Numbness in groin while riding.- Mtbr.com
Results 1 to 40 of 40
    Jul 2017
    How do I combat this? Is it a bike-fit issue? Nothing about the bike seems like it isn't ergonomic other than I get numb when I don't stand up for a few minutes.
    Oct 2018
    Possibly need to try a different seat.
    Does your seat have a pressure relieve groove?
    Is it overly padded?
    Jul 2017
    Quote Originally Posted by Forest Rider View Post
    No groove of any real size.
    It's not padded much at all
    I've had this problem. I use a saddle with a pretty big cut out
    down the middle. It may take trying several different saddles
    until you find the right one for you.
    Thinking about riding.
    Dec 2014
    Adjust the angle and position of the saddle on its rails a bunch before trying a new seat. A degree or two in angle makes a big difference.
    Downcountry AF
    Oct 2013
    Quote Originally Posted by 6foot4 View Post
    Post a pic of your current setup.
    It could be a positioning thing, but most likely you would benefit from finding a better saddle for your anatomy.
    I've had good luck with SQ Labs. I've turned a few friends on to them as well. Great saddles. Check out the 611. https://sqlab-usa.com/collections/saddles/saddles-mtb
    I also like the SDG Bel-air.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: LyNx's Avatar
    Yeah, that's definitely not good, need to get this sorted ASAP. Fro previous threads, I remember you're a big/heavier guy, so you're going to definitely want to find a saddle that fits you well, as in is wide enough to properly support your sit bones and has the right shape.
    For me that saddle is the WTB Pure (used to be PureV), have been using them now on all my bikes for the last about 10 years and anyone I've loaned a bike to or let test one of my bikes has always liked them, a good place to start IMHO. If you're going to give them a try, get the lower end version without any stitching/pattern on the top, the lower end ones have a softer foam which most prefer - I have a high end version a friend swapped me because he hopped on my bike with the lower end Comp version and liked better.
    WTB actually have a demo program that stores can sign up for where you can try out various models before you buy, would check in your area and see if maybe any shops have this. I've found when setting up WTB saddles that it's very important to make sure the sit bone area of the saddle is level, which in a lot of cases leaves the nose looking like it's pointing up some, don't worry about that. Also if you're on an FS, don't forget that the rear usually sags more than the front, so may need to set the saddle slightly nose down when you're off so it goes level when you sit and weight it.
    Nothing seems to kill me
    Reputation: CUP-TON's Avatar
    Dec 2016
    There are a lot of great saddles out there now with pressure relief cutouts.
    I have had good luck with WTB and SQ Lab saddles.
    And after calming me down with some orange slices and fetal spooning, ET revealed to me my singular purpose.
    Dec 2014
    How is everyone jumping to new saddle without even knowing if he's adjusted the angle yet? Bunch of saddle salesmen in here, I figure.
    Reputation: d365's Avatar
    Once you get it adjusted for proper leg positioning, and it's not tilted too far one way or the other... that only leaves a new saddle that fits better.
    I'm 220lbs, and I can wear out a saddle shell in a year of regular riding, so that it becomes too flexy and sags too much creating pressure. SQ Lab is my new favorite saddle.
    CEO Product Failure
    Reputation: bingemtbr's Avatar
    My advice-get to your local reputable Specialized dealer and ask to be fitted for a saddle. If the dealer has gone through the Specialized fit program, they'll measure your sit bones. From there its all about finding the saddle that suits you via trial and error. The fit will at least confirm if you have the recommended saddle width.
    Usually for me, when my junk is numb, the nose is high on my saddle. Try lowering a bit
    High Plains Luddite
    Reputation: Squeeze's Avatar
    Apr 2015
    Quote Originally Posted by bingemtbr View Post
    That worked for me. Took 30 seconds to take the test at the Specialized dealer and now I know my size (143, I think - I have it written down at home).
    Funny/annoying story - I bought a black Specialized Riva saddle from them, brand new, for about thirty bucks. I liked it (still do!) but when I went back to get another for my other bike, they told me they were discontinued.
    The nearest comparable saddle is now priced well over $100! I refuse to pay that much for a saddle, but at least I know my size now so I can shop elsewhere when necessary.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    Hey Numb Nuts! (sorry, I just had to)
    As others have said, if you have not had the bike fitted to you, do so now. Seat height and tilt angle could very well be the cause of your issue. Once that's done, if you don't feel an improvement, it's probably time to start looking at new seats. Opposite of what you might think a heavily padded seat is probably NOT your best option.
    Good luck getting it sorted out, so guys like me don't make disparaging comments to respond.
    "And crawling on the planet's face, some insects called, The Human Race..."
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Have you contacted Holden McGroin? He specializes in this issue.
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    Just use this one and you should be just fine.
    The numbness should shift...elsewhere.
    Trek …monda | Transition Scout | Transition PBJ | Framed Attack Pro
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by TheDwayyo View Post
    Oct 2018
    Good points about adjustment.
    I get discomfort, but no numbness, if the nose is tilted too high. Too low and of course we feel like we'll slide off.
    I've only had 1 seat in 4 bikes that haven't worked for me. The bad one was one with no relief channel.
    As mentioned above, small changes go a long way. Make a few small changes and see how it goes.
    Keep in mind, padded seats can make the issue worse -you can sink down and the padded material is pushed up against the body causing pressure.
    Dec 2017
    My mountain bikes have total asshatchets but I spend so much time in shred mode, I don't even notice. So I advise going downhill more.
    On a more specific note, if your actual groin is numb, you probably have a medical issue and not a fit problem. Your groin should not be touching the saddle.
