Let's ditch full rigid- Mtbr.com
Results 1 to 58 of 58
    Out spokin'
    Dec 1999
    Y'all,
    Time to set the record straight. There are three main types of bikes:
    • Full suspension (front & rear suspension)
    • Hardtail (front suspension)
    • Rigid (no suspension)
    That's it. It makes no more sense to say "full rigid" than it does to say "full hardtail" and nobody says that. If you ride rigid -- and good on ya if you do -- just say, "I ride a rigid bike." It's badass enough.
    =sParty
    P.S. No doubt someone will come along to ask what about suspension seatposts. Well, like grips with wings, bar ends, weird saddles and the like, bolt-on rear suspension doesn't actually count, it just makes your bike look weird. It's actually fake suspension. Either hold your head up high and say "I ride rigid" (actually lying a little bit) or be more honest & say, "I'm semi-rigid right now." Be sure to wink if you do say this.
    disciplesofdirt.org
    Reputation: cookieMonster's Avatar
    I not only ride rigid, I install leg braces to prevent my knees from bending. Now that's riding rigid!
    Merry Christmas!
    Bikes belong in Wilderness areas.:)
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    What about fully limp recumbents?
    Jul 2014
    If person rides rigid bike out of saddle, then isn't that less rigid than riding from saddle (riding full rigid when on saddle)?
    Then again, hard tail is not rigid at all when riding out of saddle.
    Quite often I ride my hardtail almost rigid though as front forks did seize up.
    I think that it is too dangerous to box different bikes into tight categories, much better to just ride them.
    Trek 3700 Disc, frame, wheelset, seatpost, fork and rear brake original, rest is upgraded.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by Nat View Post
    I'm fairly certain that's redundant, as the adjective is implied by the noun itself.
    Death from Below.
    Reputation: Sir kayakalot's Avatar
    Jul 2017
    Even if you’re an EnduroBro you can’t say “full rigid”? That’s harsh brah
    DAAAANG...that was janky
    Reputation: OldHouseMan's Avatar
    I'm with you on this one. Also add "forks" to the list of words to ditch when you're talking about a single fork.
    Reputation: plummet's Avatar
    I ditched fully rigid in 1996, then ditched hardtail for trail riding in 1998. Haven't looked back since.
    Sneaker man
    Reputation: mik_git's Avatar
    yeah but what about soemthing like a flext stem or suspension seatpost, or softride. ... rigid frame with a suspension component...
    All the gear and no idea.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by mik_git View Post
    You just broke the internet.
    Not a role model
    Reputation: ninjichor's Avatar
    Jul 2018
    What do you call a "full suspension" mtb that is down to its frame alone?
    I think ebay had options for full, rear, and maybe dual when I listed one.
    Reputation: life behind bars's Avatar
    May 2014
    This must be part of "Festivus", the airing of grievances?
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Cycologist
    Reputation: chazpat's Avatar
    Full rigid = no dropper on your rigid?
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Reputation: J.B. Weld's Avatar
    full rigid = no tires on your rigid
    I brake for stinkbugs
    Mar 2017
    Quote Originally Posted by J.B. Weld View Post
    You can have tires but they must be solid rubber
    Up In Smoke
    Reputation: Train Wreck's Avatar
    Feb 2005
    This is why I don’t ask and don’t care what bike you ride, I just want to see pictures
    Kind of like playing an electric drum kit
    Bikesexual
    Reputation: jcd46's Avatar
    Quote Originally Posted by OldHouseMan View Post
    Please!
    Quote Originally Posted by Train Wreck View Post
    Yes!
    Surly Krampus
    All City MMD
    Kona Unit
    Surly Cross-Check
    Out spokin'
    Dec 1999
    Right on. How many forks? One. So it's a fork. Thanks, OHM.
    And since we've already started down this road, let's go all the way. It's a suspension fork, not a "front shock."
    =sParty
    disciplesofdirt.org
    There is a 4th type of bike I will call a combo. My hardtail has a lock out fork, making it a rigid and a hardtail.
    Quote Originally Posted by John Kuhl View Post
    Does that make my FS with F/R lockout a FS, hardtail, and rigid?
    No. You have a hardtail. I have a FS.
    Sent from my Moto G (5) Plus using Tapatalk
    the half breed devil
    Reputation: shekky's Avatar
    Oct 2011
    guilty as charged.
    will keep OP's intent in mind when making future posts re my karate monkey.
    Reputation: natas1321's Avatar
    Nov 2017
    I just ride.
    Sent from my moto g(6) using Tapatalk
    Nat
    Nat is offline
    No, it’s still a hardtail.
    Apr 2019
    Quote Originally Posted by Sparticus View Post
    Y'all,
    =sParty
    Why say “full-suspension “, then?
    Suspension
    Hardtail
    Rigid.
