How To Hold Brake Levers On Trail Ride- Mtbr.com
Results 1 to 165 of 165
    Threaded
    Reputation: BobBracket's Avatar
    Jun 2018
    I had my first trail ride on my new fat bike yesterday and went pretty good but am a bit unsure if I'm using the brake levers right. I found I had to be on the brakes a heap but that when I am I'm not able to grip the grips going over the rough stuff as my fingers have to be open resting over the brake levers to use them. Is that just the way it goes or is there a better method to be learnt here?
    Jul 2017
    Move the brake clamps inboard(toward the stem) so that the lever can only be physically operated with just your index finger. Your hand will be able to utilize the entire grip while your index finger can rest on the brake lever.
    I no longer like to party. But I like the idea of it.
    Reputation: Legbacon's Avatar
    Move the levers in until the end fits well with your index finger. The index finger is all you should need if the brakes are working properly.
    Formerly Travis Bickle
    Team Robot. "modulation is code for ďI suck at brake control.Ē Hereís a free tip: get better."
    Reputation: sturge's Avatar
    One finger on brake levers (index finger) is all you need to get the required stopping power with today's hydraulic brakes. Grabbing a fist full of brake is going to cause skidding (or worse). Check setup of levers to ensure they are in optimum position on bars where your index finger is naturally at the best spot on the lever.
    This usually means the levers need to move INWARD leaving a gap between the grips and lever mounts. This will put the levers in the correct position for your index finger to get the best lever pull while having hands naturally on grips. Also check/rotate levers on the bars as needed. Loosen mount and rotate up or down to get best fit for your situation. Most levers also have a small allen screw adjustment where you can extend or reduce the distance from open lever to bar (adjusts gap for small or big hands).
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...:thumbsup:
    Reputation: LewisQC's Avatar
    Jul 2013
    Quote Originally Posted by almazing View Post
    1+ on that. Depending on the shape of lever and type of brake, sometime you'll need two finger. That was the case with my fatbike (avid BB7 mechanical brake). Now that I have Guide RS hydro one finger is enough. Looking at my setup, there's no way you would be able to ride with all your fingers on the lever
    2015 Salsa Blackborow 1
    2017 Devinci Hatchet Carbon
    2009 Spec Tricross Sport
    2019 Ibis Ripmo
    Reputation: Gasp4Air's Avatar
    And once you have adjusted the position toward the stem so they're reachable by one (or two) fingers, angle them on the bar so they are about in line with the back of you hand. You shouldn't have to rotate your hand on the grip to get you finger(s) on the lever.
    Bonus tip: once positioned, tighten them down just enough so that they can still be rotated on the bar with moderate force, but not so loose that they move during use. In the event of a crash, they can move, reducing the likelihood of breakage. When that happens, you can just rotate them back into position with your hand.
    Use it, use it, use it while you still have it.
    I line up my levers so the line up with my wrist/forarm when I am in an average braking position, which is not my seated pedaling position.
    Threaded
    Jun 2018
    Thanks all, I'm glad there's a solution to that. I have SRAM level hydraulic with 180 front and 160 rear rotor, fat bike is just under 15 kg and will be a bit less than that when I go tubeless. Brakes seemed to work well so the one or two finger method should hopefully work out.
    Threaded
    Jun 2018
    Do all bike shops sell their mtbs with levers in that inconvenient position or is there a reason for it?
    Reputation: BlueCheesehead's Avatar
    Deleted, too late.
    Jul 2017
    Quote Originally Posted by BobBracket View Post
    Bike shops just clamp it on there to make it complete. People have different preferences and shapes. So tailor the cockpit to what works for you, or have your LBS do it.
    Some shops will spend 10 minutes to quickly inspect and adjust components for you.
    Some shops don't because they either don't care or they are incompetent.
    Reputation: Mr Pig's Avatar
    Bike shops don't set the bike up, just assemble it. You wouldn't complain that a car dealer had not put the driver's seat where you wanted it?
    Bikesexual
    Reputation: jcd46's Avatar
    Quote Originally Posted by Mr Pig View Post
    I think that depends on the shop. When I got my Heckler, they dialed it in for me on the spot. Same when they build my Kona (2 different shops).
    I know of a shop that didn't do that on my first bike, and their service is overall very poor. That's why I prefer smaller shops, the service is always there, and you don't need to speak with 5 different sales/c.s people.
    Surly Krampus
    All City MMD
    Kona Unit
    I've never had a shop set my brake lever position, never asked them to and wouldn't want them to. I don't think it's something you can get right in a shop. you need to ride the bike for a while, see how it feels and move them until you get it dialed.
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ well yeah. I know what I want and like and don't need anybody to set it up that way for me, but newbies often don't, so it's helpful for the shop to get them set up with a decent default position. Also, using one finger and keeping it on the brake at all times isn't something that necessarily comes naturally to the white-knuckled beginner. Most hold onto the grips with a full fist and then grab the brakes with all fingers.
    What, me worry?
    Reputation: life behind bars's Avatar
    May 2014
    Tighten the clamps just enough to keep them in place yet able to rotate on the bar in the event of an unscheduled dismount.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Reputation: Scott O's Avatar
    I need to know why BobBracket has a negative reputation on mtbr. Is it because of his lack of knowledge around brake levers? Or something else? eBiker? Still rides a 26er? Blatantly leaves skid marks on eco-sensative flora and fauna. Stole someone's chIck? All of the above? What'd you do, BobB?
    Threaded
    Jun 2018
    Quote Originally Posted by Scott O View Post
    Lol I noticed that nice surprise earlier today when I visited the forum so searched around to see how many others also have negative reputations. No-one. My best guess is westernmtb has multiple accounts and is trying to encourage me off the forum through reputation bullying. He took exception to the "dumb" ebike question I recently asked then he visited my account. Shortly after that "BobBracket" is infamous around these parts" even though he's pretty new here and barely knows anyone. The infamous reputation came before the brake lever question and after the ebike question.
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    I think one of his posts said he's Australian. Just like the direction the toilet water swirls, reputation points work backwards down there too.
    Threaded
    Jun 2018
    Quote Originally Posted by GuitsBoy View Post
    No doubt that's it.
    Meatbomb
    Reputation: Phillbo's Avatar
    I flip mine to moto style.....
