disc brake tabs- Mtbr.com
Results 1 to 6 of 6
Thread: disc brake tabs
    disc brake tabs
    Is it possible to add disc brake tabs to a ti frame?I have a older moots that I would like to try disc on.If so any suggestions for a welder.Thanks
    A wheelist
    Reputation: Mike T.'s Avatar
    Sure it's possible. Why not call Moots and talk it over? Maybe the stays they used were not up to the stresses of DB. It's got to be a bike tubing Ti welder who does it for you anyway. If they do it, they can re-furb the whole frame at the same time and it will look original.
    Air Pirate
    Reputation: Bokchoicowboy's Avatar
    How about one of those disk brake adaptor devices? There are a couple different designs that can be found out on the web.
    any idea where to look for these?
    On ebay, if you type in disc brake adapter or converter, you'll find some for around $50.
    Quote Originally Posted by Bokchoicowboy
    How about one of those disk brake adaptor devices? .
    I looked in to those, some people have had problems with the type that attaches to the brake posts...sometime the posts break .....instead of brake
    I decided to run a disc in front and stick with a rim brake in the back. Just got a new wheel and brake, installing this weekend!