    There.
    Nat
    Nat is offline
    Quote Originally Posted by downcountry View Post
    Suspension
    Hardtail
    Rigid.
    There.
    Hey, yeah. We don’t say “half suspension” or “partial suspension.”
    We don’t need to specify “full suspension motorcycle” or “full suspension car” do we, so at this point are mountain bikes with suspension on both front and rear standard enough to just call them “mountain bikes?”
    Out spokin'
    Dec 1999
    Suspension
    Hardtail
    Rigid.
    There.
    Truth! Now we're gettin' somewhere. Although technically one might argue that a hardtail is a suspension bike. But in common use, no one would do that. No one would refer to their hardtail as a suspension bike, so yeah, "suspension," "hardtail" and "rigid" are essential terms. Let's go with it.
    =sParty
    disciplesofdirt.org
    Let's not forget about soft-tails.
    Reputation: Curveball's Avatar
    Aug 2015
    I reserve the term "full rigid" for when I'm talking to the wifey.
    Riding Washington State singletrack since 1986
    Out spokin'
    Dec 1999
    You must spread some Reputation around before giving it to Curveball again.
    For this exclusive purpose, the phrase "full rigid" shall remain! Best yet, for wifeys everywhere to exclaim as excitedly and as frequently as possible.
    Okay, let's tie this up with a bow on this Christmas Day. Whenever some unsuspecting, out-of-the-loop MTBR poster employs the phrase "full rigid" to describe his/her bike, please set them straight (ahem) by pointing them (ahem) at this thread.
    =sParty
    disciplesofdirt.org
    Quote Originally Posted by Curveball View Post
    Long hard fully rigid night rides?
    Cycologist
    =sParty
    or tell them to save it for the wife
    Oct 2018
    The comment is not about how you are riding, but rather what you are riding.
    If you are riding rigid, it differs from riding a rigid.
    Therefore, standing is removed from this example of bike style.
    Somebody tells me they are riding rigid, depending on the person/context, I assume they are either riding too tight or um....never mind.
    Somebody tells me they are riding a rigid, I say "Yeah, I'm looking at your bike and noticed that".
    Lockouts don't count on a fork, on forks or suspension fork(s). That's selectable and is therefore void.
    Rabid Lana Fan
    Or, maybe ditch "hardtail" and start saying "half-rigid".
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Cycologist
    Is the hardtail half-rigid or half-suspended?
    Rabid Lana Fan
    I guess it depends on your worldview.
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    What do I call the bike I have with a soft-tail frame and a rigid fork?
    Apr 2019
    Quote Originally Posted by sgltrak View Post
    A curiosity?
    Aug 2015
    I'd probably go with "Frank"
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    That's a hard nose.
    Sent from my SM-G955U1 using Tapatalk
    MTBR Posting Guidelines
    calories>electrons
    Ride what you like!
    Reputation: MattiThundrrr's Avatar
    Jul 2019
    I have an old Hardrock FS. It's a hardtail.
    Should I add springs to the back, or sand off the "FS"?
    The revolution starts now
    When you rise above your fear
    And tear the walls around you down
    The revolution starts here
    Ride what you like!
    Jul 2019
    Sure. As long as no one rides a rigid Mountain bike or a hardtail Mountain bike.
    Maybe what needs to be dropped is the term "Mountain bike".
    I'm an all terrain biker!
    The White Jeff W
    Reputation: jeffw-13's Avatar
    But I love my Pikes
    Sent from my Pixel 3 using Tapatalk
    No moss...
    slow
    Feb 2005
    Quote Originally Posted by rockcrusher View Post
    That's a hard nose.
    A curiosity?
    So "Frank, the Hard-nose Curiosity" it is. Thanks for the naming assistance.
    The bike has been fitted with a bikepacking fork and demoted to gravel duty since I cracked the frame last spring in Moab.
    Na
    Feb 2019
    Full rigid= no seat or grips on your rigid..
    Jan 2009
    do people still actually say "fully rigid"? do these same people also insist on calling all stems "gooseneck" and refer to call road bikes as "ten speed"?
    most bicycles (tandems notwithstanding) only have one fork and one handlebar. maybe it's a handlesbar. Unless it's some kind of mad scientist-created mutant, a frame with suspension has a shock, not shocks. I don't understand the need to make singular things sound plural. it just makes us sound ignorant.
    One ring to mash them all
    Mar 2015
    I'm Frank, and I endorse this message.
    Women belong in the kitchen.
    Men belong in the kitchen.
    Everyone belongs in the kitchen.
    Kitchen has food.
    Cycologist
    Quote Originally Posted by mack_turtle View Post
    May I borrow your scissor, I need to cut a string off my pant.
    Actually, I'm with you, the English language if just pretty screwed up.
    EDIT: especially if you can't type!