    May 2014
    Uhmmm, no. I looked, your negative rep came from several respected members on this board, most likely for calling them "trolls". Full disclosure, you got some from me as well.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Land of the 230+
    Sep 2013
    Quote Originally Posted by life behind bars View Post
    As a sidebar, is rep history publicly visible? Or is it an admin-only function? I know I can see my "latest reputation received" but I was wondering if other people can tell that all my green chicklets came from threads about unicorns and rainbow glitter handlebar streamers?
    Up In Smoke
    Reputation: Train Wreck's Avatar
    Feb 2005
    You could check out some youtube footage of some of your favorite DH/enduro riders and try to notice how they do it.
    For me, once the trail points down my index fingers always just find the lever. You could use two fingers if necessary, but I find even the cheapest mechanical disc brakes have enough power to slow me down with just one finger and allows me to keep a good wrap around the bar with my other fingers. As others have said, making sure the cockpit is set for your preferences is key. Just a few adjustments could make a huge difference.
    Threaded
    Jun 2018
    Ummm untouchable friends of yours are they? I called two members trolls not "several". These "respected members" got called out for trolls by this newbie because that's exactly what they were doing, trolling.
    May 2014
    That feature is only available to Mods and Admin.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    May 2014
    And you wonder why you have difficulties here.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Threaded
    Jun 2018
    So this is the way it rolls around here. Who moderates the moderator?
    Up In Smoke
    Feb 2005
    karma
    Cycologist
    Reputation: chazpat's Avatar
    Ask for your cost of admission back. Best to just move along.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    Oct 2018
    I have about 1.25" of space between the clamp and the grip on the Sram Level T brake. That gets me 2 fingers if needed, one is fine. Most of the time I default back to 2 fingers, that's what my brain has been trained to do for 30 years.
    The 1.25" is adequate for the Sram as their levers are a mile long. I found I had to swap the clamps of the brake and shifter -as delivered the shifter was inward (towards the stem) of the brake clamp. Once I adjusted the brake position, the shifter became just a little too far for comfort.
    I can't remember the spacing on my Shimano setup, but those levers are shorter and I assume the clamp is a tick closer to the grip.
    I've only mentioned the dimension because it could indicate to you that it is important to shift it whatever makes YOU happy. According to my notes, it was delivered with 1/2" gap (obviously I moved it a lot further than as delivered).
    As mentioned above, make sure to rotate them so they are comfortable in your most common riding position. Usually near 45-degrees down, or less. if your riding is mostly standing, you'll need to point them lower than if you were to never stand.
    Note the right side you can see a gap then the Eagle emblem of the shifter with the brake to the left of that.
    No known cure
    Reputation: Vader's Avatar
    Not everyone uses the index finger. Some of us do one finger braking with the middle finger, which is why the lever is against the grip.
    Attached Thumbnails Attached Thumbnails How To Hold Brake Levers On Trail Ride-img_20190121_155843087.jpg
    Ripping trails and tipping ales
    Threaded
    Jun 2018
    Quote Originally Posted by Forest Rider View Post
    Attachment 1234815
    Thanks to everyone for all the detailed advice, it's very much appreciated and everything has been taken on board.
    Forest Rider I have just tried adjusting my brakes and as you said if just using the index finger the shifter levers are too far away. In my trail ride yesterday I think I was using two fingers on the shifter but due to the weight of the bike and lack of suspension I found I needed more fingers gripping to muscle and control the bike more optimally.
    After this adjustment I did find I could use the middle finger and reach the shifters nicely, however I'd prefer to be an index guy, the middle finger doesn't feel so natural. I'll try swapping the brake and shifter clamps around and see what happens. Thanks for the advice.
    Reputation: targnik's Avatar
    Jan 2014
    Big levers require big fingers ^^
    Get some Shimano or similar i.e. short lever brakes...
    One finger is all you should need.
    It's hard to slow down a bike if you can't keep your hands on it ;-)
    'Born to ride!'
    "Mountain biking: the under-rated and drug-free antidepressant"
    Oct 2018
    Trial and error. Take your multi tool with you on your ride and make trail side adjustments. Best to do so in the natural environment. I think you'll get the 1-finger thing sorted out no problem.
    We all know middle figures have other uses than braking, so safe that for the fools passing you on the trail.
    I don't think I could articulate my middle finger to reach a brake lever. Once you get it dialed you'll know it -it will 'feel right' at that point.
    Threaded
    Jun 2018
    Hahaha yeah it's always preferable not to flip off every oncoming rider lol. Anyway I swapped the right brake and shifter clamp around and went for some rides adjusting it. Works a damn treat. The right dropper post clamp on the left side didn't need swapping though as it was already in the right position. Absolutely stocked now mate, brake position is pretty much the same as the picture LewisQC sent.
    Oct 2018
    Sweet! Now to get it dialed as you progress your riding skills.
    I saw it mentioned above, but don't forget to tighten the clamps only tight enough. I know, that always sounds so odd to say/hear.
    If you crash, the looser lever can rotate around the bar instead of being more prone to breakage, and you can roll it back into position (with force of course).
    On my dirt bike clamps I dab them with blue loctite so I don't risk vibration backing the bolts out. Not a bad idea to take your wrench to the clamp bolts once in a while, especially after you've made an adjust like this, just to make sure they were in fact tight enough.
    Professional Slacker
    Old habits from V-brakes where it took more than one finger.
    We're not using one finger to brake to show off how awesome our hydro disk brakes are, we're using our index finger to brake so we can have our ring finger gripping the bar. Your index finger is typically the strongest, then the ring finger, then the last two are pretty worthless for grip strength. Two fingers around the bar, not very secure, three fingers around the bar, very secure. Secure=confidence inspiring=confidence=good riding
    high pivot witchcraft
    Reputation: mtnbkrmike's Avatar
    Mar 2015
    All this talk about brake levers...
    Where's tealy?
    Threaded
    Jun 2018
    Quote Originally Posted by richde View Post
    Loctite sounds like a good way to go for that Forest Rider.
    Richde a legacy from past V-brake days, I think you've nailed it. I think the guy who set it up was a road rider too so he might not have known about the new mtb braking method. And you're right, when I was using the last two fingers to grip they were very weak and it almost felt like I had no grip at all. That was causing insecurity to the point I started researching pads when I got home lol.
