Problem with seatpost bolt pulling through bolt hole- Mtbr.com
Results 1 to 7 of 7
    Aug 2010
    I have a easton ea70 aluminum setback seatpost. I recently bought a new saddle and today while riding the rear bolt pulled through the bolt hole on the seatpost
    I was able to reattach it and finish the ride but the bolt pulled 1/2 way out and was stuck in the hole.
    Would adding a washer help, look for a larger head bolt, or should I get a new seatpost?
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Pics?
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: dirtdan's Avatar
    This should be interesting...
    Aug 2010
    Not sure if you can tell much from the pics but basically some of the aluminum sheared off which allows the Bolt to go through under my weight
    You can put a conical washer in there to stop the head from going through
    The problem with 2-bolt seatposts is that the hole needs to be large enough to allow the bolt to pivot through the range of motion of the clamp, so it needs wiggle room. I'd try adding a washer, and if that doesn't solve the issue, buy a new seatpost (either the same type, or a different one).
    Aug 2010
    Thanks! I will try the washer and see what happens
