stainless and cast dropouts, can they be TIG welded to 4130?- Mtbr.com
Results 1 to 8 of 8
    Gamers local 2112
    I was looking at slider dropouts and they all seem to be either stainless or cast mild steel, can these be TIG welded to a 4130 tube? If not, are there other options out there besides what Nova and Paragon have to offer?
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Yes.
    Dec 2012
    They can be TIG welded to 4130 with the proper filler rod.
    Gamers local 2112
    I've used surly track dropouts that appear to be cast and they weld fine, so a mild steel one would be ok cast or not?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Yes
    Eric
    If I don't make an attempt, how will I know if it will work?
    Mar 2018
    I suspect the original question came from the fact that cast IRON is not practically weldable in most situations, due to the high carbon content. Cast steel can certainly be made weldable.
    Gamers local 2112
    ok, good to know. Thanks for the sagacious counsel.
    Dec 2011
    When we say cast, we are actually meaning Forged.
    Eric
  1. Replies: 12
    Last Post: 12-04-2015, 08:28 PM
  2. Replacing headtube on tig welded TT Ox Platinum frame
    By MotoMark in forum Frame Building
    Last Post: 07-22-2014, 08:08 PM
  3. WMW - 2nd frame - 1st TIG welded
    By abarthx19 in forum Frame Building
    Last Post: 06-18-2012, 02:36 PM
  4. 4130, TIG and Heat Treat?
    By Nockpoint 01 in forum Frame Building
    Last Post: 03-22-2012, 06:20 PM
  5. Welded, pinned, spot welded...
    By iviguy in forum Wheels and Tires
    Last Post: 03-21-2006, 03:30 PM