    On the small ride I just did the middle finger made a world of difference, I have proper grip now. Can't wait to get back out there, even with my bad grip I was grinning as soon as I hit the trail.
    Reputation: bvibert's Avatar
    Mar 2006
    Quote Originally Posted by Vader View Post
    I thought I was the only one. Whenever I tell someone that I use my middle finger for one finger braking they look at me like I have 3 heads.
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Yeah man, is Tealy still around?
    Bikesexual
    Quote Originally Posted by Nat View Post
    He is hiding, building his next engineering project.
    Carbon awesome strap?
    Surly Krampus
    All City MMD
    Kona Unit
    Reputation: tom tom's Avatar
    Quote Originally Posted by Phillbo View Post
    Because of the clutch on your bicycle? And do you pull up on your left pedal every time you pull on your left lever to up shift?
    I Pity The Fool That Can't Ride A Bike Without A Dropper!!
    XC iconoclast
    Reputation: richj8990's Avatar
    Apr 2017
    Quote Originally Posted by sturge View Post
    Actually, if he has cheaper stuff like Shimano M335 or Tektros, two fingers may be needed. A large percentage of people on here still have lower-end bikes and brakes, larger than you might imagine. At the Deore/SLX/XT level and above, then yes, one finger, but cheaper stuff is often two fingers. And I'm not even overweight, I'm only 150 lbs and sometimes I need to use two fingers.
    XC iconoclast
    Apr 2017
    SRAM braking system is all he needed to say...
    XC iconoclast
    Apr 2017
    Bob, if you have an issue, I would recommend talking to Klurejr before anyone else. Certain moderators can go off the deep end on contentious issues, so just let Klurejr know this, he's probably the most objective one about that kind of stuff. If there is a real problem I'm sure he will talk with them privately.
    And ditch the SRAM brakes, get Shimanos.
    Quote Originally Posted by richj8990 View Post
    Yes one, two or three fingers its personal preference. When I ride I always cover both levers with my index finger but when I need to brake hard I quickly move to two fingers.
    XC iconoclast
    Apr 2017
    Quote Originally Posted by tom tom View Post
    Not to hijack this thread or anything...
    Amazon is selling Shimano Deore M615 front/back pre-bled, plug and play for only $77 total. Best brake deal of all-time. But they are moto-style. That is the only reason why I have not purchased them yet. I just don't want two bikes with one normal brake setup and one that has the brakes reversed; if both had moto-style, OK I could get used to it, but you don't want to be distracted with remembering that kind of stuff going downhill.
    Oct 2018
    I think that is how I ride. I have pictures of me with fingers over the levers quite a bit. I don't even realize I'm doing it. People ask how many fingers I brake with and I don't know how to answer it -I do whatever my brain said. I did see in one of my GoPros that my index finger was over the lever, but it seems like I do reach for 2. That's probably just the old dirt bike/v-brake habits I haven't totally broken yet.
    Aug 2018
    with modern disc brakes you should really only need one finger.. if you set the braking system up right / right for you size..
    I'm well into clyde territory standing 6'3" and 265lbs~ I run XT brakes with a 203/180 front /rear RT86 rotors and J02A pads.. for me on even the steepest runs (i am willing to do) I can get plenty of stopping power with 1 finger braking .. adjust levers if needed to be able to comfortably get index finer on lever comfortably.
    for me.. if I can't 1 finger brake on a bike... I'm changing the brake setup so I can..
    Oct 2018
    I am probably going to change my Sram brakes on the Chameleon to Shimano SLX. My FSR has the M615's. After getting off the Sram bike, I realize how good the M615 is but I still want better braking. I'd like to put XT on the FSR.
    I considered moving the 615 to the Chameleon and going XT on the FSR but not sure I'm up for grafting the 615 to the Chameleon.
    I haven't been able to figure out if the Sram Level T brake is weak, or if the design is just so different that it feels week compared to the Shimano. If I don't ride the FSR for a few rides, I act like a new-to-disc brake user with the jerky braking action.
    In general the brakes do in fact slow me down but I am used to slowing down more quickly without hesitation. Perhaps the 2.8 tires contribute to slower braking because of the surface contact area.
    I don't think I require additional force (extra finger), I think it's just their weaker/modulated action that my brain has yet to adapt to.
    I am unable to find the Amazon brake identified as reverse (moto) for $77. I've seen a good price on a "front" or a "rear" but not identified as "left rear".
    And not as a "pair" if that is what you meant by saying $77 total.
    No known cure
    Quote Originally Posted by targnik View Post
    'Born to ride!'
    Alteks are a huge step up from Shimano for V levers, and like I posted, I use one finger, just the middle instead of the pointer finger. Those levers with Avid Black Ops Vs and ceramic rims are top shelf.
    Threaded
    Jun 2018
    richj8890 thanks for all suggestions. The vast majority of forum members are nothing but helpful and positive, they greatly outnumber the occasional sh-tstirrer having a bad day. And as long as I'm allowed to give as good as I get regardless of pecking order I'm happy
    I've also heard criticisms of the SRAM brake oil which apparently has poor longevity. Power-wise they seem excellent to me but I'm not exactly riding balls-to-the walls yet.
    Cycologist
    You can swap them. At least one will probably need shortening anyway and if you're careful, you don't have to bleed them.
    I'd ride the Srams until there there's an issue with them, then buy Shimanos; that's what I did.
    I swapped to right front a long time ago mainly because I'm right handed and it made so much sense. Much better to have the dominant hand on the front lever IMO.
    Mike T convinced me to do it. https://forums.mtbr.com/brake-time/e...ght-51378.html
    Mike T 2004
    "Yeah probably.
    The tendancy is for N. American bikes to have left/front braking and for UK bikes to have right/front braking. I'm not quite sure where all the other countries of the world fit in.
    I've read many "reasons" for why this is and most of them somehow seem to center around hand signals. That reasoning, if it's even a viable reason, has very little to do with mtb'ing does it?
    I'm in N. Am (but I am from the UK) and I have mine right/front. To me I have sound reasoning for this. I'm right handed and if I have one hand in charge of any brake while I wipe, point, wave, drink, adjust, pick, hit with my dominant (right) hand, that hand isn't going to be in charge of a brake that's got the ability to send me into a Superman impersonation. Nossirr my left hand is going to be in charge of a brake that has the abilty to skid a tire at worst."