    Nat
    Nat is offline
    I’ve never come to terms with the word “pant” meaning the garment you wear on your lower body. “This is a new pant for spring.”
    be1
    be1 is online now
    too hot to hoot
    Reputation: be1's Avatar
    Sep 2013
    i vote for this.
    suspension
    half suspension
    non suspension
    or maybe just "bike"
    Ride what you like!
    Jul 2019
    Quote Originally Posted by be1 View Post
    i vote for this.
    suspension
    half suspension
    non suspension
    You're looking at it backwards, as though suspension were the default.
    I say this makes more sense:
    Bike
    Half or front suspension
    Full suspension.
    I'd wager that there are far more bikes without suspension than with. Remember that all terrain cycling is just a niche in the market.
    Apr 2014
    =sParty
    We are going to have so much more time for riding this year!
    Out spokin'
    Dec 1999
    Quote Originally Posted by MarcusBrody View Post
    Time for riding? Riding what?
    • DH
    • Enduro
    • Downcountry
    • All mountain
    • XC
    • Etc, etc, blah, blah, blah...
    More defining to be done!
    =sParty
    disciplesofdirt.org
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Quote Originally Posted by bronxbomber252 View Post
    LMAO
    "Always usually" come with solid rubber wheels, solid saddle without any form of padding, no dropper and, no grips for full rattle experience...
    【ツ】 eDub 【ツ】
    Ride what you like!
    Jul 2019
    Quote Originally Posted by edubfromktown View Post
    LMAO
    Lol now we've finally found the definition of a dentist's bike: one that rattles your teeth out!
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    =sParty
    I get the idea here and like to be a team player but I might often ignore this calling out just because the 'pants' or 'forks' point of view makes me think of things going in the direction of Grammar Police. For me, it's sometimes a quagmire in the way of most things mtb I'm hunting down or perusing.
    Definitely not bad here as some forums I've seen, yet I sometimes see tight-a$$ policing calling out of some minor things and although I'm sure it's difficult for some to let it slide or not take the spotlight, I'll keep my focus on things more to my interest.
    That said, I DO understand there are often times correct designation of a style, type or component can be crucial for understanding or not mis-informing. Where safety is related or correction will 'fix', I'll def try to keep in the spirit of intentions.
    -Someone may have posted or asked but I'm wondering if 'a dually' is acceptable for full sus ?
    If you cut a leg off your pants, you have pant. Cutting the legs off, you have shorts.
    "Before you criticize, you should walk a mile in their shoes. You'll be a mile away from them and you have their shoes"
    Cycologist
    So full squish, half squish and no squish is what we're going with?
    Maxxis cult follower
    Reputation: richj8990's Avatar
    Apr 2017
    Y'all,
    =sParty
    LOL @ full hardtail, that's really funny, have not heard that one yet.
    I was looking at dropper posts earlier this week (my 100mm one is not cutting it on steep climbs), and came across a Suntour 'suspension post' with 65mm of travel. As in you hit a bump and the seat bounces. They advertised it as "It feels just like having full suspension". LOL. People actually complain about the feeling of full suspension, because they say it feels like their rear tire is going flat. So I dunno if that's a good thing to feel like it's full suspension when it isn't.
    As far as rigid is concerned, I wish they made cheaper bikes rigid instead of putting on a cheap coil fork like a Suntour XCT (or worse). They could then put on wide tires, like a 2.6 or a plus tire and get 'some' suspension, maybe 10-20mm directly from the tires. The cheapest decent air fork is $250+ so that's too expensive for an entry-level bike; they should just make them rigid instead of putting beginners through the never-ending pogo stick torture.
    40% of the population doesn't even understand what a dictatorship is. Or worse...far worse...they don't care.
    Co Springs
    Oct 2013
    Fully rigid seems aluminum. Maybe we term it hard-ass rigid?
    Comfort rigid - steel
    Springy rigid - carbon
    Lively rigid- ti
    I've met some Full Rigid personalities.
    I'll bet you have too.
  1. So let it be ridden, so let it be done.
    By CptSydor in forum Eastern Canada
    Last Post: 06-14-2015, 08:22 PM
  2. GDMBR: Full Rigid or Full Suspension?
    By albeant in forum Bikepacking and Bike Expedition
    Last Post: 07-20-2012, 06:00 PM
  3. Let it rain..let it rain, Marin Stoke!
    By Guitarzan415 in forum Turner
    Last Post: 04-01-2011, 09:42 PM
  4. Let it rain, let it rain, let it rain
    By LMN in forum XC Racing and Training
    Last Post: 06-19-2008, 03:07 PM
  5. Let it snow, let it snow........
    By ibmkidIII in forum Riding Passion
    Last Post: 04-25-2004, 09:14 AM
Members who have read this thread: 195
