Seat tube reamer?- Mtbr.com
Results 1 to 12 of 12
    Seat tube reamer?
    I want to install a dropper post in my frame but the seat tube insertion depth is not enough. I only need to ream about 19mm @ which point, in the seat tube, is a minute step. I don't know if an adjustable reamer :
    https://www.jensonusa.com/Chadwick-A...iABEgJ48fD_BwE
    Or fixed :
    https://www.bike24.com/1.php?content...7C%7C%7C%7C%7C
    Reputation: Mr Pig's Avatar
    What about a shorter dropper?
    Oct 2016
    What size? I have a 30.9 setup for sale.
    Quote Originally Posted by Mr Pig View Post
    I am 6'5" tall and need the largest dropper available - 200mm.
    Quote Originally Posted by Black Squirrel View Post
    Need a 31.6mm. Thanks.
    Quote Originally Posted by keen View Post
    If you fit a 30.9 and a shim you might not need to alter the frame.
    I am currently running a shimmed Thomson post and get creaking. Not sure if having the dropper greased, @ the insertion, would eliminate the noise but it would still have movement. Before I shimmed my current setup reviews for shims were a bit mixed.
    Reputation: life behind bars's Avatar
    May 2014
    Or fixed :
    The first linked tool isn't the correct size, the second is handles, you'll also need the proper size reamer. I'm with the poster that suggested a shim.
    "These things are very fancy commuter bikes or really bad dirt bikes, but they are not mountain bikes." - J. Mac
    Reputation: Clockwork Bikes's Avatar
    Just add a handle. https://www.ebay.com/itm/1-244-Carbi...4AAOSwzaJYBpkL
    Or, if you don't want to mess around, Joe Bringheli sells the best reamers.
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Creaking has nothing to do with the size of the post or whether or not a shim is used. In fact I would suspect that the noise is coming from the saddle area, not the lower part of the post.
    There isn't any reason why a shim shouldn't work fine. I've used them a couple of times with no issues, although I do seek out 100mm ones rather than the more common 80mm, just because. Most frames only support the seat-post over that sort of area so seat-posts, dropper or not, will have to be designed with that in mind. I would definitely just use a shim rather than starting to remove metal from my seat-tube. No question.
    I decided to dig a little into the creaking noise. It is in-fact the post to frame area was causing the creak but not where I would have guessed. I thought the shim might be slighting rocking during seated climbing but one shot of silicone on the post (then re-inserted) and it was creak free. The post is a Thomson 27.2 w/ a Cane Creek 27.2 / 31.6 shim. I only used the skinny post as that was what I had from an old Turner frame.
    You should grease the post anyway, or use assembly paste if it's a carbon one.
  1. 30.9 Seat tube reamer
    By Black Squirrel in forum Classifieds
    Last Post: 2 Weeks Ago, 05:16 PM
  2. Replies: 6
    Last Post: 09-21-2015, 03:37 PM
  3. Cyclus seat tube reamer review
    By RCP FAB in forum Frame Building
    Last Post: 08-11-2015, 11:48 AM
  4. 44mm head tube reamer/facer
    By experiment70 in forum Frame Building
    Last Post: 09-05-2013, 08:52 AM
  5. Anyone have a 30.9mm seat tube reamer? (South bay)
    By Daniel O. in forum California - Norcal
    Last Post: 03-31-2011, 03:10 PM
Members who have read this thread: 11
