Eggbeater Question- Mtbr.com
Results 1 to 8 of 8
    Reputation: ckropp's Avatar
    Eggbeater Question
    Hey Everyone, I've been using SPD's for as long as I can remember. I just got a set of eggbeater pedals and I'm not sure what do look for to tell if I need the shim. Can anyone give me some sort of concrete thing to look for? If it helps, I have Bontrager RXL shoes and I have a relatively easy time clipping in. Thanks guys!
    -CK
    it's....
    Reputation: Strafer's Avatar
    If you don't have problem clicking in or out, then no need for the shim.
    Quote Originally Posted by Strafer
    Yeah, what he said. I've been using Eggbeaters for 6+ years and am currently riding with Sidi Dominator shoes. I use the thin plastic shim to help get the cleat off the sole a little bit more. If you are able to clip in and out without feeling what would be your sole bottoming out on the pedal, than you do not need shims.
    jesus efen karist!! do i have this straight? you don't have a problem clipping in or out, so you want to know if you have a problem? i think you might. you worry to much buckeroo
    Rebmem Rbtm
    Reputation: claydough001's Avatar
    ha! he said buckeroo.
    He also doesn't know the difference between to and too.
    Rebmem Rbtm
    that's true "too".
    well you knew what i meant. who are you? daniel freakin webster
