Floor Pump Recommendations??- Mtbr.com
Results 1 to 11 of 11
    My Scott floor pump has finally given up the ghost. Looking for suggestions on a replacement.
    Silca floor pumps
    You can't go wrong with a Silca floor pump. I've had my Silca for 17 years and it works as well as the day I bought it.
    Go faster
    Reputation: HellMuttCracker's Avatar
    I have had a Serfas floor pump for about 3 years and no problems at all. If you want more info about pumps check out the product reviews
    just along for the ride
    Reputation: Brown_Teeth's Avatar
    Topeak joe blows suck, say no more or i'll =0= on your shoes
    Silca
    Silca pumps are A+ quality. Every shop has one and has probably had theirs for a number of years. Some of the new Silcas aren't quite as nice as the old ones, but they're still fully rebuildable and should be good for life. Just know the typical Silca issues: don't store the pump on its side, don't let it freeze (the leather cup inside will become brittle), and generally don't treat it like one of those $30 "shop-quality" pumps from the other manufacturers. It's a fine instrument - treat it with respect.
    Enjoy the ride.
    [ Chris in MI ]
    I've got a Silca too, Geez,..I thought only roadies loved them.
    Quote Originally Posted by MTBDad
    Now that I'm mostly a mt biker though, I find it's still quite good. The only thing that could be upgraded on it, is the chuck. It's heavy duty brass, but has no fliplock to tighten it on the stem. I've taken to using little washers so the rubber seal will compress tighter when I tighten the chuck's collar, and forget about using them with Schraeder, they're supposedly reversable, but the pin that contacts the Schraeder's core pin doesn't reach properly.
    Ebo
    Ebo is offline
    Nashbar Blue $14.95 @ Nashbar.com (NM)
    Quote Originally Posted by Ebo
    I have had this one for three years without problem. Definately not Silca quality, but worth the money.
    Reputation: limba's Avatar
    Lol.I have a Joe Blow and it's never given me any grief.Works great.Just do a search in the reviews section and you'll find something good.
    http://www.mtbr.com/reviews/Pump/product_22520.shtml
    Do It Yourself
    Reputation: Homebrew's Avatar
    Try to find one with a decent range on the gauge and a decent sized gauge. Trying to get 35 psi with 1" gauge that goes to 300psi is ridiculous. I have a Silca Magnum which is a high volume pump with only 85psi on the gauge. Works great.
    Ride what you want!!
    Reputation: george_da_trog's Avatar
    Jul 2003
    Don't get the Digital Topeak floor pump. It sucks. I've had 2, the first one failed and it was replaced. I've had the second one for a while now and the digital guage is screwy and the thing has a tendacy to leak air.
    george
    Trogs: Too Tough for Carbon Fiber
  1. Singlespeed recommendations?
    By Lighty_ in forum Singlespeed
    Last Post: 03-10-2004, 05:39 PM
  2. Rim recommendations
    By Tony Montana in forum 29er Bikes
    Last Post: 03-08-2004, 03:25 PM
  3. 5th element shock setup recommendations?
    By GeePhroh in forum Shocks and Suspension
    Last Post: 01-12-2004, 09:44 PM
