Replacing grips...simply impossible?- Mtbr.com
Results 1 to 56 of 56
    Vitamin Bike Added
    Reputation: MTBCanuck's Avatar
    I removed my lock-ons and bought some standard grips (just with different ergonomics to try). I can't get them on in any kind of satisfactory manner. I tried the hairspray thing but the stuff never seems to dry and the grip just keeps spinning on the bars. I tried alcohol but that won't seem to dry either, even with inserting a few zip ties to help airflow between the grips and the bars to help dry it out. Placing the grips on dry just doesn't work as I can't get em on. Anyone have any tips for placing standard grips with something that can actually dry? Any way to get them on without some kind of product/additive (heating etc)? I've given 12 hours of drying time to all the things I've tried so far with no luck.
    Thanks in advance?
    Keep the rubber side down
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Air compressor.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Isopropel alcohol always worked fine for me, just use a small amount not too much, twist and push and they seem to stay put.
    I've always had success using a little squirt of windex. It seems to evaporate pretty well. I just did this a week ago. No problem.
    rubbing alcohol, but just a little bit.
    To remove grips, I slide a spoke underneath the grip an inch or so and pour rubbing alcohol down the spoke and let gravity pull the alcohol through as I twist it free. usually after a second or two, even fairly stubborn grips break right free.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    ODI Lockons
    You replaced the solution with the problem.
    JPark - 3.5- don't listen to dremer
    Quote Originally Posted by AZ.MTNS View Post
    Air compressor.
    This. No fuss no muss.
    bi-winning
    Reputation: rkj__'s Avatar
    I've found hairspray to work very well. The cheaper the better. Extra-hold from the dollar store. Don't use too much.
    Vitamin Bike Added
    Quote Originally Posted by huffster View Post
    Worked like a charm. Already dry. You just earned some rep my friend!
    Chubby Chaser
    Reputation: Will Goes Boing's Avatar
    Grip glue.
    Feb 2012
    +1 on the air compressor
    Dec 2009
    You suggest i should buy an air compressor to fit my grip? Any sugestion for an air compressor under 10$?
    Rubbing alcool work fine.
    Reputation: MotoX33's Avatar
    This might sound crazy but I used to use gasoline on my quad grips. Plug the hole of one end, pour a little in, swish it around for a few seconds, and the grip will slide right on. It's my theory that the gas softens the grip up just enough to get it to slide on and once it evaporates in a few minutes, the grip is as good as glued. I always used grip wire to be safe.
    Are you a Happy Mutant?
    Reputation: gmats's Avatar
    Apr 2005
    Quote Originally Posted by MTBCanuck View Post
    Thanks in advance?
    Aloha,
    Yes, shops and a lot of us use compressors. That allows us to get the grips on and off when we need to. Unfortunately, not a lot of people own compressors. I wish I had a simple answer for that one.
    Another trick though this is a pretty much a one time only deal. Get some double stick masking tape. Wrap some on to the bars. Now plug the hole in the grip, totally get the inside of the grip covered with paint thinner, gas, something that can make the sticky on the tape not be sticky for a little while. After you're sure the grip's coated on the inside, pour this stuff all over the sticky outsides of the tape on your handle bar. Now work semi quick and slid the grip on. Let it sit over night as the solvent will eventually evaporate and your grip will be stuck on to the bars.
    This is how golf club grips are held on to the golf clubs.
    Good luck, I hope this helps.
    Reputation: pleepleus's Avatar
    Quote Originally Posted by rkj__ View Post
    Also let it dry a little before you shove the grip on.
    don't be such a tight wad and let your shop mech'a'nic in stall then for you and give the guy some beer money!!!!! look at all the time you've wasted over a 20 dollar pair'o grips! get a grip will ya?????
    Chubby Chaser
    I say befoH! I say again!!
    Grip glue..... you can find it at most motorcycle dealerships/shops.... $1 for a small tube. Wipe a bit on the end of the handle bars and immediately slide the grips in. It'll go in nice and smooth.
    AZ
    AZ is offline
    Quote Originally Posted by lapinGTI View Post
    I suggest you use one, if you buy one and how much you do or don't pay for it is none of my concern.
    MTBR member
    Mousse works great! It makes it slippery when installing, but dries stickey. If you need to remove old grips, just slide a thin screwdriver under the grip and spray.
    OFT.
    2010 Giant Yukon FX
    Pure XCR Wheelset/Geax Saguaro Tires/Tubeless
    Bike Weight Lost: 2.48lbs (1124g)
    Reputation: GTscoob's Avatar
    MAF cleaner for your car works great.
    Spray it on the bar and you've got about 8 seconds to get the grip on before it evaporates.
    Then you can pull your air sensors out of the airbox of your car and clean them to make sure your motor is running well.
    Reputation: GTR2ebike's Avatar
    May 2010
    Rubbing alcohol in a spray bottle(mist) spray on the bar. Make sure you get the bottom of the bar and spray it inside the grips. I've found this is the easiest way, just make sure you do it somewhat fast.
    Plan #123-D
    Reputation: The_Aaron's Avatar
    +1 on the cheap hairspray. I've actually found that no-name Walmart stuff works better than my wife's Aveda stuff for securing my ESIs. Weird.
    C'mon lets go for a whirl.
    clown question, bro
    Reputation: zeppy's Avatar
    Quote Originally Posted by aperzigian View Post
    Hmmmm if only I had access to something sticky that was cheap and easy to get. Hmmmmm.
    I think I see where you're going with that...
    <_<
    >_>
    >_<
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    Thanks in advance?
