5010 C
    Anytime. Anywhere.
    I was going to but it's list didn't include bottle cages, which are clearly an accessory.
    Sent from my LG-H812 using Tapatalk
    Anytime. Anywhere.
    Looks like I may have to sell a bit of soul and go with S
    Jan 2009
    https://www.youtube.com/watch?v=Gxw6L0QmPF4
    Seth's Bike Hacks bottle cage smeasher.
    Jun 2013
    Lezyne side load cage. You can use a dremel to slot the bottom hole more.
    Oct 2000
    Not to go off topic from side loading cages, but I recently picked up a Camelbak insulated water bottle that is the best bottle Iíve ever had. And Iíve had numerous ones. Itís a bit longer than most and holds a little more. The fluid stays cold throughout a 3 hour ride due to the insulation. And itís got a nice locking dial on the drinking spout instead of the old pull push design.
    Side loading Cage With Slotted Mounting Holes-04a465fe-fd6c-4005-bd07-9583e05188f6.jpg
    Side loading Cage With Slotted Mounting Holes-3fbd3d43-48c2-42a7-85ed-fe3125a392d8.jpg
    https://www.merlincycles.com/camelba...SABEgLXg_D_BwE
    May 2012
    I use the Podium Chill in my Specialized Zee cages. The dial on the top goes from open to closed, but the nice thing about "open" is due to the bite valve does not let water out unless you squeeze.
    Joe
    Podium chill is my go to bottle too
    Anytime. Anywhere.
    The one thing I hate about Podium bottles is that the spout holds a lot of mud. I have a couple on the way with mudcaps so they should be good for winter. I may try an insulated bottle if it keeps the water warm for a couple hours. In the summer I don't care if the water gets warm, but I hate cold water when it's cold out. The last couple of years I have been pouring warm water in the bottle and carrying it in a bib short pocket.
    It looks like Cannondale makes a cage similar to the Zee. https://www.cannondale.com/it-IT/Can...7-228fe777d5b6
    May 2012
    Here in Phoenix for summer rides I will freeze a bottle solid. Then take it for a ride and let it melt on the ride. Nice to have ice cold water when riding on 105F temps. When it is just "warm" out I fill with ice and then add water for the same effect.
    Joe
    Oct 2015
    +1for Zee cage I drilled holes in mine up higher to mount it lower.
    Anytime. Anywhere.
    I picked up a Zee cage yesterday and it fits perfectly. I like how the underside is flat and sits close to the frame which maximizes space.
    Mar 2015
    I will see you in hell. This time, you're buying
    sbd
    sbd is offline
    Satan makes a good bottle cage.
    ninjichor.com
    Reputation: ninjichor's Avatar
    Jul 2018
    The Lezyne Flow cage doesn't hold bottles that well in any config other than top of downtube. Ejects from vertical seat tube mount and ejects from under the downtube. Lost a 22 oz Purist bottle a few rides ago from a vertical ST mounted Flow cage (left hand, which is right handed for this position). It held the bottle when it was full, but when it was about 25% full, somehow the bottle squeezed out the side.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    awesome strap...
    Reputation: thecanoe's Avatar
    Santa Cruz Tallboy
    Moonlander
    Jul 2017
    The podium dirt series will solve that issue. But Iím not sure if they have a chill version. Alternatively, get their mud cap (the podium dirt series simply adds the mudcap by default) - problem solved!
    Oct 2000
    Quote Originally Posted by Shadow4eva View Post
    It has mud flaps? I could have used a mud flap after a short bout with the flu last week.
    Anytime. Anywhere.
    I ordered a couple of mud cap bottles from Merlin because I could not get them locally. The Zefal cage looks good, but is spaced much further from the frame than the S Zee. The Zee makes the best use of limited space from what I can gather.
    Jul 2017
    I said mud caps
  1. Side loading water bottle cage
    By 06whitetaco in forum Endurance XC Racing
    Last Post: 04-05-2016, 07:47 AM
  2. Replies: 3
    Last Post: 01-13-2015, 08:47 PM
  3. Any ideas for low profile/side loading bottle?
    By Axe in forum Nutrition and Hydration
    Last Post: 06-09-2012, 01:57 PM
  4. Profile crank bearing side loading?
    By TXPhisher in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2008, 01:19 PM
  5. 36 holes hub on 32 holes rim
    By polpan in forum Beginner's Corner
    Last Post: 07-15-2004, 07:59 PM
Members who have read this thread: 108