    Right front is also more popular.
    https://forums.mtbr.com/brake-time/b...can-38801.html
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Travis Bickle View Post
    Mike T 2004
    "Yeah probably.
    I'm right handed and I do some of the things Mike T mentions with my left, possibly unconsciously for that reason. Usually I'm not waving or drinking if I'm in any sort of sketchy situation though.
    Anyway, I think whatever you're used to is all that matters, left front brake has never caused any issues for this right hander.
    I brake for stinkbugs
    My braking improved after a nervous transition period. Never crashed during that time, but I had to talk to myself out loud.
    Meatbomb
    Uh no...I'm just use to grabbing the front brake with my right hand from years of riding moto....
    Mike T 2004
    "Yeah probably.
    It also makes more sense to do everything non-bike related with your left hand in order to be able to shift while you're fumbling with a wrapper or whatever. But I'm not going to swap my levers on multiple bikes because when it comes down to it, I'm going to drop whatever I'm doing to panic stop and the rear brake does a fine job in any situation where I'd be riding one handed.
    Jan 2009
    When I built bikes at my last shop, we spaced lever clamps 25mm from the end of the grip on most bikes, 15mm on woman-specific bikes. All handlebars were rotated so the grip area is level and the levers are pointed down at a 45 degree angle using an angle finder. That part of the bike build took an extra 60 seconds, if that, and was worth it to give the customer a consistent experience. That way, people got decent braking and could test ride several bikes with a similar experience.
    Bike shops that slam levers in any which direction are doing their customers, and therefore their business, a disservice.
    Quote Originally Posted by mack_turtle View Post
    When I built bikes at my last shop, we spaced lever clamps 25mm from the end if the grip on most bikes, 15mm on woman-specific bikes. All handlebars were rotated so the grip area is level and the levers are pointed down at a 45 degree angle using an angle finder. That part of the bike build tool an extra 60 seconds, if that, and was worth it to give the customer a consistent experience. That way, people got decent braking and could test ride several bikes with a similar experience.
    That is where my levers are, with my hands positioned toward the end of the grip, that IS the one finger braking position we're talking about. If I choke up on the grips, I can use two fingers, but at the outside of the grips, it's one finger only.
    Shallower angle, but not the point.
    since 4/10/2009
    Reputation: Harold's Avatar
    I've seen it done both ways in shops. Some shops make those little setup details a priority, and others don't GAF. When I built bikes in shops, it was for shops that prioritized those details. So I always checked the little cockpit setup details. It grates on me when I walk into a shop and see the brake levers all over the damn place, saddles not level, and that sort of stuff.
    Jan 2009
    Quote Originally Posted by Harold View Post
    That's the difference between a shop that makes money and a shop that goes under.
  67. #67
    Oct 2018
    Are the controls on the bars from the factory, then a shop will take time to adjust them or does the shop install the controls?
    I've only purchased one new bike.
    I'm a familiar face in the shop I purchased the bike from. But each of the 3 I visit know me. I have not been into a shop that doesn't go above and beyond. The guy who assembled the bike went over a few things with me but also knew I am capable of making my own personal feeling tweaks. I feel confident in saying they would help set up a customer if they are new to riding a bike.
    I purchased my first bike used and went in to ask a question about something. I don't even remember now.
    Shop dude had it on the stand and went over the bike with minimal effort. I hadn't been on a bike since I was a teen (many years prior).
    One of the shifters were lazy, he lubricated both of them. Checked shifting and made slight adjustments. All the stuff I consider "standard" from my experiences of my local shops. I think my initial question was for the blown out fork and what my options were to fixing them.
    Each time I've wheeled my bike to the shop for random stuff they always find something they would routinely update. Once I had a guy about to adjust my derailleur and I asked not to. I had it dialed for shifting well on the ride, but it didn't shift as well on the stand. Not bad, attempting to check/make adjustments when the bike wasn't in for that.
    Anyway -I wonder what it would be like to swap brake levers. I've ridden dirt bike for 25+ years and don't feel like I have ever got confused about bicycle brakes. My bike friends asked me when I first got a MTB if I would switch? I looked at them with a confused look on my face to ask why in the world I'd do that. Even from the beginning I never noticed an awkward feeling.
    I'm not going to swap for testing purposes but I do wonder what it would be like. Especially since I like my front brake to engage sooner than the rear brake.
  68. #68
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I am going to pop in here and also say that as this is a new bike (I think that is what I figured out) it will take some time for the brakes to bed in. They will develop more power over a few rides. So you might also just be suffering from green brakes. Once they bed they should have more grip and more modulation. Otherwise brake set up is fairly specific. I like to run my brakes also perpendicular on the bike but others ride with them at a 45į angle to the ground or somewhere in between those. Your fingers should rest naturally on the brake lever, you shouldn't be reaching up or having to roll your hand to grab the lever. I would fiddle around with the shifter location and the brake lever to see if there is a sweet spot for your hands. I also have a tendency to have right and left hand discrepancies as well to account for my preferred braking style (I also ride rigid only so my style is a little different than a suspended bike).
    MTBR Posting Guidelines
    calories>electrons
  69. #69
    I do.
    Sinister Bikes
    Wraith Bicycles
    Sunday River Mtn Bike Park
    NEMBA
    Wachusett Brewing Co.
  70. #70
    Yup. Any competent mechanic would set the brake in that general position as a start.
    A good bike shop will take a few minutes of a sale and help dial a bike in for their customer also.
    Same with a good auto dealership. The place my wife has bought her least two vehicles spends a good chunk of time going over how to operate and adjust everything, right down to linking her phone and downloading contacts, music and apps to the car system, making sure she knows how to operate the handsfree stuff, etc etc. Of course, it's a Caddy dealership, not the local econobox lot, so they operate on a pretty high level.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  71. #71
    Self Appointed Judge&Jury
    Oct 2000
    Move the levers in until the end fits well with your index finger. The index finger [in combination with middle finger, for some] is all you should need if the brakes are working properly.
    Common sense goes a long ways in every aspect of life. Either way, good advice for those going through life confused.
    BTW-I added in and bolded what I thought you missed. Once again great advice.
