Middleburn, home brew spiderless... chainline.- Mtbr.com
Results 1 to 8 of 8
    Aug 2010
    Anyone using this setup for a 1x9? What did you do to deal with the chainline?
    I tried it last night and the chainline sucked... ring rides too far outboard. Plus the chain guide needs to run so far out that it barely clears the crank arm... and I use a Paul's keeper which is very small... I doubt your standard e-13 or MRP would work.
    (edited below because I goofed).
    Going to have to move my spacers around to fix chainline.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Never mind, I 'm an idiot.
    Aug 2010
    Quote Originally Posted by AZ.MTNS View Post
    LOL! Thanks... that was very helpful.
    AZ
    AZ is offline
    Can you run a spacer outboard of the spider to space it in?
    Aug 2010
    Okay, so I'M an idiot too. I had what spacer was needed where, flipped in my head... I actually need less spacers on the driveside, not more... which actually solves my problem.
    As for your question... that was my first thought, but I think it would probably put the splines under more strain as it would reduce the interface (i.e. 5mm spacer means 5mm less spline interface).
    Anyway, so the issue of chain-line will probably be fixable, but people wanting to run any chainguide on a 1x9/10 will still have issues with standard chainguides. I think Paul's will be the only solution there.
    nothing to see here
    Reputation: Stevob's Avatar
    I've ordered a HbC spiderless chainring for my new Middleburns. How much difference is there between the Middleburn ring's chainline and the HbC chainline?
    As for your issue with the 1x9 set up, has your rear derailleur got an adjustable spring tension on it? I've heard that you can set some to run tighter, which helps with not dropping the chain at the front.
    I see hills.
    I want to climb them.
    exact chainline
    I have a similar drivetrain setup (middleburns with hbc spiderless, Paul chain catcher, and gears in the back).
    How did you configure your spacers and what was the resulting chainline?? Right now I have the bracket for the Paul catcher and a 2.5mm spacer on the drive side. I had to use a 1.8mm spacer on the nds otherwise my cranks were binding (nobody has better tolerances than shimano!!). My chainline is about 59mm which is way too wide. Riding in the 36T cog is really loud. I'm going to move the 2.5mm spaced to the nds to see if it helps. But it will still be wide. I didn't realize that the Middleburn spiderless ring had so much offset...
    Would love to hear your experience!
    Quote Originally Posted by Stevob View Post
    I believe the middleburn chainline is 50 or 51. With the hbc it is more like 58 or 59. The middleburn ring has a lot of built in offset.
