Tubing suggestions for use with Paragon's steel chainstay yoke- Mtbr.com
    650b me
    Reputation: golden boy's Avatar
    Has anyone built a frame using Paragon's chainstay yoke for 3" tires? What tubing did you use for the chainstay? The yoke has a stub with a 20.2 mm diameter that is designed to accept the chainstay slip fit over the top of it.
    Frame Building Moderator
    Reputation: Walt's Avatar
    I have assisted on one for a buddy (I just did the welding, not any of the mitering/fitup), and we used 22.2mm x .9, as I recall.
    You could do a tapered tube there if you wanted, there is a .9 x 22.2 single taper chainstay out there somewhere though I don't recall right now who sells it. The Nova .8 one would probably be fine too.
    -Walt
    650b me
    Thanks Walt. I was hoping there was a tapered option. Tapered stays look much more elegant to me. I'll look around for the one you mentioned.
    Found them, I think. I misremembered, they are .85 wall. Should work great, though:
    https://www.spectrum-cycles.com/framesupplies.php
    Note that they are kinda thin at the small end (.9mm) so be careful. I might do the Nova .8mm ones instead, honestly, because welding that small of a .9mm tube to a dropout seems like it's asking for trouble.
    -Walt
  1. Paragon yoke to rocker dropouts?
    By groomer in forum Frame Building
    Last Post: 05-04-2016, 07:12 AM
  2. Having New Chainstay/Yoke built for Full Suspension?
    By PHeller in forum Frame Building
    Last Post: 12-31-2014, 07:42 AM
  3. 07 Paragon or 08 Paragon
    By danadog in forum 29er Bikes
    Last Post: 11-24-2007, 06:15 AM
  4. 2007 Paragon to 2008 Paragon
    By Fishlips in forum 29er Bikes
    Last Post: 08-23-2007, 06:38 PM
  5. Classic Steel bikes, which tubing is better. (Steel lovers only)
    By Cmonster in forum Vintage, Retro, Classic
    Last Post: 11-04-2005, 10:14 PM