  72. #72
    Bikesexual
    Brakes are overrated.
    Surly Krampus
    All City MMD
    Kona Unit
  73. #73
    Jan 2009
    Any competent bike mechanic would test ride a new bike and bed in the pads before putting it on the sales floor. Just saying.
  74. #74
    Threaded
    Jun 2018
    Travis Bickle here in Australia at least all road, hybrid, and mtbs seem to have front brake on the right. SlapHeadMofo lol well played.
    Talking of good and bad bike shop setups, think I need to shorten the cable housing for the dropper post: How To Hold Brake Levers On Trail Ride-dropper-cable-2.jpg
  75. #75
    XC iconoclast
    Apr 2017
    It seems like they are all going under one by one.
    I have to drive 30 min now, used to drive 10 min. Both of those closer shops closed.
    I don't think it's the quality of the repairs, you guys probably go to the LBS only rarely, and I now can do all the basic stuff, maybe go to the LBS three times a year for various installations.
    It's the cost of the bikes they sell that is killing them. I get that people don't buy Chinese, parts because it either directly or indirectly helps American/Western bike manufacturers but the price difference is huge. The shops that are staying open in my area often tend to be repair only and have a really low overhead. I looked at the Performance Bike 25-40% closeout sales, and not one bike came even close to being worth buying, even at that discount. I looked at my bike that I half-assed built up for under $1000, and most parts are the same as on their $2500 bikes, and a lifetime warranty on that $2500 bike means nothing if the shop closes. If I would have done 1x11 for a couple hundred more I'd have almost the same exact bike they are selling for 1/2 the price. Too big of a price difference for them to survive long.
  76. #76
    Reputation: DethWshBkr's Avatar
    A bike shop can set anything up any way they want. The entire bike comes apart and gets put back together by ME before it gets ridden seriously.
    Learning how to hold the bars and levers is totally dependant on your own feel and preference. I am very picky on my lever feel, rotation, and inboard clearnaces. Back in my moto days, I was the same way. Brake/clutch/throttle, very picky.
  77. #77
    Oct 2018
    Quote Originally Posted by DethWshBkr View Post
    Why do you fully disassemble?
    Please answer something better than "because I know it was put together properly"
  78. #78
    No, he's right when it comes to hydro brakes. If that is insufficient, fix your brakes.
  79. #79
    Oct 2000
    I didnít say he was wrong. I meant some like the two finger technique over the one finger. Both should be sufficient with good hydros. I grew up riding dirt bikes and always used the two finger technique, it transferred over to mountain biking due to what I was used to. Iíve also used the one finger technique which worked fine but Iím more comfortable with the two finger technique.
    Another thing is how you set up the brake lever position rotation on the bars. I prefer the levers to be slightly pointing down. Way more comfortable in the stand up ďattack positionĒ, which is critical when you are going Mach I through the tech. In the sitting down spin position that lever position is not as critical.
  80. #80
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    *waits for ninjichor's professional engineering response*
    Salsa Timberjack | Salsa Cutthroat
  81. #81
    Why it's more advantageous to use one finger has been covered several times.
    If you're not comfortable with one finger, as you noted, that is your problem. The reality is that one finger is enough.
    After discovering the shifter and rear brake aren't controlled by your feet, I decided to toss out worrying where motorcycle controls were and how they worked and figure out how to best utilize bicycle controls. YMMV
  82. #82
    Jan 2009
    Only on MTBR would people fight over how many fingers to use on a brake lever, dragging in "engineer" credentials to make the point. Get over yourselves.
  83. #83
    Oct 2000
    I didnít realize I was in an argument until I saw Riches last response.
    Why the hell are people so uptight on here? Pretty sure I only confirmed in my last response that one finger was enough but I prefer two. Just a preference is all, jeez.
  84. #84
    2 finger's on the rear brake and 1 on the front. All the best bike shops set up the levers for that method.
  85. #85
    Remove the brake hose from both levers and switch them to bicycle style.......
  86. #86
  87. #87
    jcd's best friend
    May 2016
    I ditched my Shimano XT's for SRAM Code R brakes.
  88. #88
  89. #89
    No known cure
    That's what we do. Every new bike and every repair gets a spin around the large parking lot and down a flight of ten stairs to check shifting, braking and suspension. Every bike sold is fit to the rider and givin an invite to ride.
  90. #90
    No known cure
    Here's one finger braking with V brakes using the middle fingers during a race. (2nd place single speed open)
    Attached Thumbnails Attached Thumbnails How To Hold Brake Levers On Trail Ride-img_20181221_205705564_hdr.jpg
  91. #91
    Up In Smoke
    Feb 2005
    Dude, youíre ripped! You expect average joes to pull that off?
  92. #92
    Threaded
    Jun 2018
    Here's one finger braking using the middle fingers during a race. (2nd place single speed open)
    You are a machine riding a machine. How many inches is that front tyre, 3.5?
  93. #93
    No known cure
    2.4
  94. #94
    Two finger braking went out with v-brakes.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  95. #95
    No known cure
    Quote Originally Posted by langster831 View Post
    The kid that beat me was 18 and I'm 48. He was on a 29er; me on a 26 with a hangover in 100* heat. Not too bad.
  96. #96
    Threaded
    Jun 2018
    Quote Originally Posted by slapheadmofo View Post
    More machines!
  97. #97
    It is kinda funny, since that's exactly what you did here:
    "When I built bikes at my last shop" nice appeal to authority. But putting bikes together does not mean you have mastery in their use, so basically....who cares. Just like when you mentioned ""engineer" credentials."
    The funniest bit is that you obviously read the thread and without even checking anything, you made a gross assumption about "slamming" levers this or that way. When you mentioned 25mm from the grips, instead of instantly jumping to attack with ignorance (like some people), I calmly walked over to my bike and discovered that my brake lever was 24mm away from the clamp of my ODI grip, which puts the Shimano lever in my preferred position for one-fingered braking. If I choke up on the grip I can put two fingers on it, but I don't ride like that.
    So what you ended up doing is to attack people and then basically agree with them. Nice. What really does a shop disservice is to hold onto dogma SO hard that if an "out" group says something, they reflexively disagree, if only to ultimately agree without even knowing it. That's the kind of shop that people mention as "those guys are idiots."
