Fairly simple crank install question...- Mtbr.com
Results 1 to 3 of 3
    DSR
    DSR is offline
    This is regarding the install of a splined XTR crankset onto a splined XTR BB, but basically applies to all splined systems. How can I be sure that I have the cranks properly installed on the spline? You can line 'em up, but can't see in there once you start tightening. I'm gun shy since once I didn't get them properly seated which I found out the first time I really cranked on them and the arm moved. Should it be pretty obvious, like if they're not lined up correctly then the crank threads will appear to "bottom out" after just a couple turns? Thanks for any help. S
    Derailleurless
    Never thought much about it because mine have always gone on so easily (obviously?), but it would seem that either you're not seated (grooves lined up with grooves) and the crank arm would be able to spin around the spindle, or else you're "in the groove" (even if just barely) to where the arm won't spin without taking the spindle with it.
    I can't imagine there is any sort of "inbetween state" in which the splines are only partially engaged.
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Chainline....
    Quote Originally Posted by DSR
    Your manual will show in a diagram what the distance from the seatpost tube to the outside of the outter ring should be in cm's. This tells you if and when the crankset is on the BB far enough.
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. 04 XT crankset install on NRS install question
    By dirt diggler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2004, 08:04 AM
  3. World Class Ti BB install question
    By jbf in forum Weight Weenies
    Last Post: 04-27-2004, 08:10 AM
  4. XT crank and spindle question
    By nab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2004, 12:35 PM
  5. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
