Results 1 to 3 of 3
    Apr 2016
    New question here. 2014 Fuji SLM 29 2.5 good bang for the buck or low quality bike?
    I just came across a Brand New 2014 Fuji SLM 29 2.5 being sold for $1200, is this just a good low price or is the bike going to break within the first couple of months. I would be using the bike for XC riding mainly. Current bike is a 2016 Specialized Rockhopper Expert 29, is it a good component upgrade?
    Specs for the Fuji:
    FRAME C10 super-light high-modulus carbon w/ internal shift cable routing, shaped oversized ride-tuned down tube, PF30 bottom bracket, tapered 1 1/8" - 1.5" head tube
    REAR TRIANGLE C10 super-light high-modulus carbon seatstays w/ shaped ride-tuned chainstay, carbon 142x12mm dropout and replaceable hanger
    FORK Manitou Marvel 29 LTD w/ tapered alloy steerer, 15mm Thru, 100mm travel, MILO remote
    REAR SHOCK N/A
    CRANKSET OVAL 420 w/ integrated spindle, 36/22T
    BOTTOM BRACKET Praxis Works sealed cartridge
    PEDALS N/A
    FRONT DERAILLEUR Shimano M616D, direct-mount
    REAR DERAILLEUR Shimano Deore XT, M781 SGS Shadow top normal, 10-speed
    SHIFTERS Shimano Deore, M610 Rapid Fire, 20/30-speed
    CASSETTE Driven, 11-36T, 10-speed
    CHAIN KMC X10, 10-speed
    WHEELSET Formula DC-51 front / DHT-142 rear, 32H disc hubs, Vera DPD22 rims
    TIRES Hutchinson Cobra, 29" x 2.2", 33tpi
    BRAKE SET Promax Decipher, hydraulic disc, 180mm/160mm rotor
    BRAKE LEVERS Promax Decipher hydraulic disc
    HEADSET FSA 1 1/8" semi-integrated, caged bearings
    HANDLEBAR Oval M100, alloy bar, 9 sweep, 31.8mm diameter, 710mm wide
    STEM Oval M313, 3D-forged alloy, 31.8mm clamp diameter, 6 rise
    TAPE/GRIP Oval 400 dual-density
    SADDLE Oval M200 w/ steel rails
    SEAT POST Oval M300, alloy double-bolt micro-adjust, 31.6mm x 350mm
    WEIGHT 27.10 lbs / 12.30 kg, per Fuji web site.
    2014 Fuji SLM 29 2.5 good bang for the buck or low quality bike?-p5pb12977173.jpg
    Fuji is legit, thats a good price. Inspect it for any frame damage (from crashes). That's a good price, if it's the right size for u then snatch it up...
    I wish i could score a carbon rig for that kinda money!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '17 Scott Speedster CX20
    12 Scott Foil Team
    Jun 2013
    Fuji makes excellent frames and Manitou makes excellent forks, so it's a great deal.
    The only three components I would change immediately would be an M786 Shadow+ rear derailleur, Ergon grips and Ergon SMC4 saddle.
    https://www.worldwidecyclery.com/pro...t-saddle-large
    The brakes are kind of cheap, so if you have trouble with them, get some Shimano XT.
  1. Best Bang for the Buck Fat Bike?
    By Windigo in forum Fat bikes
    Last Post: 12-22-2014, 09:04 AM
  2. Best bang for the buck 2014 Epic ?
    By Devastazione in forum Specialized
    Last Post: 05-21-2014, 11:51 AM
  3. looking for good bang/buck ratio and quality. whats good?
    By car bone in forum Lights and Night Riding
    Last Post: 09-27-2013, 04:01 PM
  4. CST Camber - DAMN GOOD bang for the buck!
    By thuren in forum Wheels and Tires
    Last Post: 12-15-2011, 08:36 AM
  5. Best Bang/Quality for the buck.
    By Maddog11 in forum Bike and Frame discussion
    Last Post: 09-01-2011, 06:09 AM
