DMR death grip Reinstall- Mtbr.com
Results 1 to 5 of 5
    Reputation: 2obscura's Avatar
    Jan 2014
    I put a set of DMR death grips on my bike when I bought it. Bars that came on it are 780mm and need to be cut down a little. The grips are a single clamp with a tapered core lock-on.
    Has anyone removed and re installed a tapered core lock on?
    I am worried it might slip around after being removed and reinstalled. I had to pound the crap out of these to get them on.
    I have some down time while recovering from a fresh plate install on my collar bone and just really got to the point of using my hand again. Gotta fight off the jonesing and boredom for a couple more weeks.
    I don't always listen to slayer, but when I do so do the neighbors.
    Reputation: fredcook's Avatar
    Probably no more difficult to remove without destroying them than traditional non locking grips, assuming there's a small hole on the end where you can shoot some air pressure (assuming you have access to a compressor) in to expand the grip a little.
    You didn't quit riding because you're old, you're old because you quit riding.
    Jan 2014
    Quote Originally Posted by fredcook View Post
    It is a hard plastic core. air still may help the one and a half arm man. Really just concerned with once they are back on again will the stay put.
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by 2obscura View Post
    1.) If they were that tight going on, expect a fight getting them off. Don't hurt yourself doing so, seriously. Tilting the bars to allow some WD40 to penetrate from the clamp end down to the other end may help. It evaporates pretty quickly and will not impact reinstall. (used to install golf grips all the time)
    2.) I have not used them specifically, but I would expect they would still grip upon re-install.
    Hi
    I hope that busted bone is doing ok?
    Did you get the deathgrips off and back on.
    They are super tight for sure. Iím not sure air would help at all. Looks like a 2 man job to me.
    I heard itís just a matter of twisting and pulling (and looking behind you before you start because once they give youíre at risk of falling back).
    So, if youíve refitted are they staying put now. I guess they werenít as tight to get on 2nd time.
    I read another thread from a guy who hammered a pair on and wrote that they are moving after a few rides. Iím amazed because it took all my strength to adjust the rotation slightly after hammering them on!
    Heal well
  1. Replies: 6
    Last Post: 01-08-2019, 12:34 AM
  2. DMR V12 Alloy Pedals VS. DMR V12 Mag Pedals
    By RollingNoMad in forum Components
    Last Post: 05-15-2018, 11:29 AM
  3. Hope brakes: reinstall little clip?
    By happyriding in forum Brake Time
    Last Post: 09-02-2017, 10:05 AM
  4. FTM Rocker reinstall question.
    By yeschiro in forum Titus
    Last Post: 03-18-2013, 07:34 PM
  5. How to easily take off and reinstall non-locking grips easily
    By burtonridr in forum General Discussion
    Last Post: 03-09-2012, 04:25 PM
Members who have read this thread: 17
