Carbon bar width- Mtbr.com
Results 1 to 9 of 9
    Reputation: MObiker's Avatar
    Carbon bar width
    I recently purchased a SC Blur. It has an Easton MonkeyLite riser bar on it. The bar is 26.5" wide. My previous bike had a bar width of 25". The new bar seems a little wide. I ride cross country, pretty tight single track, not much for downhill or big jumps ( too old ). The guys at the LBS said you can take up to 1" off each side of these bars, requires a special hacksaw which they have. I realize I'll probably lose the warranty if I do this. Any thoughts on bar width or cutting down carbon bars before I proceed?
    It does not require a "special hacksaw," this is a common scare tactic used by some LBS.
    The hacksaw blade must be a 32tpi (tooth per inch).
    Since your bars are 26.5" wide, you can safely take them down to 24" with no problem. As a matter of fact, the MonkeyLite "SL" version is 24" right out of the box.
    I suggest you download the "how to cut carbon bars" instructions below:
    http://www.eastonbike.com/downloadab...-05-Carbon.pdf
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Ditto.
    Jun 2012
    I used a fine diamond disk on a Dremel-type tool. Cut very cleanly, but wear a mask and glasses.
    Wait a month till you cut it down. Many people now like wider bars with a slightly shorter stem.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    What Rave on said...!
    But before cutting, just slide your shifters/brake levers and grips in a tad and ride... keep shifting them in and out till you get a comfortable position for you. then just run a pencil or marker around the outer edge of your grips. and cut.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Jan 2009
    Quote Originally Posted by Yogii View Post
    yes. you will like wider bars, it's in your destiny!
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by RaveOn View Post
    I'd be interested in checking that link out but.......Liinky don't worky. Please re-post!
    Wēk Ss
    Reputation: IAmHolland's Avatar
    A post from 2004, so that's probably why the link doesn't work. What's with the grave dig?
    dirtjunkie, http://www.eastoncycling.com/bike/wp...-05-Carbon.pdf
  1. FSA Team Issue Carbon Pro Porn...
    By DIRT BOY in forum Weight Weenies
    Last Post: 03-04-2004, 08:31 PM
  2. Carbon bar & bar ends.
    By minkhiller in forum Yeti
    Last Post: 02-22-2004, 07:05 AM
  3. handlebar stiffness question
    By jean-seb in forum Weight Weenies
    Last Post: 02-22-2004, 05:00 AM
  4. Bar width
    By spacoli in forum General Discussion
    Last Post: 02-20-2004, 07:54 AM
  5. Performance CTX carbon bar, first impressions
    By pimpbot in forum Weight Weenies
    Last Post: 02-12-2004, 09:00 AM
