welding ti- Mtbr.com
Thread: welding ti
    welding ti
    Are there folks out there who can weld a cable stop to my ti frame? I hate the cable stop for the front derailleur attached to seat tube. I much rather prefer that cable be routed through down tube. By the way, I am in boston area.
    In addition to properly weld ti you need to completely submurge it in argon. Ti is a specialty try to find someone who does this on a regular basis, it probably wont be cheep either.
    it will probably be more of a hassle than its worth considering that this is just a preference and not a problem.
    good luck
    simply me
    Reputation: bostonkiwi's Avatar
    Matt Chester will probably do it...
    http://www.mattchester.com/maindocs/repair.shtml
    Seven Cycles and IF are both in Boston and both do ti, might be worth a call but I doubt they'll touch it unless they made the frame.
    http://sevencycles.com/ - Watertown
    http://ifbikes.com/ - Somerville
    Just some dude.
    Find a smaller Ti framebuilder
    I'll second what Steve3 said, find a Ti framebuilder that way you're sure that they are familiar with thin Ti tubing, have access to Ti cable stops, and have the jigs to hold the cable stops in place during welding, making the job quick and painless.
  1. Tomac Revolver Ti
    By arturo in forum Litespeed
    Last Post: 12-25-2004, 04:22 AM
  2. Bontrager Ti Lite ~ Info
    By idoru in forum Vintage, Retro, Classic
    Last Post: 06-10-2004, 03:45 PM
  3. Where do you get Ti bolts?
    By Smytty in forum Weight Weenies
    Last Post: 02-29-2004, 02:16 PM
  4. Ti rigid forks for 26" and 29"
    By patirwin in forum Alaska
    Last Post: 02-28-2004, 07:48 PM
  5. What size are Hayes brake bolts? Ti Question
    By FLYBYU in forum Weight Weenies
    Last Post: 02-24-2004, 10:01 PM
