Bar Slippage Q?- Mtbr.com
Results 1 to 15 of 15
Thread: Bar Slippage Q?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Bar Slippage Q?
    I find that when I go into a bar that I slip really easily with my clippy shoes. They Slip easily enough, but add beer onto the floor and my drunkenness to to the equation, and things get embarrassing in front of hot chicks - are 5:10s the answer?
    Honestly... ahh I give up
    ~Disc~Golf~
    Seriously though, I have a handlebar that is slipping in the clamp and need some tips.
    It's an older bike with a quill-stem, an '87 Heidelized SledgeHammer.
    I just recently got a wider bar so I could put some stubbie bar-ends on it. The ends create so much torque when I am 'gettin it' (for lack of a better term - I'm not that hard-core ) and the bar spins in the clamp. It's only a single-blot constricting style clamp and I'm at the bolt's max before strip/break for sure.
    Any tips?
    Actors:
    '80's gooseneck-quill
    '10's RF Deus...
    Obligatory Pic:
    J:
    Reputation: Deerhill's Avatar
    Dec 2009
    I have an old rigid trek with similar problem (small steerer/ one bolt quill stem ). It used to have this true temper bar that was real narrow. I tried to ruff up the surfaces and "make lines" on the bar to give more grip. Worked for a bit.
    Wondering if a newer 1 1/8 stem w/ a shim for steerer would be safe..
    Perhaps you can try that carbon grip paste...it's kinda sandy and grippy.
    Reputation: Spinning Lizard's Avatar
    Back in the 80's we used to cut open a old beer can and cut a piece for a shim. Worked every time.
    Axles of Evil
    Reputation: SS-Dad's Avatar
    Agreed
    Quote Originally Posted by Spinning Lizard View Post
    Beer can shims can work wonders.
    Reputation: Brewtality's Avatar
    Quote Originally Posted by SS-Dad View Post
    But it must be a beer can. Soda cans don't work as well.
    If you are going for the hipster look, you have to go with a PBR can or something else old and vintage - Hamms, Old Milwaukee.
    If you are going for the redneck look, Budweiser.
    Personally, I would go for Dales Pale or Maui Brewing Coconut Porter cans.
    And if you do go with a soda can, it needs to be Coke. None of that commie Pepsi crap. Coke is much more All-American. And it mixes better with Jack, for consumption while you are installing your shim
    Its all Shits and Giggles until somebody Giggles and Shits
    ~Disc~Golf~
    Got plenty o' beer cans - I know it has worked great for an odd sized post I had before
    ~Disc~Golf~
    Quote Originally Posted by Brewtality View Post
    IF, big if, I were to go the soda route - It'd be Mt Dew.
    I am an AM rider.
    Plays with tools
    Reputation: customfab's Avatar
    Do you have a stem that is 26.0 with your 25.4 mountain bar? That is enough of a difference that it will be a permanent PITB until you get the right stem.
    ~Disc~Golf~
    I have no Idea, but there is still room (1/16-1/8") to close the gap
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I always default to the beer can shim because it's awesome but for other ideas make sure the interface area is very clean. Can you tighten the bolt far enough to close the gap if there is no handlebar in the clamp? You might be hanging up on something in the clamp. And remember that that bolt is going to need to be torqued to within an inch of its life in order to hold that much force.
    And if that fails, just douse the thing in gorilla glue. That ought to do it.
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    The answer to your problem...
    Quote Originally Posted by highdelll View Post
    Any tips?
    Actors:
    '10's RF Deus...
    Obligatory Pic:
    JB Weld or Liquid Steel. You're welcome.
    JPark - 3.5- don't listen to dremer
    ~Disc~Golf~
    Fixed it - so far...
    Filed small grooves in the 'clamp' w/ a triangle file.
    I think that even a shim cold be more slippy on 2nd thought. - there are two surface-mates vs. one.
    I know it works fine for a post, but in a torque situation, I have second-thoughts
    Dude, the beer shim has been used 1000's of times with success
    The thin metal forms around the bar and clamp to make a secure contact.
  1. Slippage
    By daveholte1 in forum Singlespeed
    Last Post: 10-30-2011, 09:45 PM
  2. Slippage
    By booklikeabook in forum Tooltime
    Last Post: 09-24-2008, 03:52 AM
  3. EBB Slippage
    By zippo in forum Singlespeed
    Last Post: 06-01-2007, 11:55 AM
  4. Slippage on Acera X?
    By ANdRewLIu6294 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2005, 12:46 PM
  5. ENO Slippage......HELP!!!
    By chili in forum Singlespeed
    Last Post: 09-04-2005, 08:43 PM
