Doable??? Swaping Components from a Large frame to a Small frame????- Mtbr.com
Results 1 to 2 of 2
    Mar 2011
    hi,
    i have a 06 specialized FSRxc pro SMALL frame. Just picked up a 06 specialized stumpjumper expert LARGE frame with nicer components.
    can i swap out the forks, shock, brakes, shifters, derailers? pretty much everything but the frame/swingarm.
    will it fit since all the components is from a large frame into a small frame?
    thx in advance.
    Reputation: jmmUT's Avatar
    Fork and Shock depends on the frames and geos of each
    What to watch for are headset, bottom bracket, seatpost/clamp. You may need to replace those, depending. OCuld be different sizes/types
