Results 1 to 18 of 18
    Jan 2019
    I want to fit a tapered fork to a bike with a crown race reducer fitted.
    Hello everyone - first post - I've been a lurker for a while but I need help to fit a tapered fork to my bike which currently has a fork with a straight 1 1/8" steerer tube. My bike has a tapered head tube and a crown race reducer in order to fit the straight steerer. The bottom bearing is caged and seems wide enough to fit a 1 1/2" steerer (ID of bearing is 44mm). Do I just need a crown race and if so, which one will fit the caged bearings? Or do I need a new headset? Thanks.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    If it's a 44mm head tube you will need a new external lower cup and race.
    I got some bad ideas in my head.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Travis Bickle View Post
    He said the ID of the bearing is 44mm, not the ID of the head tube.
    It kinda matters what the headset is which crown race will fit best.
    Jan 2019
    Thanks guys, I think I have found a 1 1/2" crown race to replace the existing reducer race. I contacted a dealer who sold my make of bike (XDS) and he thinks I will be able to use the existing caged bearings. It's being sent to me in the post so I will have to wait a few days before I will know for sure. Cheers.
    Reputation: LyNx's Avatar
    Yes, all you will need is a regular 1.5" crown race that fits the bearing angle of your current bearings, no need for anything else unless by some weird reason you can't find one to match.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ he doesn't have cartridge bearings.
    Do the math.
    Yup, think I read that and thought I was reading wrong, seemed a bit weird. If this is the case, unless the shop he got it from has the race for a tapered steerer to fit the caged bearings, probably easiest thing would be to buy a new bottom cup complete. Didn't say which HT standard his frame uses, so if he can figure that out, will make finding something easier.
    Quote Originally Posted by Lone Rager View Post
    Anytime. Anywhere.
    Sorry about my reply, my reading comprehension failed.
    Jan 2019
    Thanks LyNx. Trouble is there are no markings on the bearing cage whereas the upper bearing is a cartridge type and shows 45 degrees. Itís a neco headset - I have looked through their range but cannot see any with lower caged bearings. I donít know how to determine HS standard. It doesnít appear to have cups so that would make it integrated I guess?
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Why not just pick up a new tapered headset? The NECO ones are only like 15 bucks, and bikewagon had some takeoffs that were 10 bucks.
    since 4/10/2009
    Quote Originally Posted by Dr Boogie View Post
    If the head tube of the frame is tapered, the bearings are likely sitting in a "zero stack" or internal cup. Integrated headsets will typically use a cartridge bearing, so that the bearing balls themselves aren't rolling around (and wearing out) the frame.
    https://www.parktool.com/blog/repair...dset-standards
    I have seen manufacturers mix upper headset parts and lower headset parts. For example, I have seen with some frequency lately bicycle manufacturers using Cane Creek 40 uppers, but Cane Creek 10 lowers. And then in the spec sheet for the bike, they list the headset as "Cane Creek 40" rather than being specific about what they did. Kinda slimy if you ask me.
    Jan 2019
    Quote Originally Posted by GuitsBoy View Post
    Yes I looked at that but there is a bewildering array of headsets. How would I know which is right for the head tube on my frame?
    Jan 2019
    Yes, I have looked but there is a wide range of headsets and it is difficult to know which one would fit the head tube of my frame.
    since 4/10/2009
    1. Consult Cane Creek's headset fit tool.
    2. Ask a bike shop.
    3. Consult frame specifications from manufacturer for head tube dimensions.
    4. Remove existing headset and measure head tube.
    Sent from my VS995 using Tapatalk
    Let us know what frame it is you have, maybe someone knows the headset standard it uses, or try the Cane Creek headset finder as Harold suggested.
    Jan 2019
    Quote Originally Posted by Harold View Post
    2. Ask a bike shop.
    Thanks Harold - I'll work my way through those suggestions.
    Land of the 230+
    Sep 2013
    If you have some pics, or a link to the bike in question, it might be easy to ID.
    Jan 2019
    If itís any help itís an Air x6 frame made by XDS. XDS Boss 4 (2018) is the name of the bike. XDS make frames for others too and have different names - e.g. Flight Trail 1 has the same frame and is sold by Rebel Sports in Australia (which is where I am). I did email XDS a whilst ago but they didnít reply. Thanks.
  1. 2 piece reducer on top and 3 piece reducer at the bottom - normal?
    By Metanoia in forum Shocks and Suspension
    Last Post: 01-18-2018, 06:04 PM
  2. Tight crown race - Possible damage to crown/steerer press-fit?
    By Pableras in forum Shocks and Suspension
    Last Post: 06-12-2014, 02:15 PM
  3. Replies: 2
    Last Post: 07-22-2012, 05:16 AM
  4. 1.5 inch headset reducer shims vs. "full" reducer headset
    By pfcnguyen in forum Downhill - Freeride
    Last Post: 03-21-2011, 11:55 AM
  5. Reducer cups or no reducer cups?
    By MattP. in forum Downhill - Freeride
    Last Post: 11-09-2006, 08:15 PM
Members who have read this thread: 114
