Help me get my pedals off.....- Mtbr.com
Results 1 to 20 of 20
    I am restoring a 22 year old mtb. The pedals wont budge. I am using an allen hex socket attached to a breaker bar. The hex corners are starting to round, so I stopped.
    Ive sprayed it with WD40. I'll try letting it soak a couple of days. Will a pedal wrench work better? I'm afraid to heat the pedal axle lest I melt the rubber seals.
    I'm thinking just take it to the shop. Any idea what to do?
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    You are turning them the correct way right?
    Clockwise on the left side.......counter-clockwise on the right side?
    Try some liquid wrench or a stronger penetrating lubricrant.
    Do the pedals have a wrench flat on axle that you can get a pedal wrench on? or is it only via a hex wrench?
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Definitely use a pedal wrench or f**k off spanner, and make sure you're turning it the right way.
    Yeah, turning it the right way. With the bike upside down, I turn the wrench towards the front wheel like I always do.
    Yes, the pedal has flats for a wrench. I guess its to the bike shop I go for a pedal wrench.
    Thanks.
    Dec 2010
    WD40 is okay for light-duty jobs but sounds like you need Kroil. Amazing stuff!!
    http://www.kanolabs.com/google/
    That and a pedal wrench (the one from Park Tool is good) should solve your problem.
    canuck
    Reputation: Aaron D's Avatar
    Dec 2005
    pedal wrench and a good hammer
    Try PB Blaster, it's a much better break free than WD. Some GENTLE heat never hurts either, especially if you have 2 different types of material.
    The question isn't who's going to let me, it's who's going to stop me.
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    Quote Originally Posted by bing!
    Thanks.
    Turn the pedal toward the back wheel to take the pedal off. Turn it to the front to put the pedal on. Works even when the bike's upside-down.
    Sometimes, I question the value of my content.
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Quote Originally Posted by erik1245
    Uh, wrong. If you're turning the wrench over the top, towards the back wheel turned right side up = towards the front wheel upside down.
    Bro
    Bro is offline
    Dec 2010
    Quote Originally Posted by whodaphuck
    You are quite correct. I was thinking back to last week when I was installing pedals, except my bike was still on its wheels. OP, this is why you don't flip your bike for pedal work!
    and either lay the chain over the chainring or take the chainring off
    Yes, that's fonetic
    Feb 2005
    Well, if you know which way to turn it while upside down, as the OP obviously does, what's the problem?
    Bro
    Bro is offline
    Dec 2010
    It still confuses me. Thusly, everyone has to coordinate with me before doing something suchaswise the OP has henceforth done.
    Yes, that's fonetic
    Feb 2005
    bwahahah! Okay, I'll check with you before my next wrenching session.
    There are two kinds of friction, static (resting) friction and dynamic (running) friction. Static friction is much higher.
    When you get the pedal wrench, try taking a 2x2 piece of wood and smacking the end of the wrench to shock thru the static friction barrier. Think of this like a mini impact wrench (like you see at the tire store). I find that wood provides a nice gental shock and doesn't damage the wrench like a hammer would.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by Stumpy29er
    This + pedal wrench.
    I don't know why people have a hard time figuring out which pedal to turn which way sometimes, the right pedal is right hand threads (regular) & the left pedal is left hand threads (reversed). simple.
    Ride Instigator
    Reputation: Ricko's Avatar
    Quote Originally Posted by stumpbumper
    Second on the Kroil, great product but only available on-line and I believe they'll only sell you a case. WD40 is actually pretty useless, it's an ok cleaning solvent but that's about it. Like others mentioned, PB Blaster or Liquid Wrench Penetrating oils are readily available at your local hardware store, soak it down and let it sit over night, repeat, repeat.
    I had a stuck wellgo clipless pedal, After everything got rounded ( even using a park pedal wrench) I disassembled the pedal, Removed the crank arm, Put the pedal spindle in a vise and use the crank arm to finally break it free.
    ... Now I always use anti seize lube on anything that is dissimilar metals.
    If you can't describe what you are doing as a process, you don't know what you're doing. --- W. Edwards Deming
    Reputation: mullen119's Avatar
    Im pretty sure a pedal wrench is just a 15mm wrench....
    Reputation: Eville140's Avatar
    Quote Originally Posted by mullen119
    This and it works much better, Good 15mm open end and a smack of a hammer should pop it right off. If the pedal is junk, and you can get to the axle from the front with a hammer. Try smacking it lightly, while trying to loosen with the wrench also.