    Here, in this thread, you're the kind of poster that argues that someone is wrong, by arguing FOR what they said, and then complains about people arguing after it's been pointed out. Do a little research next time.
  98. #98
    Sneaker man
    Reputation: mik_git's Avatar
    This is an issue I had, riding two bikes regularly, one with V's the other just went from V's to XT disc, I found the Discs horrible (hadn't had an issue running juicy 5's a few years before), they were grabby and just sucked... then one day i discovered when you only use one finger ... oooohhh.
    I'll still switch to 2 fingers, but only if I'm riding something harder, have some fad or I'm just knackered, but it doesn't feel good on the grip, but i'm hanging on for all I can at that point.
    All the gear and no idea.
  99. #99
    Quote Originally Posted by mik_git View Post
    Might be the reach adjustment, move the lever in, so a solid effort (not as hard as you can squeeze, but as hard as you squeeze while riding) leaves the lever parallel to the bars.
    My last two sets of XTs weren't grabby, and neither are my Saints, and they are SIGNIFICANTLY stronger than XTs.
  100. #100
    Sneaker man
    No it was because I was 2 finger mashing them like I would my v-brakes, i switch to 1 finger and it was perfect.
  101. #101
    Oct 2000
    Iíve got your finger.
    And some food for thought. The one finger vs two finger technique debate. It also depends on your lever shape. I run Hope brakes with stock levers and if I were to use one finger the shape of the lever as it is pulled in hits my middle finger thatís gripping the bar but with two fingers I have no hinderence of any other finger thatís gripping the bar. Good for me because two finger braking feels much more comfortable and more in control than one finger. I know someoneís going to say the shape of the lever doesnít matter itís about moving the levers inward or outward on the bar to fit your technique which is also true for many shaped levers. But my factory Hope brake levers are shaped more conducive to two finger braking.
  102. #102
    Did someone weld your levers to the bar?
    Listen, you can say you like to run marathons backwards, but the ability to run backwards for 26.2 miles doesn't mean that running forward isn't more efficient.
  103. #103
    Oct 2000
    Did you actually read my post or just pick out what you wanted? You have been very uptight not only in this thread but in a few other ones Iíve noticed. This after all is supposed to be a discussion forum of an audience that all enjoy the same recreational activity among other things in common. Letís try to keep the tactless remarks out of it and treat others as you would like to be treated.
    Now, what exactly is your issue with my last post again? Try to read the whole thing and absorb what I was saying before you respond.
  104. #104
    cmg
    cmg is offline
    passed out in your garden
    Reputation: cmg's Avatar
    Mar 2012
    Did you actually read my post or just pick out what you wanted? You have been very uptight not only in this thread but in a few other ones Iíve noticed. This after all is supposed to be a discussion forum of an audience that all enjoy the same recreational activity among other things in common. Letís try to keep the assholish remarks out of it and treat others as you would like to be treated.
    I dont wanna cause problems or nufin' but l think he doesnt like you, fight! fight! fight!!
    back on topic, I am mostly a 1 finger braker, but on long downhills l switch to 2 fingers eventually, mostly a mix of of brake fade a finger weakness
    btw lm working on finger weakness with masturbation
    always mad and usually drunk......
  105. #105
    Oct 2000
    Quote Originally Posted by cmg View Post
    Not just me but other threads heís been very defensive towards other members posts. Tension I tell ya, tension.
    Keep working on that last part, itíll come in time.
  106. #106
    cmg
    cmg is offline
    Mar 2012
    itíll come in time.
    I see what you did there
  107. #107
    Fat and bouncy
    Reputation: JackWare's Avatar
    Aug 2016
    After 100 posts this thread is finally worth reading.
    What a perfect waste of time
  108. #108
    I did read it. You said your lever hits your finger.
    If your lever hits your middle finger move it in on the bar and it will be the proper shape for one finger braking, adjust the reach while you're at it. Problem solved with obvious solution. I think you were aware of that...to think otherwise is insulting.
    But you don't want to change because, and this is common here, you decided to plant a flag at some point and say "this is the best, I will never change." Do people actually think that nobody who uses a new part/technique/design has never tried earlier parts/techniques/designs and found the new one superior? We weren't born using this stuff, we just happen to be open minded enough to give new things an honest shot.
    I could drop it, or you could drop it. But honestly, I'm interested and entertained by how people will twist around to justify a silly position.
  109. #109
    Pipe Dreamer
    In DJ's defense, his brakes were made when V-brakes and two finger braking were still popular, they're designed to be used with two fingers.
    This space intentionally left blank. We apologise for any inconvenience.
    Vote for the Picard as mod!
  110. #110
    Oct 2000
    Itís obvious you didnít read it and absorb it so Iíll bold what you missed.
    After bolding what you missed I should have just bolded the whole post.
    I never ďplanted a flagĒ so to speak and said ďthis is the bestĒ. Another thing you made up. Go back and read all my posts and you will see I have tried both ways, one finger, two finger. I prefer two finger, thatís all I ever said. I never claimed it to be the best. All riders have different techniques in all aspects of riding. Whoís to say one technique is better than the other. Itís the riders choice. Trying both I still prefer the two finger technique. Maybe because Iím 57 years old and have used the two finger technique from riding dirt bikes from age 8 and beyond. I became used to it. The one finger technique feels foreign ďto meĒ. Why do you insist in arguing with me when Iím not arguing back. Only stating what my experience is and my choice. Your arguing goes far beyond this thread and me. Iíve noticed your anger in other threads to other members who disagree with you.
  111. #111
    "I became used to it. The one finger technique feels foreign ďto meĒ.
    That's planting the flag, and not the point of the thread.
    Like I said, if you want to run marathons backwards doesn't mean that's it's the most efficient way to do it or a good "how to" suggestion. A whole lot of people have transitioned from two-finger to one and found it superior. You simply do not get the same level of control on the bar and the lever with two fingers on the brake lever and two on the bars. Something nobody has argued against.
    Maybe you don't want to improve, many do, and bad advice is counterproductive. Your age has nothing to do with it, nor does riding motorcycles, those are excuses. It's not anger, it's amusement, don't project your feelings on others.
    I find riding well enhances the experience, ymmv. Others are happy to wobble around a couple times a month.
