Do you lower your dropper post when in technical terrain?- Mtbr.com
Results 1 to 39 of 39
    Jun 2020
    I've started lowering my dropper post when in technical terrain. I've found that it allows me to use my legs more as suspension, and when needed, lower my center of gravity. I'm just wondering if I'm crazy here.
    Reputation: Fishwiz's Avatar
    May 2020
    Yes, all the time. My dropper is constantly moving up/down as I transition between tech and short, simple climbs and flat spots.
    Sent from my Pixel 3 XL using Tapatalk
    Reputation: Bacon Fat's Avatar
    Mar 2016
    I lower my dropper whenever I don't want to worry about my seat getting in the way. Downhill, tech, steep uphill, corners. No sense in not using it
    Reputation: targnik's Avatar
    Jan 2014
    +1
    Lower whenever beneficial
    Sent from my HD1900 using Tapatalk
    "Mountain biking: the under-rated and drug-free antidepressant"
    Jan 2016
    It's a riser post. I only raise it when beneficial.
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    Of course. Thatís what itís for.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Wait...seriously?
    Sent from my SM-G955U using Tapatalk
    I'm a mountain bike guide in southwest Utah
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Iím confused.
    Death from Below.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by squeakymcgillicuddy View Post
    Exactly
    Sent from my SM-G960U using Tapatalk
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Fishwiz View Post
    ^ this
    Quote Originally Posted by Bacon Fat View Post
    No wait, ^ this
    Quote Originally Posted by targnik View Post
    +1 Lower whenever beneficial
    Yeah, ^ this
    Oh dammit, I take back everything I said. ^ this.
    (Well crafted sir)
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Nov 2013
    I only lower mine when i come to stoplights so i dont have to tippy toe.
    Of course i lower it in tech terrain, thats the whole point!
    Big Mac
    Reputation: mbmb65's Avatar
    Quote Originally Posted by pufferjumper View Post
    Ascending, or descending? Descending, always. Ascending, maybe.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Nat View Post
    It took 6 posts to come up with dropper defined. Although many use it for many different situations the reason they were ever created was for downhill technical terrain. Lowering it to give the rider better body position by getting the riders azz behind the seat to prevent weight to far forward which helps the rider from going over the bars.
    Always in the wrong gear
    Reputation: Impetus's Avatar
    Aug 2014
    A while back I watched a GMBN YouTube video discussing dropper use.
    One line that stuck with me was something to the effect of:
    ďDonít wonder Ďshould I drop my seat for this?
    You should have it down and ask ďDo I need my post up for this?Ē
    I thought it was silly at first, but I started riding my singlespeed with my 110mm dropper (Damn 27.2 diameter!!) down, and really only raising it when I figured Iíd be sitting for a while and not soft-pedaling. 110mm drop is enough to keep it slammed and still pedal OK. It can make a big difference in the tech, but doesnít feel like Iím sitting BMX-style. Itís crazy how helpful a dropped seat is when climbing tech on a SS.
    My new FS bike has a 150 on it (with room for a 180, coming soon) and Iím pretty much riding it the same way- itís depressed most of the way- probably 120 mm for most trails, knowing I have more to drop if the trail gets spicy, or I can let it up if Iím spinning.
    Basically I think of a dropper like a car cruise control- itís off (down) for active driving, and on (up) for cruise-mode.
    Shiftin' jumps and huckin' gears
    Reputation: tahoebeau's Avatar
    May 2014
    I find it pretty nice to be have it lowered on steep rocky climbs and quick punchy uphills as well. It allows me to shift my weight around to get more traction on either the rear wheel if itís slipping or weight the front if turning all while staying nice and low.
    Ride More - Suffer Less
    Reputation: TraxFactory's Avatar
    Sep 1999
    I run a 200m dropper and still like to lower it on the steeps...
    Jan 2009
    yes. that's why I have a dropper post. what other purpose would it have?
    Professional Crastinator
    Reputation: Fleas's Avatar
    This lightbulb went on for me a few weeks ago.
    -F
    It's never easier - you just go faster.
    Nat
    Nat is offline
    FWIW, I've only recently started using my brakes when I want to slow down. I find it beneficial and less painful than ploughing into a tree.
