Suspension pivot question - new builder- Mtbr.com
Results 1 to 6 of 6
    First I should introduce myself. I like to ride rigid bikes. I have never built a frame before but I would like to. I've done some welding and brazing, but my brazed joints are ugly at best, poor on average. I do eventually get it right, but it takes longer than it should.
    I'd like to give building a frame a shot this summer. Initially I figured my first frame would be an excercise in sticking tubes together, but have instead decided I'd work on my brazing with a trailer.
    I will be building a singlewheel trailer and I want it to have suspension. I have almost everything worked out in my head except the suspension pivot. I won't have the clearance issues that a pivot points on a bike frame would have, and do not have access to a lathe. Does anybody have a recommendation for a simple pivot?
    Thanks.
    pvd
    pvd is online now
    Reputation: pvd's Avatar
    Simple nylon bushings would be fine for that.
    NEPMCPMBA President
    igus?
    Most Delicious
    Reputation: dr.welby's Avatar
    Some kind of door hinge with bushings?
    Flex hinge (like on the Slingshot bikes) - a piece from an old ski?
    Something based on a bottom bracket?
    I didn't really consider the nylon bushings as an option, but I think I'll go that route.
    I really like the flex hinge (a la slingshot bike) idea. I'm not going to use it for the trailer, but I will use it for something - someday.
    Thanks for your help.
    Framebuilder
    Reputation: Live Wire's Avatar
    Have you seen a Talyor bike trailer? They had a clever and simple suspension design.
    www.vintagebicyclepress.com/BQ71.html