    Maybe this forum needs a "Get off my lawn" subforum so people have a safe space to enjoy their resistance to change. The first thread could be "At what point did everything new become worthless."
  112. #112
    Oct 2000
    Hmmm. . .maybe, all I know is your ugly is showing again.
  113. #113
    Cycologist
    On my hydros, I use one finger. But my hardtail has BB7s and they are a bit grabby. I can brake with one finger but by using two, I'm better at feathering them lightly and avoiding a grab.
  114. #114
    Jan 2009
    If pulling your brake lever with one finger results in less than awesome braking, you have sub-par brakes or you have them set up in an irrational way. If that suits you (having shitty bike parts and being a moron), go for it! Otherwise, do something about it and stop being defensive when someone points out that you are doing something foolish.
  115. #115
    Reputation: richardjohnson's Avatar
    Sep 2016
    I use no fingers on my brakes. It is the only way to be fast. I also don't use a chain. Also the only way to be fast. Chainless and brakeless are the only way to go through life, son.
  116. #116
    In other words, your way is the right way and any other way is wrong. Uhhh...okay...
    The longer a ride lasts, particularly one that has a lot of tech and/or DH, the more likely I'll find myself running an extra finger on my rear brake lever.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  117. #117
    I use 1 finger sometimes but usually 2 because I'm a fool. Also I'm comfortable with it. If you disagree you're wrong.
  118. #118
    jcd's best friend
    May 2016
    Quote Originally Posted by richardjohnson View Post
  119. #119
    Bikesexual
    I use 3 anyone got a beef with that?
    Surly Krampus
    All City MMD
    Kona Unit
  120. #120
    Sep 2016
    Brakes or no brakes I just send it:
  121. #121
    jcd's best friend
    May 2016
    Quote Originally Posted by jcd46 View Post
    I do! Start a new thread about it though.
  122. #122
    Oct 2000
    Thread winner.
  123. #123
    Up In Smoke
    Feb 2005
    Nope, but youíre riding cleanup
  124. #124
    Projecting again?
    The consensus is that X is superior, you like Y.
    You can like Y, you can enjoy it all you want, but that does not mean it is better. When you veer into Y is better, you're not only the one arguing, you're making a bad argument. If there were fewer bad arguments, there would be fewer arguments overall.
  125. #125
    Fat and bouncy
    Aug 2016
  126. #126
    Projecting again?
    I remember when the consensus was 20" bars and 10" stems were superior.
    Some of us had bad arguments that 'Y' was better.
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  127. #127
    The consensus and the evidence, the evidence ultimately being more important. But blanket statements suck and so do arguments based on semantics.
  128. #128
    Threaded
    Jun 2018
    Oh damn the two finger ride of shame.
  129. #129
  130. #130
    Cycologist
    Anybody else brake with their thumbs?
  131. #131
    Fart smeller
    Nov 2003
    Quote Originally Posted by Gasp4Air View Post
    I'll add:
  132. #132
    Apr 2014
    I generally use 1 finger, but on rougher trails I sometimes switch to using my face.
  133. #133
    Pipe Dreamer
    Adjust your leevers, it's so simple!
  134. #134
    Fat and bouncy
    Aug 2016
    But I can't see how many fingers they're using. 🙁
  135. #135
    Oct 2000
    Now remember class, thereís only one way to do things and thatís the correct way. As taught to you by the one that does everything the correct way. Mr. Richd our class president.
    Richd, youíve got the floor now.
  136. #136
    Bikesexual
    I dunno but I've had a few laughs!
    Surly Krampus
    All City MMD
    Kona Unit
  137. #137
    jcd's best friend
    May 2016
    It's been a great off-season this year!
  138. #138
    EMBA MTB Lead Instructor
    Reputation: Thustlewhumber's Avatar
    On my 86 Trek with canti's I use my middle and ring finger while holding the bars with my index and pinky.
    Life is easy. Figure out the price of whatever it is you want, then pay that price.
  139. #139
    Threaded
    Jun 2018
  140. #140
    Fart smeller
    Nov 2003
    Quote Originally Posted by Thustlewhumber View Post
    Hmph. I'm just the opposite. \../ \../
  141. #141
    Oct 2018
    I prefer 2 fingers for the front brake and one finger for the rear.
    I only ride like that because I always try making everybody somewhat happy.
  142. #142
    Oct 2000
    It made me somewhat happy until I saw your last sentence.
  143. #143
    Trail Rider
    Reputation: mlx john's Avatar
    The Missile
    2020 Turbo Levo SL Expert Carbon
  144. #144
    Oct 2000
    With no gloves.
  145. #145
    Trail Rider
    Projecting again?
    Gloves are so Y...
  146. #146
    Oct 2018
    I only wear gloves when it's cold, and that just started this winter season (California winter).
    Its weird because on my dirt bike I'm all protected up and it feels so odd throw a leg over when I'm not wearing only one item, chest protector or gloves or knee guard.
    On the mountain bike I hurl myself down the chunk in a short sleeve and shorts and feel out of place if I wear something additional.
    It's all about what we get used to as our own "normal".
    I think I've been riding for 9 years? Maybe almost 10?
  147. #147
    Oct 2000
    I should talk. Iíve wore full gloves in so many sports , MX, stand up jet skiing etc. But for some reason full finger gloves feel strange while on the bike. Iím a half finger glove wearer all the time weather permitting. Some winter rides Iím forced to throw on the full finger, but I hate it. One thing I will say is I have to have gloves on while mtbing.
  148. #148
    Reputation: dbhammercycle's Avatar
    You can skid out the best with a coaster brake. How many fingers does a coaster brake use?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
  149. #149
    Oct 2000
    Quote Originally Posted by dbhammercycle View Post
    Zero, but you do need a two feet. Miss those old brakes.
  150. #150
    I think I could coaster brake one footed back in the day.
  151. #151
    Mar 2015
    That's it. I'm summoning tealy. This thread needs greater brake lever expertise.
    Done.
  152. #152
    Oct 2000
    I knew I shouldnít have went with the two foot excuse. Always a glitch found.
    And yes I do believe I probably attempted that back in the day via a Schwinn cruiser model as I was getting off to throw a newspaper onto a door step at age 12. Many a freestyle move was thrown into my paper route. Always in a hurry to get back home and hop on my dirt bike, so I could tear up the local trails until dark.
