• 01-21-2013
    rjr19146
    Problem with seatpost bolt pulling through bolt hole
    I have a easton ea70 aluminum setback seatpost. I recently bought a new saddle and today while riding the rear bolt pulled through the bolt hole on the seatpost
    I was able to reattach it and finish the ride but the bolt pulled 1/2 way out and was stuck in the hole.
    Would adding a washer help, look for a larger head bolt, or should I get a new seatpost?
  • 01-21-2013
    Glide the Clyde
    Pics?
  • 01-21-2013
    dirtdan
    This should be interesting...
  • 01-21-2013
    rjr19146
    Not sure if you can tell much from the pics but basically some of the aluminum sheared off which allows the Bolt to go through under my weight
  • 01-21-2013
    the-one1
    You can put a conical washer in there to stop the head from going through
  • 01-21-2013
    wschruba
    The problem with 2-bolt seatposts is that the hole needs to be large enough to allow the bolt to pivot through the range of motion of the clamp, so it needs wiggle room. I'd try adding a washer, and if that doesn't solve the issue, buy a new seatpost (either the same type, or a different one).
  • 01-21-2013
    rjr19146
    Thanks! I will try the washer and see what happens