    Hmm, in my experience hair sprays vary in effectiveness. I use Albero VO5 extra hold. You want the highest hold type. I do sand the bar under the grip section and then use a bit of windex and wipe with a paper towel to clean. Wait five minutes. Spray bar and inside of grip. Install. Make sure your room temp is warm enough for the hairspray to set up. Leave alone overnight.
    During the wait time I do use a bit of alcohol. Usually a nice Cab or a good quality brandy. YMMV.
    Dark Meat
    Guest
    Air compressor.
    Air compressor works every time. Easy on, easy off.
    Reputation: Jason B's Avatar
    Quote Originally Posted by ken in kc View Post
    you replaced the solution with the problem.
    ftw
    Transition Bank
    Transition ToP
    Transition Covert
    Hoopy Frod
    If you don't have access to a compressor, a can of air for cleaning electronics works with the hose quite well.
    Reputation: nauc's Avatar
    drop of water or 2. its a ***** but can work
    I like turtles
    Reputation: TiGeo's Avatar
    Hairspray and an air compressor. Worked every time in the shop.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Ride Instigator
    Reputation: Ricko's Avatar
    A spiral of electrical tape around the bar surface and wet the inside of the grip with charcoal lighter, let it sit for a few hours after you slide the grips on.
    I was camping one time when my grips started spinning. I was desperate and this was the only stuff I had around and it worked like a charm...necessity is the mother of invention.
    Dec 2011
    Isopropyl Alcohol or just water
    Rubbing alcohol and Windex dry quickly because they use isopropyl alcohol. So both will work. Truth is, you could just use water, it just takes longer to dry.
    http://teamalchemist.com/
    http://blog.teamalchemist.com/
    Custom Cycling Jerseys, Merino Wool Jerseys, Organic T-shirts
    We used spray paint back in the day.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Ken in KC View Post
    What he said
    Lock on's are one of the best things (advances) invented for MTBing.
    AZ
    AZ is offline
    Quote Originally Posted by DIRTJUNKIE, View Post
    Not if you sell air compressors.
    Oct 2000
    This is true, I suppose we should all look out for those poor bastards.
    Oct 2000
    Upset
    Wouldn't it make more sence and less hassle to find a set of Lock On's that ergonomicly fit your needs better.
    Professional Crastinator
    Reputation: Fleas's Avatar
    2 pages of how to install hand grips??!!
    If it won't dry, use less.
    -F
    Mtn View, CA
    Reputation: gddyap's Avatar
    I put the grips in a cup of hot water for a few minutes. Do the same to get them off. Just put the cup on the floor and lay the bike over so the grips are in the cup. I use my wife's electric tea kettle to boil the water.
    I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum.
    use a compressed electronic air (like the ones for electronics) if you don't have a compressor. The easiest, won't cause slipping.
    I used 70% rubbing alcohol to remove and install grips - got slipping. I bet 99% would have worked better. Mine were slipping. I read it will get better with time but I didn't want to wait. I used the air can and it dried out the grips and improved them within 10 seconds. Really the only thing you should use imho.
    "2 Wycked"
    Reputation: crazy03's Avatar
    Mar 2011
    Really, I thought the 29er was.
    Ahhhh...Ahhhh....it's the hammy, it's the hammy!!
    "2 Wycked"
    Mar 2011
    Oops, double post.
    Iko
    Iko is offline
    Reputation: Iko's Avatar
    Mar 2011
    Lock-ons should be standard issue.
    Attached Thumbnails Attached Thumbnails Replacing grips...simply impossible?-p4pb2613275.jpg
    I like turtles
    Air compressor..always nuke's em' on!
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    box cutter
    '01 Straight 8
    '16 Balance
    '11 Jedi
    All Mountian Destroyer
    Dec 2011
    shoot a little compressed air between the handlebar and grip while you slide and it fits on perfectly, always worked for me
    DeForest Stump
    Reputation: Cobretti's Avatar
    May 2005
    Put 'em in the microwave for a minute, perfect!
    Reputation: Blurr's Avatar
    Dec 2009
    air compressor, all you have to do is blow on the grips to take them off and on, nothing easier.
    I'm SUCH a square....
    Reputation: bigpedaler's Avatar
    I use the air compressor at work, a $1 can of spray paint at home. Both work. The spray paint usually gets overnight drying.
    BTW, I use Lock-Ons for my bike, standard grips on my kids' bikes.
    A bike is the only drug with no bad side effects....
    Oct 2000
    Quote Originally Posted by bigpedaler View Post
    Oh so the kids aren't worthy huh.
    Reputation: OmaHaq's Avatar
    Jun 2010
    Elmer's light spray adhesive... when taking the grip off you will get some residue, but acetone will take it right off.
    - The only thing that keeps me on a bike is happiness.
    I use a air compresser now, but when I didnt have one i used WD 40. Spray it in the grip, smack the grip on something to get the excess out, then slide it on. Takes about 12 to 24 hours to dry depending on how much you have in there.
    1/2 fast or 1/2 assed?
    Reputation: Koppuh Klyde's Avatar
    I never thought I'd see a three page thread on grip tips.
    I'm a ******bag in real life so I dont have to be one on the interwebz.
    Quote Originally Posted by Koppuh Klyde View Post
    Make sure to stroke towards the......nevermind wrong thread.
    2010 Giant Yukon FX
    I have always had the best luck with WD-40 just enough to slide the grip on and let dry overnight. If you ride in a lot of wet areas this is not always the best option in which case I usually wire tie my grips.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    You wil use it for more than just replacing grips.
    Worth it's weight in gold for mounting some tubeless tires.....etc.
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
