Something rattling inside of sealed chainstays, making me insane- Mtbr.com
Results 1 to 6 of 6
    Apr 2013
    I have a Spot brand 26" single speed, from around late 90s, early 2000s. Steel, made in Canada. There is something rattling inside one of the chainstays, but they are completely sealed. Would it be ok to drill these somewhere to either get the piece out, or fill with foam? Thanks for your help
    Reputation: life behind bars's Avatar
    May 2014
    1/8" hole near the dropout end.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Wanna ride bikes?
    Oct 2013
    Frames frequently have drain or vent holes. Drill a small hole by the dropout, on the inside of the frame, and shoot a little grease in there. It should catch the little piece clanking around. No need to fill with foam (which could hold moisture).
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Nov 2008
    Idle curiosity, have you taken the BB out?
    Often times there is a hole in the BB shell near about the center of the chain stay. If so you can shake whatever is in there out. I have success with this before.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Apr 2013
    Hi, yes, I've removed the bottom bracket. No chainstay holes. Thanks
    Reputation: Meriwether's Avatar
    I had one of those Spots!
    Like others have said, 1/8 hole an inch above the dropouts, use a countersink bit for its short length and rigidity and donít go past the pilot. Then use Weigleís frame saver, itís sticky and will protect it from water that will get in and not be able to drain properly without a second breather hole. It should grab and stick to the thing thatís inside rattling too.
    But if you drill a second hole at the other end can use an air compressor to blow it out. Would be nice to know what it is in there...
  1. 4/10/10 Rattling Around Rattling Creek
    By bear in forum Pennsylvania
    Last Post: 06-20-2011, 12:06 PM
  2. Replies: 10
    Last Post: 08-05-2008, 08:56 PM
  3. Replies: 27
    Last Post: 12-10-2007, 09:51 PM
  4. What is lighter ? Sealed derailleur pulley or not sealed ?
    By Megaclocker in forum Weight Weenies
    Last Post: 04-28-2006, 06:21 AM
  5. Replies: 10
    Last Post: 10-24-2005, 01:18 PM
