Results 1 to 1 of 1
    Jul 2017
    Fuji Reveal headset ?
    Hopefully someone can assist with this issue, the bike is listed as having a "FSA NO.42B, 1 1/8 - 1.5 Caged bearings"
    so I assumed a FSA NO.42ACB would be a good replacement/ upgrade, however when I received it the bearings are to big to fit inside the 'cups' so I am confused, on the canecreek headset finder the bike is listed as a IS42/52 meaning the NO.42ACB should of worked.
    I talked with FSA and they think if I knock the cups out it should fit the NO42.ACB "if" the headtube was manufactured correctly, the current headset is probably a FSA NO42B/CUP model and the cups are supposedly the shape of the ACB bearing so the headtube is supposed to be shaped to fit integrated headsets (like the ACB)
    however I am unsure, I think its to risky to knock the cups out since I cannot find the NO42B/CUP or current headset anymore so if FSA is wrong I will be without a bike.
    Edit:
    Just updating my own post, knocking the cups out the frame the headtube is machined to take the FSA NO42.ACB headset, you will need to add a extra headset spacer in to accommodate for the 3m~ extra space the cup removal gives (ie your steerer tube will sit farther in the frame)
  1. Fuji Reveal?
    By WarriorPro in forum Fuji
    Last Post: 09-20-2011, 04:05 PM
  2. 2x10 on an '08 Fuji Reveal?
    By Rockband in forum Fuji
    Last Post: 08-25-2011, 09:32 PM
  3. Manual for 2008 Fuji Reveal 2
    By trnsprt in forum Fuji
    Last Post: 05-19-2011, 03:23 AM
  4. Fuji Reveal sizing question/help......
    By unicron in forum Fuji
    Last Post: 05-11-2011, 06:17 PM
  5. Can't find a local Fuji Reveal dealer
    By turbojones in forum Bike and Frame discussion
    Last Post: 01-21-2011, 03:00 PM
