replacement freewheel body, 2010 Rumblefish 1- Mtbr.com
    Reputation: mountaindavis's Avatar
    Jun 2010
    I have a contaminated rear freewheel hub and was looking to replace it this spring but can't find the part number anywhere to order. I am using the 12-36 CS-HG61 9 speed rear cassette on my stock rims (Duster), Shimano rear hub. Anyone know what or where to order a freewheel body?
    Put this bandit hat on.
    Reputation: Tonuck's Avatar
    Jun 2010
    I think you mean the freehub body. According to the fisher website, the 2010 Rumblefish I comes with an M529 rear hub, but you may want to confirm this.
    The part numbers for that hub can be obtained from this link at the shimano techdocs site.
    The freehub body is part #Y-3SW98060, which is the same used in the FH-M595 rear hub.
    Your LBS should be able to order the part in for you with that info.
    Jun 2010
    Thanks so much-- I only called it a "freewheel body" since that is the terminology that Shimano uses including on the link you sent. They say #Y-3SW98060=Freewheel body unit. Go figure. I used to say freehub, and will continue since obviously others say that too.
    Your link is very appreciated! Thanks.
    I hate that name.
    Reputation: blunderbuss's Avatar
    By the way, you'll have pull out the axle to change the freehub. While you're there you should go ahead and overhaul the bearings. The new freehub should come with new bearings in it. (driveside wheel bearings actually ride in the freehub)
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
