Raw frames - issues for the manufacturers?- Mtbr.com
Results 1 to 17 of 17
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    Guys - before this thread gets moved to some obscure sub-forum where it will fade into oblivion, any idea why most/all bike companies appear to shy away from raw frames? They seem to be among the absolute most loved frames looks-wise. I would have thought they would be cheaper to manufacture than painted frames.
    Every time a limited edition raw frame is released, people go nuts and it is immediately sold out.
    Here is a good example of a beautiful looking stripped frame...go to the last page - posts 5879 and 5886:
    https://forums.mtbr.com/kona/honzo-b...750534-30.html
    It's a steel frame. I have the same one. Is corrosion/deterioration the issue? Inability to easily affix logos? Would a clear coat applied over the frame and logos not provide sufficient protection?
    I generally think raw frames look outstanding. They would likely be my preference for almost any frame. I don't get it? Am I overestimating how many people like the look of raw frames? Or is there some other blocker?
    EDIT: just read post post 5893. Looks like corrosion is the issue, at least for a steel frame, even with a clear coat applied.
    2020 Kona Unit
    2019 Forbidden Druid
    2018 Kona Honzo ST 30th BDay SE
    2015 Kona Paddy Wagon Fixed Gear
    Self Appointed Judge&Jury
    Oct 2000
    Donít know why they donít manufacture them on a regular basis. I do know you are correct that many dig that look. Start some new threads linking this thread in some of the manufacturers forums and get their attention.
    Bnerd
    Reputation: RideEverything's Avatar
    Woohoo, I've been linked to in another thread!
    I have read about the corrosion thing and my take away is most, if not all, of the examples that people give or relate to is the extreme end of the corrosion process. Everybody seems to think the moment water touches a steel frame holes of rust will appear!
    My first steel frame that I had I didn't do anything to the the interior of the frame to protect it. After 7 years of riding it in all conditions and sometimes putting it away wet there was only surface rust in the BB shell and headtube. And, it was easily wiped away.
    I did liberally coat the BB shell with grease every time I removed the BB.
    In my example of one I didn't experience the catastrophic rust frame failure predicted by most of the posts that I've read.
    When going down the rabbit hole researching for my most recent project of diy paint stripping of a steel frame I came across the issue that if a frame is just factory clear coated without any paint/primer so the raw metal is visible the clear coat isn't a perfect seal. However, the end result can look pretty cool as the rust forms crazy spider web like rust lines as it works its way under the clear coat.
    Reputation: OldHouseMan's Avatar
    I've heard nicer frames get selected for a raw finish. Frames with blemishes go to paint. So it could be more work to supply raw frames.
    Wanna ride bikes?
    Oct 2013
    I did my own frame raw the last time around. Frame Saver on the inside, satin clear coat on the outside. Looks pretty good. I don't expect it to last more than 4-5 years in my local environment of wet, humid, snowy, salty, wet some more, and generally bad for anything steel. I just plan on having it blasted and probably powder coated the next time around.
    I understand why manufacturers don't clear steel frames. But aluminum could be done more often. Some still do it. Knolly, Lenz, Banshee?, Canfield?...
    Ti is almost always raw or cleared. Buy more Ti.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    No known cure
    Reputation: Vader's Avatar
    Quote Originally Posted by *OneSpeed* View Post
    Fillet brazing always looks good in clear.
    Ripping trails and tipping ales
    Oct 2000
    Quote Originally Posted by Vader View Post
    Agreed, shows craftsmanship [welding, it is an art] at itís rawest.
    Reputation: DethWshBkr's Avatar
    Because an unpainted frame shows every blemish and mistake. Its easier to have a more uniform product when its painted.
    Reputation: Darth Lefty's Avatar
    Sep 2014
    Clearcoat finishes on steel will yellow and get hazy, and they don't cling as well since there's no primer... that's what I've read somewhere else before, anyhow
    Mar 2015
    MORE TI!!!
    I donít have any Ti at the moment. That is a very legit suggestion...hmmm...
    Surface Ti perhaps?
    To my eyes, your frame looks spectacular.
    2020 Kona Unit
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Darth Lefty View Post
    Yup, that's accurate and true. Hence why I realize and understand it's a temporary finish.
    A clear powder coat is definitely more durable and probably longer lasting than what I did (rattle can), but even that has a limited life expectancy.
    I didn't plan on going this route and was kind of forced into it, which is fine. I think it looks OK but actually prefer the first version of translucent Blue powder coat. It looked great with the Purple accents. Plus you could still see the brazing and craftsmanship.
    The raw thing has it's own appeal, but that Blue was awesome. I'll do that again down the road if the frame lasts long enough.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Feb 2007
    That looks really nice!
    Reputation: David R's Avatar
    Should be compulsory to offer a raw finish on all aluminium frames...
    Oct 2019
    I agree on the beauty of them. I have carbon frame with paint job that looks kinda like an anodized aluminium, and even that looks miles better than usual plasticky look of most carbon frames.
    Reputation: Samuellock's Avatar
    Oct 2019
    Once I decided bring to life an old frame,so, I used priming, 2 Car paint in cylinders, varnish, sandpaper and white spirit.
    But you know, I was totally dissapointed! Because after a week of riding, that paint faded and in some places vanished...So, I have an advice for everyone, who's going to restore the frame.
    NEVER USE CAR PAINT FOR YOUR BIKE FRAME!
    Mar 2015
    Reviving this thread.
    Today I was at one of two LBSs I use. Lo and behold, they had a lightly used Large Chromag Primer on the floor. Fk yeah! Hand welded by famed Whistler local, Mike Truelove. Raw clear coated steel! Exactly what I have been lusting over for 2 years now.
    What was weird though was that it had these bronze little squiggly looking patches every now and then. I understand that this is corrosion. Wow! I loved it. It's almost like living art.
    I have not seen this before but I have to say, in my mind it actually enhanced the look of the frame big time. Super interesting and it made the already custom frame even more unique.
    I don't know if I can rationalize getting another bike, let alone another hardtail. My garage is busting at the seams with bikes. Pretty shit component spec but I think I may have to do it nonetheless...
    2020 Kona Unit
    West Chester, PA
    Quote Originally Posted by OldHouseMan View Post
    I stripped a 2007 specialized stumpjumper and found several small dents that had filler in them.
  1. Which manufacturers have lifetime warranty on their frames?
    By Vegard in forum General Discussion
    Last Post: 08-31-2013, 05:50 PM
  2. Replies: 18
    Last Post: 09-19-2012, 11:47 PM
  3. Replies: 0
    Last Post: 09-07-2012, 01:00 AM
  4. The RAW finish. Raw or coated?
    By mitch66 in forum Niner Bikes
    Last Post: 12-06-2007, 11:05 PM
  5. Replies: 25
    Last Post: 09-29-2007, 02:07 PM
Members who have read this thread: 174