    Reputation: Crankout's Avatar
    Jun 2010
    Chamois saddles...for sure.
    The only important thing these days, is rhythm and melody. Rhythm...and melody.
    Bikesexual
    Reputation: jcd46's Avatar
    Check for a hernia.
    Surly Krampus
    All City MMD
    Kona Unit
    Quote Originally Posted by Crankout View Post
    That would mean riding bare assed. Just, No!
    When you say "groin area," do you mean the muscles you workout on the spreader/gyno machine at the gymn?
    Or do you mean your wiener and beans?
    It is important to be precise for diagnostic purposes.
    Sent from my moto x4 using Tapatalk
    Professional Crastinator
    Reputation: Fleas's Avatar
    I found that soft saddles are actually worse for me.
    My 2 favorite saddles are a WTB Pure V
    And a Forte Pro SL
    Everything else is merely tolerable, or worse...
    I was committed to riding narrow saddles for a long time, but the reality is that my sit bones need a ~143mm saddle. The Forte is the winner by nose as I can maneuver around it more easily.
    Also, too high is bad, and wrong tilt will cause problems as well.
    -F
    It's never easier - you just go faster.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Something not said....you need to get out of the saddle regularly. If you just sit and pedal all the time, the blood is going to flow. Stand up and take the pressure off the area if only for a few seconds.
    Bicycles donít have motors or batteries.
    Ebikes are not bicycles
    Jul 2017
    Quote Originally Posted by cjsb View Post
    dick and balls
    Dec 2014
    dick and balls
    Can't believe I just quoted that.
    Have you adjusted your saddle fore and aft as well as angle of dangle?
    Jul 2017
    Angle of dangle should be at how many degrees?
    Oct 2018
    One degree less than what causes numbness.
    Seriously though, make minor adjustments until the numbing is no longer present.
    Generally, start with level. Maybe tilt the nose down a tad and give it a dry. Try to isolate where you feel pressure and move the seat accordingly. Moving the seat back may get you positioned a bit more forward on the seat where less pressure.
    The only seat that gave me a problem is the only seat without a relief cut in.
    I am far from being a bike fitter, however I have to think you'd know if you seat was in a 'wrong' position as far as overall comfort is concerned. Considering it seems to be comfortable, just causing numbness, it feels to me that the seat is the problem, not the position. Only because of the theory of mine that the seat seems like it would be uncomfortable to use regardless of position if it's the wrong seat for you.
    Again, I've only had issues with 1 seat out of four as far as numbing and I have had to adjust for comfort on other bikes which never caused numbness. So others are free to state why they think a comfortable seat would cause that much numbing if misadjusted.
    Reputation: Shartist's Avatar
    Aug 2018
    Where did my post with the pic of Macís bike from Itís Always Sunny Go???
    18í SC Bronson Carbon
    Grip2, Reserve 27 hoops, i9 hubs, Float X2
    2018 SC V10.6
    Grip2, We Are One: The Outlier, i9 hubs, DHX2
    Reputation: Gasp4Air's Avatar
    Don't you remember anything from high school?
    AOD = HOM x TOD
    Angle of the Dangle = Heat of the Meat times Torque of the Dork
    Use it, use it, use it while you still have it.
    OP, The main point(s) of pressure from a saddle should be on your "sit" bones and not centered in you perineum at all (or at least very minimally). Make sure your saddle is NOT overly padded so that it puts pressure in the center, then set it level and see where you feel pressure. If your weight is supported by your ass cheeks, you're probably on your "sit" bones. If not, you may need to change your saddle width so that the wings at the back support those bones.
    Jun 2010
    Scrotal surgery to shrink down your business. Nip and tuck, bish...
    +1 for lower your saddle... you may be surprised by the difference 3-6 mm makes.
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
    Quote Originally Posted by Frs1661 View Post
    +1 on the 3-6mm. We're talking small changes make a big diff.
    -F
    Oct 2000
    Quote Originally Posted by mtnbikej View Post
    This, hell Iím 60% standing to 40% sitting on any given ride. Plus as mentioned a slight tilt back with the saddle corrects a lot of this pressure the OP is experiencing.
    Reputation: nauc's Avatar
    whats your height and weight, what bike and what size is it? pic of seat setup?
    some Specialized dealers have an AssOmeter, measures the width of your sit bones. least yould know what width yould need if you had to get a different seat
    also, you riding with a good chamois? those help a TON
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    ISM saddle.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Apr 2005
    Your saddle tip is pointing up too high. You have to point it downward.
    Sent from my SM-G965W using Tapatalk
    Jul 2017
    Quote Originally Posted by Picard View Post
    I started to realize this during my most recent bike ride. I'm still getting it dialed perfectly, but I had too much pressure on my taint-bone.
  1. Saddles..how to fit. And numbness. NUMBNESS...
    By drew15a in forum General Discussion
    Last Post: 09-12-2016, 08:23 AM
  2. Groin Numbness and Spasms...Doesn't that sound fun?
    By crewjones in forum General Discussion
    Last Post: 02-10-2015, 12:58 PM
  3. Groin pulls- yeeouch!
    By Finch Platte in forum General Discussion
    Last Post: 01-12-2011, 04:51 PM
  4. groin pain dat after riding
    By mark_8408 in forum Riding Passion
    Last Post: 10-06-2006, 07:20 PM
  5. Groin Pain while riding
    By Eggman in forum General Discussion
    Last Post: 03-08-2004, 06:15 PM
Members who have read this thread: 156