    Dec 2004
    Yes. It's the most used lever on my bike. In addition to typical DHs, any sort of tech feature or significant turn and it goes down. Steep, sketchy climb where a sideways fall is possible...down. Not only has it (a) made me a better rider and (b) allowed me to utilize techniques to become a better rider, it's made riding much safer as the chance of a sideways tumble down a slope (cliff?) is much reduced.
    Oct 2000
    Quote Originally Posted by goldsbar View Post
    More than your brake or shifter levers? Amazing!
    I definitely use my dropper post more than my shifter. Probably not too much less than my brakes.
    After the obvious descending benefits, I drop mine in every corner and find it has a huge benefit.
    Jan 2009
    more than my brakes, no ó but definitely more than my "shifters."
    Reputation: plummet's Avatar
    Imagine this post in a cooking context.
    "Hey guys, i've just started using the microwave to heat things up.... how about you guys?"
    I think the award for captain obvious goes too......
    Apr 2005
    I am the only captain here eh
    Sent from my SM-G965W using Tapatalk
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    Quote Originally Posted by Picard View Post
    Hey don't you ride with a dropper post without a saddle? How's it working out?
    Cannondale Synapse Neo | Salsa Timberjack
    Dec 2008
    I drop my post when riding skinnies. The lower COG makes definitely increases balance and control.
    Aug 2014
    Quote Originally Posted by mack_turtle View Post
    I feel like there's a common misconception that a dropper is only beneficial for big, dangerous, 'steep' stuff.
    Dropping the seat for rough and tech, but FLAT stuff is not inherently understood by many. Techy climbing while standing over a dropped post is even less intuitive, but IMO just as important.
    How many posts do you see on this forum where someone goes "I live in [Florida, Kansas, other 'flat' state]. I don't need a dropper post because I don't have mountains." ??
    Kudos to the OP for using the tools and advancing his skills for better technique.
    orthonormal
    Reputation: andy f's Avatar
    I have mine set up at seated pedaling height when fully dropped rather than fully extended. I extend it when I need to eject myself from the bike.
    The glass is twice as large as it needs to be
    Rider
    Reputation: TylerVernon's Avatar
    Nov 2019
    No. I only use my dropper for when I am going fast down hill.
    Rider
    Nov 2019
    Quote Originally Posted by Battery View Post
    I can tell you which parts are getting the work out.
    Reputation: Rev Bubba's Avatar
    Absolutely. If nothing else, with the dropper lowered and my new flat pedals, its easier to bail if necessary.
    orthonormal
    Joey, do you like movies about gladiators?
    Apr 2005
    It has been great. My thigh muscles get good workout along with butt muscles
    No known cure
    Reputation: Vader's Avatar
    I've been using a dropper since 2006 and never use it on the trail. Only on steep parts of the race course. I think it's old school technique ingrained. I'm used to using the inside of my thighs to control the bike.
    Ripping trails and tipping ales
    Mar 2015
    The dropper only goes down if keeping it up will eject me from the bike or limit movement in the air.
    Oct 2018
    It depends on the conditions and how much I need to move around.
    For me there is no 'definitive' yes or know based on the term technical. I will do it on non technical terrain if needed and I may not during technical work. It all just depends.
    The only right answer is, if you feel comfortable then you're doing it right. If that makes you crazy, well maybe you really are crazy.
    Reputation: Curveball's Avatar
    Aug 2015
    I found that pedaling works really well to get up hills.
    Riding Washington State singletrack since 1986
    jcd's best friend
    May 2016
    Great! I will keep that in mind next time I head out to the trail.
  1. Action pics of Rigids on technical terrain
    By shackleton47 in forum 29er Bikes
    Last Post: 11-19-2018, 08:53 PM
  2. Speed and technical terrain
    By noonievut in forum Beginner's Corner
    Last Post: 07-06-2014, 03:20 AM
  3. Replies: 32
    Last Post: 06-05-2013, 10:44 PM
  4. BEST Wet Terrain/ Mud Terrain Tire?
    By fjtort2 in forum Wheels and Tires
    Last Post: 05-13-2011, 03:03 PM
  5. Flux terrain vs 5 Spot terrain
    By Duncan in forum Turner
    Last Post: 07-20-2005, 09:12 PM
Members who have read this thread: 181
