Correct PSI?- Mtbr.com
Results 1 to 7 of 7
Thread: Correct PSI?
    2ts
    2ts is offline
    Mar 2011
    Correct PSI?
    Hi to all,
    Im not sure if im doing it correct. I applied air pressure on my bike's rear suspension (fox DCRV). I followed the chart's recommended PSI based on my weight, but the moment i removed the pump head completely from the valve, I knew that some air pressure (about 20PSI) came out of it.
    Questions are:
    Is it normal? or do I have to add extra PSI so it would compensate whatever pressure came out? Whats the right way to do it?
    THANKS.
    Did you use a shock pump? The air chambers in shocks are very small and chances are you let all the air out when you removed the pump.
    All of the true things I'm about to tell you are shameless lies.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    That's air coming out of the hose. You're fine.
    Afric Pepperbird
    Mar 2005
    Just to clarify, the last answer in this thread nails it.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Quote Originally Posted by 2ts
    That does not guarantee that the result is what you like, anyway. You should experiment a bit: ride, make a change, repeat; until you find the best set up for you. Then use the same shock pump to keep it there ( ... until you want to try something different ... )
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Jan 2005
    The absolute number is somewhat irrelevant if your technique is inconsistent.
    Said that, I did read it somewhere (probably User docs for Giant) that one should allow for ~5% of air (and pressure) to be lost when the pump is disconnected. So, if you want to get, say, 100PSI, pump to 105PSI and then disconnect.
    But the key is consistency - pump to 100, check the sag, ride. If happy, write the pressure value down, so you can repeat it later using the same reading and the same pumping technique
    Reputation: shiggy's Avatar
    Dec 1998
    Hi to all,
    Questions are:
    THANKS.
    Use sag, not psi to setup your suspension. Note what psi is required to achieve the desired sag for the future.
    mtbtires.com
