1 1/8 to tapered adapter- Mtbr.com
Results 1 to 11 of 11
    May 2020
    I am looking to upgrade the current setup of my bike to 150mm instead of 130 on the front. the problem is my headtube is 1 1/8 straight, and the fork i have is tapered. is there an adapter i can buy that fits on to my bike that will allow me to to make this mod? thanks a lot.
    Sneaker man
    Reputation: mik_git's Avatar
    you mean the fork that is already on it is tapered, and the one you want to pu ton is straight 1-1/8? or the for you want to put on it is tapered?
    For the former, I imagin so, for the latter, if you headtube is a Zero stack headset, internal bearing design, then it can be done. If it regular straight with external bearings, then it cannot be done (probably, maybe someone managed it somehow, but not usually).
    See here to figure out:
    http://www.canecreek.com/wp-content/...his-poster.pdf
    All the gear and no idea.
    Reputation: Hurricane Jeff's Avatar
    Like me get this straight. You have a bike with a 1.125" head tube, and you currently have a tapered fork that is not mounted on the bike?
    I heard of an adapter, to fit a tapered fork into a untapered head tube but I never was able to locate one.
    EXODUX Jeff
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Matt_Sinclair View Post
    Depends on the specific dimensions of the head tube on your bike.
    If you have a 44mm head tube, you'll need a new lower headset cup. If your head tube is 34mm, you're SOL.
    Dec 2013
    What frame do you have?
    Dec 2013
    I have 2 bikes with the above mentioned 44mm, both running tapered, but there is limitations on some frames due to insertion depth for the bearing cup.
    May 2020
    trek marlin
    Jan 2009
    130mm is already much longer than what is appropriate, probably what is safe for a Trek Marlin. 150mm is just silly. It's the most absurd chopper modification.
    I don't think it will work. You need a frame that was designed for a 44mm or larger headset cup and something that will withstand such a long fork.
    RAKC
    Reputation: tigris99's Avatar
    That bike doesnt even come with 130 and already maxing that frame out. No one needs 150mm on a hardtail and is beyond stupid on that bike. All it will accomplish is causing the frame to fail.
    Sent from my SM-N975U using Tapatalk
    since 4/10/2009
    Quote Originally Posted by tigris99 View Post
    While I agree 150mm on a Marlin is a very, very bad idea, there are plenty of hardtails built to accept a 150mm fork. I ride one with a 140mm fork (that is within the spec of the frame). With the right frame, a longer fork on a hardtail can be a lot of fun. I ride mine and enjoy doing so on terrain that most people wouldn't ride anything less than an enduro FS bike on these days.
    On the wrong frame, you're likely to injure yourself and destroy your bike.
    Dec 2013
    Budget frame with semi-integrated headset, no go. And max 100mm fork per site. I wouldn't hesitate for a second to run 120, but no longer.
  1. Magura Tapered Fork in Spec. Tapered Head Tube
    By phlegm in forum Shocks and Suspension
    Last Post: 05-09-2012, 05:27 AM
  2. Replies: 4
    Last Post: 10-24-2011, 12:50 PM
  3. Tapered vs Non-Tapered Headtube
    By claystrick in forum Colorado - Front Range
    Last Post: 06-14-2011, 11:34 AM
  4. Replies: 10
    Last Post: 03-16-2011, 12:27 PM
  5. Jet 9 fork tapered versus non tapered.
    By mvi in forum 29er Bikes
    Last Post: 02-22-2011, 02:17 AM
Members who have read this thread: 49