  153. #153
    Reputation: tealy's Avatar
    Mar 2013
    okay
    "You can be clipped in and be boring or ride flats and have a good time." - Sam Hill
  154. #154
    No known cure
    Quote Originally Posted by tealy View Post
    There are two legitimate reasons why you would brake with two fingers.
    One, you're running cantilevers and you need all the power you can get. Two, you're running modern brakes and you're an idiot.
    Want to know why one finger braking is king? Grab a broom stick in both hands. Put two fingers out on each hand like you're braking. Get someone to yank the broom stick out of your hands. Hard to hold on right? Now grab the broom stick with both hands again. Put out your index finger on each hand. Get someone to yank the broom stick again. Easy to hold on. You're middle finger is your strongest finger so you want that bad boy wrapped around the bar when you're shredding the gnar.
    If you feel like you can't get enough braking power out of one finger, then either you need to ride more to build finger strength, need better brakes, or need your brakes cleaned/adjusted.
    However, modern brake levers are STILL designed for idiots who use two finger braking because lord knows why. So even if you move your lever to the proper position for one finger braking, your lever is at a weird angle under your finger which will never feel right. We have yet to see mass adoption of a technically correct lever. (Refer to my avatar.)
    In fact, three finger braking (middle, ring, pinky) is even superior to two finger braking because you have a better hold on the bar with just your index and thumb than you do with your pinky, ring, and thumb. And when I was a kid this is how I rode bmx until I picked up an mtb magazine and saw downhillers rocking index finger braking.
    People who middle finger brake are like OGs or weirdos. Yeah you can still hold the bar ok but I feel like you've got less motor control with the middle finger braking compared to the index.
    But the winners are people who can ride brakeless because that's 100% badass.
    I've never used two fingers for braking, even with cantis or V's. I've always used just my middle finger. My single speed has V's and it one finger only, even in the wet. They are a bad ass set up though. Altek levers, Avid Black Ops arms and ceramic rims These have more power than my GF's Magura Martas.
    Attached Thumbnails Attached Thumbnails How To Hold Brake Levers On Trail Ride-img_20190121_155913533.jpg
  155. #155
    From an "instructor" standpoint, I usually have people grab their grips with all their fingers and tell them to lift the bike by the handlebars. Then remove their index finger and lift... then remove the middle finger and lift... then the ring finger (lifting only with the pinky). Try it yourself.
    Modern disk brakes don't require any more than the force from your index finger to stop. If your middle finger is on the bars, you have the absolute most control over your bike handling, using your index finger to modulate the brakes. The reasoning is that the middle finger is the strongest, followed by the index finger.
    If you are using your middle finger to brake, you run into three issues - 1) your brake lever usually hits your index finger, 2) your middle finger is actually too strong and will cause your brake feel to be "on/off" instead of modulating (like a dimmer switch), 3) you don't have as much control over your bike, which will lead to arm pump - which will lead to bad form - which will lead to bad riding because you are overly tired. Btw - Missy Giove using her middle finger to brake (in the image above) almost went over the bars during that race run.
    Two finger braking is also too much - which leads to excessive "oh shit" moments where you are grabbing the brake too hard. Its just as bad as not covering your brakes at all. Two finger braking is really not necessary on bikes that are 30 years newer, and its an extremely bad habit that needs correcting to progress your riding.
  156. #156
    Bicyclochondriac.
    I run my lever pointed pretty far downward. Like 60-ish degrees down from horizontal.
    I also adjust the reach so the levers are very close to the bar.
    I have been going one-fingered pretty much ever since I switched to v's from cantis 20 years ago. I did not realize just how ingrained it was in my brain until I rode with lobster gloves a few weeks ago.
  157. #157
    Quote Originally Posted by thustlewhumber View Post
    lol!
    Sinister Bikes
    Wraith Bicycles
    NEMBA
  158. #158
    Oct 2018
    I wish I knew how many fingers I used while braking.
    A recent picture I had one finger, in older pictures I think I used 2 fingers. Different bikes.
    I wish I could get out of my head and remember this thread when I'm bombing a descent. Then I could come back to accurately update this thread.
    I think what happens when I'm bombing a hill instead of thinking of this thread is doing what feels natural with my braking efforts.
    I wonder why I am one of few here that can't remember what my braking technique is, unlike all you guys.
  159. #159
    Bicyclochondriac.
    The fact that we are debating one vs two fingers is a really good sign.
    When I first started trail riding back in the days of cantis, 4 fingers was not uncommon for me. If I had more fingers I would probably have used them.
  160. #160
    One ring to mash them all
    Mar 2015
    Probably thinking too hard about your attack position.
    "Extraordinary claims require extraordinary evidence." - Carl Sagan
    Real eyes realize real lies.
  161. #161
    cmg
    cmg is offline
    Mar 2012
    left side two fingers, right side one finger ( l need the other finger to control the volume on my bluetooth speaker)
  162. #162
    Oct 2018
    Quote Originally Posted by the one ring View Post
    I know -leave me alone. Just want riding a bike to be comfortable.
  163. #163
    Threaded
    Jun 2018
    Yes!!!
    It's not your bottom bracket
  164. #164
    Threaded
    Jun 2018
    I use a pencil, and a biro for the really techy downhill stuff...
  165. #165
    No known cure
    I've been riding and racing since 1985 and I'm not about to change my braking style. It's worked for two state DH titles, numerous podiums and I've never once even thought about my hands coming off the bars. I crave technical riding and it's always worked for me. I've never had a problem with modulation or the lever blade hitting other fingers. At the end of the day, I'm still braking with four fingers wrapped around the bar. It's not something I've ever put much thought into except when building a bike for someone else or instructing. Then I'll always go with the pointer finger.
  1. Replies: 0
    Last Post: 06-24-2012, 08:53 PM
  2. Replies: 6
    Last Post: 01-06-2012, 09:34 AM
  3. Cantilever levers vs v brake levers
    By Potential Roadkill in forum Brake Time
    Last Post: 11-21-2005, 02:36 AM
  4. mtb brake levers vs bmx brake levers
    By austinb89 in forum Downhill - Freeride
    Last Post: 11-15-2005, 03:54 PM
  5. Replies: 3
    Last Post: 07-08-2004, 12:04 PM
