Bash Guard- Mtbr.com
Results 1 to 20 of 20
Thread: Bash Guard
    Reputation: stevejill91's Avatar
    Bash Guard
    Anybody using a Bash Guard and how do you choose the size. I have a 32t middle and i never use my large chain ring. Are there any hints on what to get.
    thanks
    2012 Rockhopper 29er w/ manitou tower pro
    wannabee
    Reputation: giantbikeboy's Avatar
    Dec 2004
    lose the big ring I guess. I run BBG
    bash guard - Bing
    Reputation: Gasp4Air's Avatar
    It's a pretty standard item that will be just a little bigger than your middle ring. You want to match the BCD to your crank spider, typically 104, which is the distance between the bolt holes, and it will also tell you the maximum middle ring size it will work for.
    You just take off the outer ring and replace it with the bash guard. Then start clearing logs and roll overs better.
    Use it, use it, use it while you still have it.
    Self Appointed Judge&Jury
    Oct 2000
    Quote Originally Posted by Gasp4Air View Post
    Or if you are unable to remove the big ring like some older XTRs. Just grind the teeth off the big ring and it acts as a bash guard.
    Frt Range, CO
    Reputation: pursuiter's Avatar
    never mind, need coffee
    I put a new crank on recently and left the big ring on it. I've used my it about once every month, going to replace with a bash gaurd. So much better striking deadfall or a rock on bashbuard.
    Reputation: drblauston's Avatar
    gonna second DIRTJUNKIE,'s and Gasp4Air's suggestions - lose the big ring and then find a bash you like and that fits..
    I use a Gamut P30 Bashguard - Gamut USA Store
    then as the others said get out there and use it!
    Ive seen 32T, 34T 36T Bash guard do I match the tooth for tooth. I have a 32T middle so do I get a 32T Bash guard or a 34/36?
    thanks guys. I know I will get one now cause I do have trails with rock and logs and come very close to impact. Just have to figure out whitch size.
    the Gamut isn't sized other than P30 for 3xT rings..
    max I would guess to be 36T but it works for 32/34
    I have about a 1/1.5cm of radius difference between my middle 32T ring and the bash guard though, whatever that means
    Ok so I can get a 36T bash gueard for my 32T ring. cool.
    thanks
    Reputation: SeaBass_'s Avatar
    No reason to get a 36t unless you plan on running a 36t in the future. Go to BBG and get a 32t bashguard for $18 delivered.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yup, got bbg on both bikes, great stuff. If you have a 32t ring that is what size bash you need
    WOW I just ordered on up, I have been searching but they were all around $40.00. Awesome info being Im on the Obama pay plan.
    thanks again.
    Bicyclochondriac.
    Quote Originally Posted by stevejill91 View Post
    thanks
    The only thing you may run into with a 36t bash and a 32t middle ring is a situation where the chain rubs against the bash guard when you are in the middle ring and use the smallest cogs. This happened to me with a 36t Truvativ bash guard. It probably depends on the particular bash guard.
    Iko
    Iko is offline
    Reputation: Iko's Avatar
    Mar 2011
    bash + 29er = cleaning everything on the trail.
    Reputation: Bailey44's Avatar
    Dec 2010
    Yep, BBG rocks. Good looking, sturdy, light and cheap.
    Reputation: BacDoc's Avatar
    +1 for BBG
    This is on a 3X9 - took off the big ring and replaced with bash. BBG website has the options or you can call them for info.
    Mine is on its way, red 32 tooth
    Adrenaline Junkie
    Reputation: Fighters's Avatar
    Thanks for following up Steve,
    I just ordered a black oval 32T for my Giant Talon 29er 0 (32T) as well.
    Reputation: Rogueldr's Avatar
    Run a 34 spot brand on my Jamis F/S, a 34 BBG on my Klein, and my Race Face Evolve XC SS crankset came with a 34 bashguard. I just took the big rings off and replaced with the BG's. My middle rings and my SS are 32's but I like the little extra clearance the 34 BG's give me.
    "Lock S-Foils in attack position"
  1. Looking for a better helmet...
    By Sonoma_MTB in forum Apparel and Protection
    Last Post: 01-14-2012, 01:34 PM
  2. xtr 2 ring bash options
    By hak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2012, 04:32 PM
  3. O/T ...this forum who is it selling bottom bracket bash guards?
    By HEY HEY ITS HENDO in forum Lights DIY - Do It Yourself
    Last Post: 01-12-2012, 04:33 PM
