Small crack inside the seat tube. Should I worry?- Mtbr.com
Results 1 to 12 of 12
    Dec 2017
    I'm overhauling a steel bike and I found a small crack inside the seat post. The lug around seems in very good shape. Since the bike is for a friend, I feel responsible!
    Any input is welcome, thank you
    Plays with tools
    Reputation: customfab's Avatar
    Something to keep an eye on for sure. The crack will likely keep going until it gets to the end of the seat tube. As long as the lug doesn't crack as well you're doing ok.
    Dec 2017
    Would it be possible to stop it by welding/brazing it? thx!
    Cycologist
    Reputation: chazpat's Avatar
    Quote Originally Posted by Star View Post
    Not my area of expertise, but wouldn't that interfere with inserting a seat post? Maybe you could drill a small hole in the end to keep it from expanding? Looks like it would still be inside the top tube and not show.
    Quote Originally Posted by Oh My Sack! View Post
    Remember, there's always quilting and knitting if pedalling becomes too tough.
    Dec 2014
    I like the drill a hole to stop it idea. Shouldn't have to be big, and shouldn't cut into the top tube or lug. Welding would probably also work, but then you'd have to ream it. I'm not sure if brazing would stop it or not...
    Dec 2017
    Chazpat, a hole there would still fall inside the diameter of the top tube. So it seems to me a very clever idea! let's wait for the expert to endorse this solution!
    Dec 2017
    Cyclingengr thank you for your input, I agree:
    - Hole drilling - preferred solution (it won't cut anything else than the cracked part of seat tube wall, easily clearing the lug and top tube wall)
    - Welding (maybe reaming with a Dremel would be imprecise but enough for a seatpost)
    - Brazing - not very sure if that would stop it, but it is just an intuition without much scientific background
    Plays with tools
    Have fun drilling a hole at the end of that crack.
    Cycologist
    Quote Originally Posted by customfab View Post
    Because of the angle you'd have to drill at? Looks like if you removed the binder bolt, you could go pretty straight at it.
    Moderator Moderator
    Reputation: Walt's Avatar
    Yup, stick a drill bit through the binder slot, drill the crack, call it good.
    -Walt
    Dec 2017
    update
    Done, I had to enter with a bit flexible support. Thanks everybody for the suggestion!
    Small crack inside the seat tube. Should I worry?-img_20180611_161653.jpgSmall crack inside the seat tube. Should I worry?-img_20180611_161811.jpg
    Nothing seems to kill me
    Reputation: CUP-TON's Avatar
    Dec 2016
    That looks good.
    And after calming me down with some orange slices and fetal spooning, ET revealed to me my singular purpose.
  1. Sanding down inside of carbon seat tube to lower seat post?
    By Trevor2458Italia in forum Bike and Frame discussion
    Last Post: 02-21-2017, 07:05 PM
  2. Should seat tube or post always be parallel with the head tube?
    By Speeder500 in forum Downhill - Freeride
    Last Post: 10-08-2013, 05:20 PM
  3. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  4. How to repair seat tube and top tube crack?
    By febikes in forum Frame Building
    Last Post: 05-17-2012, 01:33 PM
  5. Should I worry, bow in top tube
    By Froride1 in forum Frame Building
    Last Post: 01-23-2012, 10:41 PM
